Old 01-18-2011, 12:52 PM   #1
leighton1245
Member#: 210593
2002 WRX PSM
Epic tuned 300whp
Default Wiper help please (wont turn off)
Everytime I have turned my car on today my wipers turn on for a bit then eventually turn off, when the switch is in the off position. I have tried turning the switch on and off all it does is make it go faster doesnt shut off.
leighton1245 is offline   Reply With Quote
Old 01-18-2011, 01:15 PM   #2
KIrbstermcgee
Member#: 182273
I'm at work right now so i dont have acces to a schematic. However i would be willing to bet you have an issue with the "park" function. You know when you turn you wipers off and they dont just turn off immediatly where they are on your windshield? It has to go another stroke then "park" in the off location. Bad ground maybe? Short to power? Check your connections for corrosion for any obvious issues. After that study the schematic, or have an expirenced tech look at it.
KIrbstermcgee is offline   Reply With Quote
Old 01-18-2011, 01:17 PM   #3
leighton1245
Member#: 210593
2002 WRX PSM
Epic tuned 300whp
Thanks for the help I have a schematic now and im looking at it, there is icy rain coming down maybe corrosion on the connector.
Old 01-18-2011, 01:27 PM   #4
KIrbstermcgee
Member#: 182273
Your on the right path ::Thumbs Up::
Old 02-14-2011, 12:59 PM   #5
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Aww man mine jsust started this... is it just the switch on the stalk?
djerickd is offline   Reply With Quote
Old 02-14-2011, 01:03 PM   #6
leighton1245
Member#: 210593
2002 WRX PSM
Epic tuned 300whp
The switch from subie is $218 to replace that is what mine was.
Old 02-14-2011, 01:05 PM   #7
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
ouch! maybe I can clean it.. post the part number if you have got it!
Old 03-16-2012, 07:14 PM   #8
ilikewrx10
Member#: 188122
1998 OBSTi
Green
Default Same problem
I have the same problem. When it's wet out my wipers turn on and won't turn off. Like the OP said if I mess with the switch on the steering column it just increases the speed of the wipers but won't turn them off. I got a new switch which didn't do anything, then I respliced and sealed the wires coming through the firewall to the connector for the wiper motor (I have a swapped 98 wagon) and that didn't help. I went out and got dielectric grease and sealed off the connector and that helped for about a week. Now they have turned back on again so I pulled every pin out of the connectors and cleaned everything out and resealed with the same grease and it didn't make any difference.
Anyone have any ideas? Is dielectric grease even the correct product to be using here?
ilikewrx10 is offline   Reply With Quote
Old 12-02-2012, 08:57 AM   #9
sackytar
Member#: 149262
2003 03WRXw6sp/05FXT
Had same thing happen last night relay?
sackytar is online now   Reply With Quote
HELP!! key wont turn in ignition wrx600rr Electrical & Lighting 4 10-22-2008 06:34 AM
wierd problem (lights wont turn off) mrpeabody3119 Factory 2.0L Turbo Powertrain 11 06-14-2005 07:46 AM
boost gauge light wont turn off, please help! jmanny152 Electrical & Lighting 4 02-20-2005 10:39 PM
HELP!!!! Car wont turn off! wrxsc Factory 2.0L Turbo Powertrain 25 07-06-2004 07:31 AM
Message Board Statistics All times are GMT -4. The time now is 09:32 AM.
