Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 11-22-2012, 03:37 PM   #3151
sc00by4life
Member#: 97135
Originally Posted by gregroot198521 View Post
While I'm not 100% sure on the'08 STi's stock tire diameter, but guessing its pretty close to the '11 specs (I believe it's 235/35-18 @ 24.4" in diameter) so the smallest Geolander in that size (225/60-17) is 27.6" in diameter. Highly likely to rub on pretty much any setup he could go with. Would take some hellacious fender work, almost guarenteed. Here's the tire calculator I used:
http://www.rimsntires.com/specs.jsp
stock sti size is 245/40/18.
a 27.6" tire will not even fit the car without forester struts.
Old 11-22-2012, 09:39 PM   #3152
gregroot198521
Member#: 280844
2006 STi
Yep, like I figured. Didn't realize the stock tires were that big though. Maybe I was thinking of the stock size on the GD STis, 225/45-17. I'll run into the same problem though, once I get the '06, but I'm gonna be going after some gravel spec brakes, then I can fit my 15" Braids. They'll still be overly large in the tire size (215/70-15), but it'll have to do for a bit. At least till its time for some replacements.
gregroot198521 is offline   Reply With Quote
Old 11-23-2012, 03:59 PM   #3153
K_DubWRX
Member#: 335083
2003 WRX Wagon
I was going through some old pics today and came across these pics of a dry river-bed run years ago. '87 XT-Turbo with stock air-ride, 5-speed with locking diff. Stock, but dirty.
How about snowy?
I'm looking forward to the day my WRX can join this thread. Thank you all for the inspiration.
K_DubWRX is offline   Reply With Quote
Old 11-23-2012, 05:52 PM   #3154
burkart
Member#: 305000
2005 Legacy GT 5MT
Bright Silver Metallic
How about snowy?
holy ****! great post -- and amazing photos! was it an automatic or a manual?
junkyard finds subaru XT6 rare old sports coupe wacky 80s interior by tommyburkart, on Flickr
i came across one last summer and it had the best pearl white paintjob i've ever seen! i really wonder how it drives. probably pretty heavy but fast with a six and an automatic
junkyard finds subaru XT6 rare old sports coupe by tommyburkart, on Flickr
burkart is offline   Reply With Quote
Old 11-23-2012, 05:56 PM   #3155
burkart
Member#: 305000
2005 Legacy GT 5MT
ha im not very smart. lol. manual xt-turbo
Old 11-23-2012, 06:14 PM   #3156
K_DubWRX
Member#: 335083
2003 WRX Wagon
The XT wasn't fast by WRX standards, but it handled like no other. They're only 2,400lbs-ish with 115hp so it'd scoot, but the Full Time 4WD is a different beast, and the weight distribution was near 50/50. It would twist in a powerslide from a center of gravity right between the front seats. It just pivots like a tank. By the time that car went on to its next life, its air suspension was completely shot and it rested on the bump-stops. Serious problem on washboard dirt roads, but freaking amazing on smooth pavement. Oh, and the shifter was never more than a couple of inches away from the wheel and all the controls were at your fingertips. It fits like a Kayak. Mine even had the digital dash (some of which actually worked at first). Such a fun car to drive; if you get a chance to try one, do it.
Old 11-23-2012, 06:31 PM   #3157
K_DubWRX
Member#: 335083
2003 WRX Wagon
Here's a couple more, for being a good audience.
The Audi didn't make it out of the river-bed under it's own power. He cracked his aluminum radiator on a rock and I had to tow him to town.
These are from the same ski trip to Mammoth and Mono as the two above.
Old 11-23-2012, 06:41 PM   #3158
burkart
Member#: 305000
2005 Legacy GT 5MT
mmm sounds nice. yes the XT digital dash is pretty remarkable! some recent press
http://www.thetruthaboutcars.com/201...-digital-dash/
PLUS it looks alot like the Reventón from 20 years later...
digital dash - speedometer and instrument cluster - Subaru XT vs. Lambo Reventon by tommyburkart, on Flickr
Old 11-24-2012, 02:50 AM   #3159
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
coolest dash ive seen in a subaru hands down!
Daddy_Digital is offline   Reply With Quote
Old 11-25-2012, 05:08 PM   #3160
fkearney39
Member#: 286774
1995 ej20g legacy
white
does anyone know if you can fit 225/75/r15's on a 98 outback without any mods or with forester suspension? or any links to a car with them. thanks
fkearney39 is offline   Reply With Quote
Old 11-26-2012, 01:14 AM   #3161
wagoneggy
Member#: 265693
You should be able to fit those as your spring perches are higher than imprezas and foresters. Double check the clearance though for sure. They will rub like hell though so you might want to get a lift. You can make a cheap 2 inch strut lift if you have some HDPE and some tools. While you're at it get some low offset wheels to help with lateral tire clearance. So to make a long story short, without modification you might run into some issues. 215/75/15 should fit no issues and general grabbers Are a popular choice
wagoneggy is offline   Reply With Quote
Old 11-26-2012, 02:49 AM   #3162
fkearney39
Member#: 286774
1995 ej20g legacy
white
ok thanks, i was planning on getting body spacers and probably bigger springs but i was seeing if i could get them and run them for awhile then lift it. and yup general grabbers are what i was planning on getting haha
Old 11-26-2012, 10:46 PM   #3163
wagoneggy
Member#: 265693
I would lift it first honestly. Sure it'll look funny for a little bit but when I got my 27s I wanted to go bigger instantly. You won't have to worry about tire clearance issues either. 235/75/15 LTs are the business
Old 11-27-2012, 05:43 PM   #3164
sampsonohio
Member#: 312216
Originally Posted by westy2005 View Post
Here is my dedicated RallyCross car.
Dude nice setup, how much lift did you get form the GD springs? Also what material did you use for those massive flaps? Looks good
sampsonohio is offline   Reply With Quote
Old 11-30-2012, 07:41 PM   #3165
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
I just finished going through this entire thread and it really makes me want to get going on finishing up mine.
Here's a before and after of my 2005 Outback Sedan 3.0R. Has 1" Subtle Solutions lift spacers. Still have the stock 225/55/17's on it (Big O Euro's were on it when I bought it). I'm going to go with the Grabber AT2's in a 215/65/16 but I don't have any clue which 16" wheels to run. I want something like you might see on any other lifted 4wd vehicle (Cragar's or Black Rock's or Mickey's and etc.) just to be different but nothing seems to be in a 5x100 bolt pattern.
spshultz is offline   Reply With Quote
Old 11-30-2012, 08:10 PM   #3166
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
I ****ing love outback sedans.
ManualOverAuto is offline   Reply With Quote
Old 11-30-2012, 10:31 PM   #3167
skunkman
Member#: 118141
95 'lifted' legacy
skunkman is offline   Reply With Quote
Old 12-01-2012, 10:09 AM   #3168
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
^^^^^ That is EXACTLY what I plan on doing with mine once it's finished.
Old 12-01-2012, 11:33 PM   #3169
skunkman
Member#: 118141
95 'lifted' legacy
yours is H-6 3.0, is it automatic? If so Auto is tits off road, with the torque and power of the 3.0, plus an auto's slipping clutches , you should be able to do pretty well "for a car"
but such a nice and new rig, body damage is inevitable, once you start pushing and playing hard
nice looking OB sedan!!
Old 12-02-2012, 09:45 AM   #3170
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
Thanks! Yeah, it's a 3.0. I live in Colorado and will start out lightly first just to see what capabilities it has. Then once I'm more comfortable with it I'll start hitting some of the harder trails. I just need to find a group to go out with. I don't want to run them alone. Bad joo joo is certain to happen if I do.
I was hoping to maybe get 1 more inch of lift out of it so that I could run a slightly larger tire. But as it is now the tires have moved too close to the body for any further lifting and the 215/65/16's are gonna be about it.
By the way, we'd love to see some video of your car in action. It's pretty cool to see a car going where only the bigger 4wd's go.
Old 12-02-2012, 10:03 AM   #3171
ManualOverAuto
Member#: 304662
Sedona red Pearl
Someone correct me if I'm wrong, but I think different trailing arms will take care of that. Either adjustable ones, or the just the bracket from (insert car)?
Awesome car though! Don't forget to post up pics of it when it gets all dirty.
Old 12-02-2012, 10:34 AM   #3172
gregroot198521
Member#: 280844
2006 STi
Yeah, it'd be the trailing arms for the rear tires. Check out Gorilla Offroad, Jack(Skemcin on DI.com) has some adjustable trailing arms for most MYs.
Old 12-02-2012, 11:00 AM   #3173
premier00000
Member#: 251060
2008 Impreza Outback
This thread has me thinking about trading my '08 OBS for an older Forester or Outback to lift and have fun with...
Old 12-02-2012, 11:41 AM   #3174
skunkman
Member#: 118141
95 'lifted' legacy
@ ManualOverAuto: You're on the right path for the typica fix of that problem, but that won't work on his car. His rear suspension is different (not macpherson strut).
I'm not too sure what will fix that in his car, I have only seen a couple other lifted 3rd gen outbacks. . . .
My knowledge on those is limited.
@ spshultz: How did you lift your OB? strut top spacers, king springs?
Old 12-02-2012, 11:42 AM   #3175
skunkman
Member#: 118141
95 'lifted' legacy
YEAH!!!
Chamois, or just plain Sham? Lifino Interior & Exterior Modification 8 10-02-2013 08:01 PM
SOA gotta love 'em or just plain hate 'em kalbo-1 Warranty Issues & SOA Problems 1 01-19-2004 08:29 PM
Hot or Not or Just Plain Ok.... n20x3whitewrx Member's Car Gallery 28 07-29-2002 10:05 AM
McRae: Dedicated or just plain nuts? SubaruStu Motorsports 2 03-20-2002 09:55 AM
Jinxed? Or just Plain UnLucky??!! silverSurfer General Forum Archive 6 06-30-2000 10:27 PM
