Old 12-01-2012, 03:37 PM   #1
conklin_02
Member#: 324190
2005 wrx STi
Default NEED HELP! Metallic grinding sound when driving
Hello nasioc, i have an issue that i cannot figure out. I recently took off my coilovers and put on my stock struts for the winter. Well, the parts went back together fine and there were no problems until today. I was driving down the road and noticed this horrible noise. It was very faint, but sounded like a metallic scrapping sound coming from my passenger front wheel. At slow speeds, i can hear the noise clearer, but cannot distinguish the sound. It almost sounds like the wear indicator on my caliper. But im not sure because my rotors and pads are fairly new. Any help would be great! thanks!
conklin_02 is offline   Reply With Quote
Old 12-01-2012, 11:48 PM   #2
conklin_02
Member#: 324190
2005 wrx STi
Bumpp. Any help would be great!!
Old 12-02-2012, 07:24 AM   #3
funk32
Member#: 245787
2004 STi
did you check your dust shield? you may have bent it in while working on that side
funk32 is offline   Reply With Quote
Old 12-02-2012, 07:30 AM   #4
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
this.
mhoerath is offline   Reply With Quote
Old 12-02-2012, 08:26 AM   #5
sc00by4life
Member#: 97135
Do you have stainless lines? Check and make sure they aren't rubbing on the wheel.....
Old 12-02-2012, 10:42 AM   #6
Dmochowski
Member#: 306478
2012 WRX limited
305whp/360tq TSM tuned
I had the same issue with my car after driving with debris on the road from a storm. Turned out to he a dust shield went and snaked an arm in there and pulled on it on the side of the road and it went away.
Dmochowski is offline   Reply With Quote
Old 12-02-2012, 10:55 AM   #7
conklin_02
Member#: 324190
2005 wrx STi
I will look at the dust cover. And no I don't have stainless lines
Old 12-02-2012, 09:28 PM   #8
Kingnothing616
Member#: 277507
Raise the front end up and spin the wheel... seems pretty easy.
Kingnothing616 is offline   Reply With Quote
