#1 |
Member#: 282972
I understand what these products are supposed to do, but they are such different looking set ups with the same purpose which would be better? I have a 2011 STI custon stage 2 tune. Ive taken my IC off many times and i always have oil in it so i figured i should get one of these. whats your thoughts...
#2 |
Member#: 255776
Vehicle:2010 LR WRX MPS and PAR powered. |
Well, one works fairly well, the other...Not so much.
#3 |
Member#: 233501
Vehicle:07AD 337/335SAXWAGON 99 outback sport |
One collects the oil blow by (Crawford)the other one recirculates it to the intake/ back to the oil pan (GrimmSpeed)
GS aos have been know to allow oil to slosh back up into the intake tract on hard right turns. Crawford: awesome for track does what its supposed to. You have to empty it periodically though. GS: set it and forget it don't use it on the track, unless you like burning oil. I personally use the GS and have no problems with it, but I also do not track the car. It has definitely stopped all/most of the blow by making it to the tmic, and I only burn an 8th~16th of a qt per oil change (3750 mi) ~Evil |
#4 | |
Member#: 117980
Vehicle:2005 sti wr blue |
#5 |
Big Ron
Moderator Member#: 18062
Vehicle:on car parts so PM me b4 j00 buy |
Don't get either and save all that money as I've been on this forum since 1865 and have a favorite quote:
My car exploded due to the lack of an oil catch can/air oil separator----nobody |
#6 |
Member#: 255776
Unabomber, the same could be said for intakes, downpipes, or any mod really...It's not like it's a bad idea to get one. I do think that you can often spend that money elsewhere, but it's just a way to keep oil out of the intercooler and keep it more efficient.
#7 |
Member#: 136314
Vehicle:2014 Grand Cherokee |
^ +1
Who said anything about AOS keeping your car from exploding? A mod is only worth it if it keeps the car from blowing up? ![]() Every turbocharged subaru I've owned without AOS had oil in the intercooler...the intercooler in my current 2012 STI with a GS AOS is bone dry, which makes it more efficient. |
#8 | |
Member#: 282972
Only track would be the 1/4 mile. thanks |
#9 |
Member#: 282972
Yeah it seemed like the crawford would be more work to take car of. Well if i buy one ill most likely get the GS. thanks guys
#10 | |
Member#: 282972
You had a lot of oil in the IC? i get a pretty good amount sometimes |
#11 |
n00b Moderator
Moderator Member#: 140114
Vehicle:06 18G Semi Built SGM WRX |
Oil in the intercooler is normal mind you.
#12 |
Member#: 136314
#13 |
Member#: 62985
Vehicle:2005 STi Platnium Silver |
#14 |
Member#: 330625
Vehicle:2006 WRX WRB |
#15 | |
Member#: 280572
E. Canada
Vehicle:2011 sti sedan plasma blue pearl |
how do u figure the Crawford aos would be higher maintenance??? For every day use go with gs aos, if u r ever considering tracking or otherwise go with the Crawford aos especially if u live where u will be driving in the winter as they utilize your turbo coolant lines so condensation will not freeze up your vacuum lines. Do a search there is lots of info about people having issues with the gs aos. Gs makes good products but from what I've read I won't touch their aos. |
#16 |
Member#: 330625
Whoa, reading the crawford aos description this sounds like one of the few mass market aos that are actually designed correctly. At the very least they make it sound like they did it right. I wont run a normal catch can draining back to the pan, I've run multiple manual drain ones and you get serious milk shake built up in there, crawfords sounds like it should mitigate that problem. At least they realize its a problem.
#17 |
Member#: 279525
Vehicle:04 rex luger! |
Yea i currently have a grimmspeed aos. Its for sale if anyone wants it. I removed it after advice from a tuner. He says remove it asap. The milky residue left behind is not good at all. After the residue accumulates it mixes and u get half water half oil.. Not good at all
#18 |
Member#: 255776
Leafy, the Crawford one really is about the only one. That's why I'm getting one for my built engine...But that's different than on a stock motor.
#19 |
Member#: 337700
Vehicle:2013 WRX Ice Silver Metallic |
Are there numbers out there showing the cooling differences of a TMIC w/ and w/o an AOS for everyday driving purposes?
I can understand the crawford piece in racing applications as you are constantly under boost and temps are always an issue but for DD? This question also applies to octane rating. I keep hearing about blow-by decreasing octane rating but I haven't seen any numbers. Are some of you guys running your cars at the level where even a fractional drop in octane or TMIC temps is going to be detrimental to your engines? Not poking here. I'm just asking honest questions. |
#20 | |
Member#: 280572
E. Canada
#21 |
n00b Moderator
#22 |
Member#: 255776
^^^Except in a front mount, it will collect and just sit...
OP probably doesn't have a front mount, but it's worth mentioning. |
#23 |
Member#: 330625
If you cut your stock top mount open right now. Ever single surface of it will have a fine oil film. The if the thickness of the oil film was known and the heat transfer coefs of the oil were known you could easily do the math to see how much it reduces the efficiency by. Octane wise, we know the octane of the oil, we dont know what mass is in the air stream. And the ratio of the oil mass to the fuel mass in the intake charge will determine how much it lowers the octane by.
#24 |
Member#: 245242
Vehicle:2006 STI E85 Power |
Crawford unit is better. Hands down.
#25 |
Member#: 278705
E. Canada
Vehicle:04 STi |
I've used both the GS and Crawford.
The GS didn't work for me (suspect it was related to the power I'm making, +400whp) I choose the Crawford because it was maintenance free, heated and came highly recommended. The Crawford is my choice, I can't recommend the GrimmSpeed. |
