Old 11-07-2012, 01:31 AM   #451
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Originally Posted by lazyimpreza View Post
i see that all o8+ wrx 2.5i and outback sport Struts + Shocks are interchangeable.
but i also read some posts that say 11 wrx struts will not fit 11 2.5i due to the widebody on the wrx, is this incorrect??? or like the first statement, all 08+ shocks/struts are interchangeable
thanks in advance
The 2011 wrx struts will fit, however you will lose some negative camber due to the change in track width. I think. You would be better served by 09 or 10 wrx dampers.
- Andrew
AndyRoo is offline   Reply With Quote
Old 11-08-2012, 08:49 AM   #452
lazyimpreza
Member#: 319024
if i'm planning to keep my ride stock height, losing the negative camber woudln't be an issue would it?
lazyimpreza is offline   Reply With Quote
Old 11-08-2012, 01:34 PM   #453
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Originally Posted by Power6 View Post
What are you looking to interchange? ;-)
08-10 WRX (and 08-11 Impreza) front LCA are the same as 05-09 Legacy arms. The front/rear bushings in them are common to all 08+ Impreza (including 08-10 STI) and the 07-09 Legacy SpecB (other Legacies use softer interchangeable bushings). LCA are interchangeable with the 05-09 Legacies, including the aluminum arms used on the 07-09 Legacy Spec B.
Rear Arms: 08-12 Impreza are all the same rear arms including WRX and STI, arms bushings etc all the same on all models. There is a Subaru JDM arm kit for the Impreza, features pillow-ball bushings for the rear LCA and toe arm.
Wow I want those front LCA's really bad now. May I ask how much you paid for them? Also to clarify, the sti bushings on the rear lca's are pillowball but the 2.5i/wrx are not? Also do you think that the sti's rear lca's are any stronger/beefier than the 2.5i/wrx versions? The reason I ask is when installing my new suspension mine tended to flex quite a lot from just trying to get the rear shocks and place and I really did not like that . Any feedback or input is very much appreciated
KartRacer3 is offline   Reply With Quote
Old 11-08-2012, 01:38 PM   #454
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
You should be fine, if anything I would say you would losing maybe .5 degree of camber ability.
Also to Racecomp you should update the first couple posts for 08+ 2.5i/wrx fitment on swaybars. The rears are all interchangeable across all impreza models, grant it the 2.5i models just need the hardware to mount the RSB i.e. brackets and endlinks.
Old 11-08-2012, 09:33 PM   #455
Devon
Member#: 321595
2005 Legacy GT
I agree, I have an '09 STI rear sway on my '10 OBS. Fits no problem with the end links/brackets from the STI as well.
Devon is offline   Reply With Quote
Old 11-27-2012, 11:06 AM   #456
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
Will RCE black springs from a 2010 STi fit a 2011 WRX? Any issues?
ResidentR is offline   Reply With Quote
Old 11-27-2012, 01:10 PM   #457
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
No.
45
Old 12-02-2012, 02:37 PM   #458
RunninKurt
Member#: 338292
2016 Wrangler
Tank
So after reading the 02 WRX thread, I know I can use 06/07 STi springs as long as I get top hats accordingly. Would those springs provide any lowering compared to factory springs?
RunninKurt is offline   Reply With Quote
Old 12-02-2012, 10:12 PM   #459
RunninKurt
Member#: 338292
2016 Wrangler
Tank
Anyone?
Old 12-02-2012, 11:12 PM   #460
Bikelok
Member#: 254851
2002 WRX wagon 5mt
You will also need 921 spacers for the rear struts-to-top hats. Otherwise the top hats will clunk. Go to Turn In Concepts for them.
Those springs will drop about 10-15mm over stock.
Bikelok is offline   Reply With Quote
Old 12-03-2012, 09:06 AM   #461
RunninKurt
Member#: 338292
2016 Wrangler
Tank
Thanks a ton!
Old 12-05-2012, 08:49 PM   #462
Kevlar_07
Member#: 339474
2008 Impreza OBS
Just picked up a 2008 OBS, I'm curious what my options are for a rear sway bar. Will a 2008 Sti or wrx bar work,or should I be looking at an aftermarket bar? This is my first Subaru I previously drove a cobalt ss/sc and can not stand all the body roll. Any help is greatly appreciated
Kevlar_07 is offline   Reply With Quote
Old 12-06-2012, 09:06 AM   #463
bidaci
Member#: 291519
2011 OBS
08+ STI or WRX take offs are your best bet. Try to get them with the endlinks and attaching hardware and it will be an easy 5 minute bolt on. The STI bar is thicker then the WRX by 2-3 mm depending on years. I used an STI bar on mine with the stock front and find it a great addition.
bidaci is offline   Reply With Quote
Old 12-06-2012, 11:38 AM   #464
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
Originally Posted by RaceComp Engineering View Post
Well the issue will be that on the front struts the lower clevis tabs are 12.5mm LONGER which would push your wheels OUT by that much AND in the process reduce your maximum camber capability.
In reverse......someone ( me) who has a 2011 WRX who installs say GTWORX/Bilsteins which are made for the 08-2010 WRX..that person would GAIN maximum camber. So the range would be -1.0 minimum to -2.9 maximum. AWESOME for performance.
Back to you. Your maximum camber would likely be reduced to like -.8 and your minimum would go down to like +1.0 which you dont want AT ALL.
Hope that helps.
Myles
so, will aftermarket front camber bolts remedy this problem? i picked up some 2012 wrx assembled springs and struts that i want to install on my 08 wrx. my car is only a daily driver...
are there any issues with the rear suspension? with this potential setup?
isotopesope is offline   Reply With Quote
Old 12-27-2012, 08:19 PM   #465
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
I know I can replace a stock wrx setup into a 98 forester no problem. I am just wondering if the top hats will match up if I have the struts and springs from the wrx with the top hats of the forester?
bugeye-brawler is offline   Reply With Quote
Old 12-28-2012, 11:26 AM   #466
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
That might be okay. The rears are the same 08 to 12 fitment wise.
- Andrew
Old 01-05-2013, 11:21 PM   #467
bugeye-brawler
Member#: 182337
Sport -- White
PLEASE if you notice I'm missing something, don't flame me.....just let me know! I'll change/add it as soon as I can. And yes, please double check my work.
I may rearrange the organization, but for the time being i'm focusing on content.
- Andrew
There is no info on the front sway for Impreza Outback Sports from 98-0?
Old 01-21-2013, 11:44 AM   #468
IT Swift
Member#: 125853
2013 Impreza Sport
Red
Car: 2013 Impreza Sport Premium
What fits? 2008+ WRX/Sti stuff? The car is a nice little commuter, but I'd like to improve the suspension....
IT Swift is offline   Reply With Quote
Old 01-22-2013, 06:56 PM   #469
BayAreaSubie
Member#: 342924
2013 Impreza Sp Lim
Satin white pearl
+1
Subie Newbie here also. It'd be great if OP or someone with more knowledge about the 2012-2013 2.0L, non-WRX version of the Impreza, could post a list of the confirmed upgrades/mods for our vehicles. I know a lot more of us with the 2.0Ls will start popping up and I've been scouring this site for the past few days looking for some mods for my 2013 Sport Limited.
So for I found(though I can't confirm) that a 08+ STI RSB will fit on the new model...?
http://forums.nasioc.com/forums/show...=2012+sway+bar
Not much else though...
EDIT: so I crawled underneath my car today and discovered that yes, there's a OEM rsb on my 2013 Sport Limited so I hopped on the net and ordered the STI rsb, should be an easy swap.
Thanks for the info guys!
Last edited by BayAreaSubie; 01-22-2013 at 11:21 PM. Reason: Found new information
BayAreaSubie is offline   Reply With Quote
Old 01-23-2013, 10:59 AM   #470
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
To be honest I don't really know much about the latest Impreza. If anyone figures anything out, let me know and I'll update the thread.
- drew
Old 01-31-2013, 03:49 PM   #471
shiggz
Member#: 265102
2008 WRX
grey
so i couldnt find a definitive answer on the forums for this question and the dealerships dont seem to know either.
trying to do a cheap upgrade to replace my blown front shocks on my 2008 wrx hatch. I know the 2009 wrx shocks were slightly upgraded from what im told. and the 2011 shocks upgraded further but from a previous post the bolt patterns dont match up giving the car too much positive camber than you want..
i did some digging and it looks like the 2009 stock shocks theres two different variants.
any one know if the upgraded one is the "WRX TUNED" and if so if it will fit on my 2008 wrx?
thanks for the help
shiggz is offline   Reply With Quote
Old 02-24-2013, 10:34 PM   #472
ozunadel
Member#: 313772
1992 Skyline r32
work in progress
sooo, its safe to assume the Gt spec adjustable rear lower control arms made for the WRX 08+ would fit on my little 2.5i. just want to make sure before i drop the money on ordering them
ozunadel is offline   Reply With Quote
Old 02-24-2013, 11:11 PM   #473
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Yes, we have nearly every same suspension component as them (08+ Wrx). Minus the front sway bar of course.
Old 03-03-2013, 07:15 PM   #474
jamesonp16
Member#: 347149
2007 impreza 2.5
red
Default StI sway bars on a 2.5
I found stock STI sway bars (04-07) for a good price and I am wondering if they fit my 2007 2.5. I obviously dont want to buy them if they are not going to fit my car. does anyone know if they will fit? im very interested in these to start my suspension upgrades, any help that anyone can give me would be great!! thank you
jamesonp16 is offline   Reply With Quote
Old 03-03-2013, 07:20 PM   #475
timbo123
Member#: 207476
Anyone know if the 93-01 wrx struts,springs and mounts fit a 2001 RS sedan? I want full coil overs but can't find them for anything but wrx
timbo123 is offline   Reply With Quote
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 11:46 AM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 06:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 06:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 10:25 PM
