Old 11-27-2012, 04:31 PM   #1
07TexasSTi
Member#: 237032
2007 STi Limited#312
UGM
Default Lowering spring and sway bar questions
Ive been searching and havent really found definite answer. I'm about to order Tien S-tech springs and front and rear sway bars. I was wondering what sway bars I should use. I've read Whiteline are good but I'm unsure on what mm I should go with? Also is there any other brands I should check out?
Any help is greatly appreciated.
07TexasSTi is offline   Reply With Quote
Old 11-27-2012, 04:37 PM   #2
07TexasSTi
Member#: 237032
UGM
And I just saw the sway bar and end link FAQ, sorry.
Old 11-27-2012, 06:10 PM   #3
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Sorry, but if your truly searched you will change your mind on those springs!
Perhaps the worst springs made for these cars. There is a sticky on it, it's so bad.
I think you need to do more research. Take your time on this, do it right.
Bikelok is offline   Reply With Quote
Old 11-27-2012, 07:03 PM   #4
07TexasSTi
Member#: 237032
UGM
Thank you, I didn't look much into the springs because I liked the price.
Old 11-27-2012, 10:21 PM   #5
glejsmar
Member#: 210242
2004 Impreza WRX
I always heard that tein springs were very good. Have not use them myself, actually planning on buying them next week. More details on why they are the worst springs??
glejsmar is offline   Reply With Quote
Old 11-27-2012, 10:29 PM   #6
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Go up to the suspension super sticky and look it up.
Basically put, they are too low and too soft.
Again go up to the stickies and take a good long look at all the GREAT INFO up there. Right at your fingertips.
Old 11-27-2012, 10:30 PM   #7
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
The S-techs are only designed to make your car look good, they were not made to perform well or be comfortable. There are much better options out there.
ResidentR is offline   Reply With Quote
Old 11-28-2012, 08:05 PM   #8
Vaughn Performance
Member#: 170489
Too low, too soft, purely designed for dudes that wanna slam their car and have no concern for anything performance related. Sticky covers it really well. To be fair, there is a deluge of other poorly designed springs out there as well.
If you want, you can drop me a line on here and I'll get ya pointed in the right direction.
-Anthony
Vaughn Performance is offline   Reply With Quote
Old 11-29-2012, 08:12 PM   #9
RunninKurt
Member#: 338292
2016 Wrangler
Tank
-Anthony
What are some suggestions for budget minded guys looking to get some low?
RunninKurt is offline   Reply With Quote
Old 11-29-2012, 08:36 PM   #10
you been hearing things at the kiddie slammer meets....tein springs are at the very bottom of the barrel for springs
Old 11-29-2012, 09:11 PM   #11
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Be careful how low. Most lowering springs are on the soft side, so beware. Lowering springs are not usually good performance springs. Personally I would not go lower than 30mm (about an inch).
Search for lowering springs to see what might do what you are looking for.
If you are on a budget look for used. Swift Sport is a well regarded lowering spring for example. Used is great way to save money.
Old 11-29-2012, 09:13 PM   #12
RunninKurt
Member#: 338292
2016 Wrangler
Tank
Thanks for the suggestion. I see a lot of used coil overs, but between the baby, wife, new house, etc... You know the story. Do I have to buy wagon specific springs? The front just looks stupid with the 2" gap...
Old 11-29-2012, 09:21 PM   #13
Bikelok
Member#: 254851
2002 WRX wagon 5mt
No, sometimes sedan springs won't sag on a wagon, but more often they will. So don't worry if you only find sedan springs. You can get saggy butt spacers to take care of any sag.
I made my own out of a poly cutting board and a jig saw. It's very easy to do.
Go to Turn In Concepts if you want to buy them. They are not that expensive.
Old 11-30-2012, 02:25 PM   #14
jaboyd
Member#: 247304
2011 STI
WR Blue
Default Dropping it
I would strongly consider adding a Whiteline Roll Center kit if you're dropping that much.....it will definately improve the "bump steer" and aid handling.....about $250 - 300 installed.
jaboyd is offline   Reply With Quote
Old 11-30-2012, 05:39 PM   #15
Vaughn Performance
Member#: 170489
As far as aftermarket goes, RCE and Swift are the two to look at. All the others are really more concerned with a fashionable drop and meeting a price point. RCE makes wagon specific lowering springs, for the RCE you'll need uprated dampers though. I recommend either Koni inserts Feal inserts or D-specs.
If you want aesthetic drop Swift Sport springs are fine, and have rates that aren't too detrimental to stock struts, though being an 02 you'd probably want to at least get new oem replacement bits. If you want proper performance oriented springs you need Swift Spec R springs, and again uprated dampers like the ones mentioned above.
If it was me I'd opt for RCE wagon springs and one of the above uprated dampers paired with Group N tops.
-Anthony
Old 12-02-2012, 11:44 PM   #16
sell the subaru and buy a vw or hunduha
