Old 12-01-2012, 12:41 PM   #1
gonzo1
Member#: 243589
2005 Impreza WRX
Default After installing trans, Air bag light and no horn
After installing my transmission and getting everything installed back on, my air bag light stays on and my horn does not work anymore. I looked at fuses and nothing. Every connector seemed to be installed. Don't understand why they both are. Also now my dash lights went out, i replaced the fuse for illuminate and popped, then i installed another one and nothing. Looked at fuses in engine bay and same. Help..... thanks
gonzo1 is offline   Reply With Quote
Old 12-01-2012, 01:27 PM   #2
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
You pinched/pulled a wire somewhere... You obviously didn't pinch/pull them in the fuse boxes, so look elsewhere...
We wearn't there for the work, we don't know what you did, but you did something, usually rather silly and like 10min from now you're likely going to come back and say "guys, I'm dumb, I found it"
Old 12-01-2012, 03:16 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The problems could be related, or there could be more than one issue.
Airbag light + no horn usually = a bad clock spring. Did you for any reason have the rack disconnected and turn the wheel? That is how they usually get broken.
To verify the source of the airbag light you can get it scanned at a dealer, or use the DIY procedure in the FSM to read the code through the light.
The blowing fuses, I agree that if it only happens since the trans work you probably pinched a wire. Visual inspection and troubleshooting with the electrical manual should find the cause.
