Old 12-02-2012, 12:10 AM   #1
avikm289
Member#: 315748
2012 wrx
White pearl
Default 2 piston brembo question
My calipers were split to be powder coated, and I got them back still split. I hear the torque specs for the fronts are 65 ft/lb for the 4 splitting bolts. What is the torque for the rear Allen bolts? There are 4 bolts on the rear 2 piston that's are hex type. There sti calipers btw
avikm289 is offline   Reply With Quote
Old 12-02-2012, 01:15 AM   #2
sc00by4life
Member#: 97135
Why did you split them to be powdercoated? It is very easy to permanently damage them once split...
Old 12-02-2012, 06:08 AM   #3
avikm289
Member#: 315748
2012 wrx
White pearl
The guy I went to split them, and I read up on the great debate why/why not they should be split or not
Old 12-02-2012, 08:26 AM   #4
sc00by4life
Member#: 97135
I would probably never go there again. There is soooo much that can go wrong by doing what he did.....make 100% sure they actually hold pressure once you get them on the car.
Old 12-02-2012, 03:29 PM   #5
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Originally Posted by sc00by4life View Post
They are actually 85ftlbs for both front and rear. Why did you split them to be powdercoated? It is very easy to permanently damage them once split...
Where did you get that torque spec? All the research I've done has lead to "no published torque spec". Furthermore, I highly doubt the torque spec on a M8 bolt into aluminum is 85ft/lbs.
All the sets I've reassembled after powder coat I've just tightened them by feel. If you want a torque spec, look up bolt charts, educate yourself based on the hardware specs and decide for yourself.
I've split dozens of sets. As long as you're not stupid there isn't much that will go wrong. Replace the cross seal.
Old 12-02-2012, 04:05 PM   #6
sc00by4life
Member#: 97135
I think i confused the bracket torque with the halves.
OP does seem correct though, according to the porsche forums those guys are saying 62-65ft lbs.
i edited my original post.
Old 12-02-2012, 04:11 PM   #7
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
85 ft/lbs is too high for the M8 bolt into the aluminum bracket in the rear. The FRONT M10 caliper bracket bolt is 85 ft/lbs.
Old 12-02-2012, 04:24 PM   #8
sc00by4life
Member#: 97135
yes, sorry front.
rears are 24ftlbs?
Old 12-02-2012, 04:27 PM   #9
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Here's food for thought for the caliper half bolts that I just realized:
The caliper half bolts are the same size and thread, threading into the same material as the bracket bolt. Make what you will of that information
Old 12-03-2012, 04:20 PM   #10
avikm289
Member#: 315748
2012 wrx
White pearl
reassembled them, tourqued as best i can (allen heads stripped a lil so i stopped) and blead them and its good thank god
