Old 05-20-2012, 10:15 AM   #26
easterbran
Member#: 307359
'05 STi Stage II
Originally Posted by DSRX2005
Ya when I did this I noticed the same thing, I decided that the wires wouldn't enjoy that much tension so I just cut them and extend it with a separate wire. I just soldered and put heat shrink on them. The lights defiantly look a ton better after. Good write-up!
Did you cut the black and the red wire and extend both of them? I just did this mod and noticed the tension. Any specific wire I have to use to extend it? thanks
Old 05-21-2012, 01:35 AM   #27
Scooby STIle
Member#: 277027
2004 Impreza WRX STI
Jeez.... I see you posting in almost every single thread I'm subscribed to. Lol.
But I second this comment, I've been watching this thread and was considering cutting and rewiring. Any special gauge wiring anyone would suggest who's done this?
Scooby STIle is offline   Reply With Quote
Old 05-21-2012, 07:06 AM   #28
easterbran
Member#: 307359
'05 STi Stage II
Haha we share interests. But I ran over to Oreily and picked up some wire and crimps. I cut both the red and black, attached a crimp thing to each end (so four crimps per light) cut a new length of wire, and crimped it into the other ends of the crimps I put in. It's really easy.
Old 05-21-2012, 07:09 AM   #29
easterbran
Member#: 307359
'05 STi Stage II
http://www.parts-express.com/pe/show...number=095-550
These are what I was calling "crimps" I guess they're called butt connectors
Old 05-21-2012, 07:18 AM   #30
easterbran
Member#: 307359
'05 STi Stage II
The butt connectors are 22gauge and 18Cal. (22-18) The wire is 18 gauge
Old 05-21-2012, 11:18 PM   #31
Scooby STIle
Member#: 277027
Impreza WRX STi
lol i was just looking for the gauge of the wire. I already have my soldering gun and some heatshrink ready. Personally I dont like the crimp connectors
Well I'll probably be attempting this within the next couple of months, so if I do and it comes out alright I'll post it up here and I'll try to take pics of every step too
Old 09-15-2012, 07:18 PM   #32
armintheman
Member#: 316460
2008 STI
Snow White
sorry to bring this up from the dead but can someone explain how to rewire to make the lights look like the last pic? thanks guys!
armintheman is offline   Reply With Quote
Old 09-17-2012, 06:44 PM   #33
armintheman
Member#: 316460
2008 STI
Snow White
Originally Posted by nosmo View Post
^^^Yup it works well
this is what I'm wanting to do but could someone explain what I need to do to the wiring?
Old 09-18-2012, 12:21 AM   #34
djtoone
Member#: 285097
2004 WRX
Java Black Pearl
Have you sent Nosmo a private message to see if he can tell you what he did?
djtoone is offline   Reply With Quote
Old 09-18-2012, 06:59 AM   #35
easterbran
Member#: 307359
'05 STi Stage II
Oh yeah I never did post a pic...
Old 09-20-2012, 09:25 PM   #36
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
I Got a PM from this. I really cannot explain what I do for this since it's been a couple years since I've done it, but I'll make an effort to do a set and take some pictures. As I recall it takes 2 butt connectors (I'm in Vegas, if it were wet I'd solder and shrink wrap) some sniping and splicing. Give me a week someone will want the mod done.
nosmo is offline   Reply With Quote
Old 09-26-2012, 10:10 PM   #37
poodlchu
Member#: 286746
2015 WRX
Ice Silver Metallic
Nearly a week! here is a motivational bump/reminder! lol
poodlchu is offline   Reply With Quote
Old 11-02-2012, 01:22 AM   #38
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
w/ the original poster directions change out the bulb in the new center socket w/ the bulb in the reverse light and you will have the result of the two outer bulbs lighting up while braking. this works bc the bulb removed is a double element swapping for the single element of the reverse light.
krambte79 is offline   Reply With Quote
Old 12-01-2012, 03:09 PM   #39
Scooby STIle
Member#: 277027
Anyone have a spare set of taillight harnesses?
After I did this mod, I rewired my harness to further change my setup, and now have an idea for another mod but want to test with a fresh harness.
It involves rewiring every bulb, and the turn signal bulb will be turned into a secondary reverse light
Old 05-12-2013, 11:28 PM   #40
kriiiss
Member#: 208848
2006 Sti
AW
Will the left side tail light harness fit on the right side? One of the bulbs on my passenger side harness will not come out even after twisting it several different ways.
kriiiss is offline   Reply With Quote
Old 05-13-2013, 12:17 AM   #41
easterbran
Member#: 307359
'05 STi Stage II
Is it the bulb closest to you? (If you are standing at the back of the car looking at the passenger side harness). That one was finicky, but I promise, there's a very specific way you have to turn it, then use a little force and it pops out. I've removed that bulb at least 20 times now and it still doesn't like to come out.
Old 05-14-2013, 06:58 PM   #42
easterbran
Member#: 307359
'05 STi Stage II
For anyone interested, I just tested it on my 05 STi tail lights, the right and left wiring harnesses ARE interchangeable and function perfectly.
JDM Taillight Mod turboxsubie05 Interior & Exterior Modification 3 04-24-2011 05:11 PM
JDM Taillight mod question yo14jman Interior & Exterior Modification 1 10-08-2009 05:31 PM
JDM taillight mod? ThirdEye Newbies & FAQs 10 03-21-2007 05:43 PM
jdm taillight mod? Jake06wrx Electrical & Lighting 8 04-17-2006 11:31 PM
04-05 jdm taillight mod 00Maddog Alaskan Impreza Club Forum -- AKIC 10 10-18-2005 12:08 AM
