Old 10-24-2012, 02:31 PM   #1
obi10
Member#: 303092
2002 Impreza WRX
Default XPT Stage 2 LC
Does anyone know how to set launch control on the XPT map with LC? Been trying to figure out how to but no luck, xpt hasn't emailed me back either. If you know how to set it, I would appreciate the help. Thanks!
obi10 is online now   Reply With Quote
Old 10-26-2012, 05:40 PM   #2
obi10
Member#: 303092
2002 Impreza WRX
tttttttttt
Old 11-23-2012, 09:43 PM   #3
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
There should be two settings with the XPT stage 2 LC.
Something about RPM
And something about Speed.
The RPM is your redline minus the number. So if your redline is 7k, and you put in 2k for the value, it will rev to 5k. If you put it at 3k, it will rev to 4k.
The Speed value in MPH will be when it turns off. Set it to like 3mph, so when your car reaches that point, the LC will turn off. Setting it high like 30, means until you reach 30mph, you will not be able to go higher than the RPM set by you.
Jubert69 is offline   Reply With Quote
Old 12-01-2012, 03:16 AM   #4
eeyuhc
Member#: 312339
'14 BRZ
CBS
Seems to me you need the XPT Defs that are provided in osecuroms, but even I have trouble getting my account activated. I also have the stage 2 map for my 2003 wrx.
If ANYONE has these defs, it would really be appreciated.
eeyuhc is offline   Reply With Quote
Old 12-01-2012, 03:29 AM   #5
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
PM me your email. I have one.
Old 12-01-2012, 03:48 AM   #6
eeyuhc
Member#: 312339
'14 BRZ
CBS
Pm'ed
Old 12-01-2012, 11:27 AM   #7
Danthrax
Member#: 299368
2014 Impreza 2.0i
How is the xpt stage 2? And what mods do you have and fuel do you use?
Curious because I have an invidia TBE and grim speed up pipe in the mail and was wondering if they have good tunes.
Danthrax is offline   Reply With Quote
Old 12-01-2012, 12:46 PM   #8
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Pm'ed
Will send it when I get home
Old 12-01-2012, 12:46 PM   #9
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
K&n drop in, catless turboback
Old 12-01-2012, 11:06 PM   #10
eeyuhc
Member#: 312339
'14 BRZ
CBS
Thanks, you are the man!
And @ Danthrax
High flow catted DP/stock catback, gutted UP, drop-in panel (spectre) filter. No issues so far. So much smoother over stock. But it's only been a few days, so I am still learning about the new tune.
Old 12-02-2012, 08:40 PM   #11
Danthrax
Member#: 299368
2014 Impreza 2.0i
Did you have to do the resistor mod to clear the CEL?
Old 12-12-2012, 12:37 AM   #12
eeyuhc
Member#: 312339
'14 BRZ
CBS
Found from a different source(http://forums.nasioc.com/forums/show....php?t=1559011 [post 4].
Old 12-15-2012, 02:21 PM   #13
pocketdrummer
Member#: 197301
2005 WRX STI
W R Blue (02C)
I just bought an XPT tune. I got my account activated within 2 days of submitting the order number to him (PM him on osecuroms).
pocketdrummer is offline   Reply With Quote
