Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 11-10-2012, 06:24 PM   #1
landon2992
Member#: 334211
2005 WRX Wagon
Some type of blue
Default Turboxs utec
Okay..so I'm still learning about subarus and I have a 2004 wrx and it has a turbo xs utec. I bought it from a dealer about 2 weeks ago. I just found out it has a turboxs utec. And I may not be able to contact the previous owner. So, question is...is there a way to find out what maps he has tuned in it? He put a map selector near the mirror switch but it isn't hooked up. I've been searching and searching so don't get on me about using the search bar. Keywords could have been wrong, I don't know. But any pointers would help. I may take it to a shop near me and have them look it over for the hell of it. Thanks!
landon2992 is offline   Reply With Quote
Old 11-13-2012, 02:51 PM   #2
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
you will need a serial cable or serial to usb cable and hyper-terminal to check out the maps installed. Turboxs is only an hour and 1/2 from you if you need support.
Old 11-13-2012, 07:41 PM   #3
landon2992
Member#: 334211
2005 WRX Wagon
Some type of blue
Thanks! I finally found more info on it. I was actually just thinking about going to them to have them check it out since they're close. But I do have a serial cable but won't hook to my laptop since its not a serial to USB. But that's how I first noticed it lol I was on my passenger side for some reason and I saw the serial cable tucked under the dash. So i moved the carpet and the kickplate and BAM! Saw a turboxs utec.
Old 11-13-2012, 08:52 PM   #4
landon2992
Member#: 334211
2005 WRX Wagon
Some type of blue
But I am also having problems with the map selector switch that is installed. It doesn't seem to work and I can't find anything about how it couldn't be working. I switch to a different map with it and it doesn't do anything. The red dial on the utec is set to 0 like it should be. I checked and it is in the accessory plug. There are two wires (I believe white and light blue; not 100% sure but they have connectors on the end) I'm not sure where they go if they are even suppose to be hooked up, I found them rolled up under the kick panel. And like I said I can't find anything that explains on why the map selector switch wouldn't be working besides making sure the dial is at 0.
Old 11-16-2012, 11:34 PM   #5
sidewayz
Member#: 5810
2001 S366 2.5RS
It's possible the selector switch is bad. How far are you from Allentown Pa?
sidewayz is offline   Reply With Quote
Old 11-18-2012, 05:08 PM   #6
landon2992
Member#: 334211
2005 WRX Wagon
Some type of blue
I was thinking that too. Idk if it needs an all time "hot" to change maps or not. If it does, one of the wires needs to be moved in the connector so it connects to the hot on the utec. I'm about 2 1/2 hours away from Allentown Pa!
Old 12-02-2012, 10:25 AM   #7
sidewayz
Member#: 5810
2001 S366 2.5RS
If you need help with it pm me.
Old 12-18-2012, 06:03 PM   #8
tmclaughlin83
Member#: 336108
2006 Impreza WRX Lim
Red/ Black
Soo I'm kind of in the same boat and after searching I'm starting to feel like the utec is an out-dated piece of **** but until I can upgrade I want to setup the 2 step launch control. Problem is I can't even connect to the thing. I've tried using a PC with windows 7 and a Mac with 10.6.8 running a VT100 emulator. Any suggests?
tmclaughlin83 is offline   Reply With Quote
Old 12-20-2012, 02:27 PM   #9
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
download hyperterminal on your pc. You might be able to get it off an older windows cd. I haven't tried accessing it in years with a Mac, last time was very frustrating just to get the cable recognized.
Old 12-21-2012, 04:17 AM   #10
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Use any PC running windows xp. Search files and folders. Type hyper terminal and two files will show up... hyperteminal.exe and hyperterminal.dll. It might show up abbreviated like hypertrm.dll or something iirc.Anyway just copy those two files to a flash drive and put those two files in the c drive of the newer laptop running windows vista or 7 etc. Might want to place hyperterminal shortcut on desktop for future use.
You now have hyper terminal... click on the exe and run. It will ask for new connection etc name connection Utec and save as for future sessions. Do the com port setup and other small things per user manual and all set. The hyper terminal screen will do nothing until you turn on acc power to utec. Then you will see utec main screen come on in black on hyper terminal.
*To play with maps in utec at home without 9v adapter, go to a music store and buy a Roland 12v power supply for a keyboard or drum machine. Bring utec and make sure plug fits. Presto. Have fun playing with maps and options without sitting in the car without that silly 9v battery thing. How did I know this would work... it seemed logical that any 12v power supply would work because that's what runs powered devices in the car, a 12v battery. I had some spare power supplies in a box... found a 12v that fit and it was the one made by Roland. Works perfectly.
Any issues send me a pm
blkgm8 is offline   Reply With Quote
