Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 12-03-2012, 12:27 AM   #326
papasmurf180
Member#: 322150
Sonic Yellow
Anybody have write up on how to do a 2011 sti TMIC install on a bugeye?!?! Would be greatly appreciated
papasmurf180 is offline   Reply With Quote
Old 01-14-2013, 06:05 PM   #327
I Love Sparklies
Member#: 334475
2005 Wrx
I have a 05 wrx and I'm trying to get a sti tmic on it. What parts can I reuse on my wrx intercooler to my sti intercooler? And what parts would I need to buy to make the sti intercooler fit?
I Love Sparklies is offline   Reply With Quote
Old 01-21-2013, 10:53 PM   #328
geedar
Member#: 224617
03 WRX
6-sp. vf39
I just installed n '05 USDM top-mount on my 03 WRX with a USDM VF-39. I followed the OP's instructions and it worked for me. There seems to be no difference between the USDM TD04 and VF-39 as far as installing the USD STI TMIC. I had to bend my AC line toward the firewall and it will mount on both brackets. I used the stock USDM STI Y-pipe (MY04) and only needed the two custom hoses to install.
2.75in ID at 3" in length
2" ID 90 deg. elbow at 4in. + 4in. in length (four inches on each side from the center) "slightly trimmed"
I located some radiator hose in these same dementions and it worked to some degree to get my car mobile but I later read that radiator hose stretches under boost which wastes energy and creates a lag-then-surge kind of effect. I now ordered the hoses in silicon like I should have in the first place.
I wanted black dull hoses for an OEM look but unfortunately silicon = shiney . Here in CA, cops can give you a $500 ticket for "modified emissions system" (I know, because it happened to me for an intake). Something to consider if you live in CA. A red or blue hose (even a shiny black hose) can cost you a lot of money and trouble.
geedar is offline   Reply With Quote
Old 01-27-2013, 04:58 PM   #329
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
That's crazy. Cops can ticket you for having a modified intake system? What if it has an emission sticker like K&N SRI?
Old 01-29-2013, 12:18 AM   #330
tobigforhisshoes
Member#: 251434
04 WRX
WRB 319/285 bobby tuned!
Holy law book Batman.
tobigforhisshoes is offline   Reply With Quote
Old 03-22-2013, 01:12 PM   #331
kevin85193
Member#: 145900
2003 wrx wagon
so in order to have a USDM 04-07 STi Top mount fit onto a 03 wrx w/ 16g =
http://www.siliconeintakes.com/produ...01078ee9aee664 ??
+jdm splitter + jdm scoop
kevin85193 is offline   Reply With Quote
Old 03-23-2013, 10:31 PM   #332
Rally Red Bugeye
Member#: 275808
2002 Wrx & Forester
Rallie Red
I need a write up on a 2008 and up sti tmic on bugeye?
Rally Red Bugeye is offline   Reply With Quote
Old 03-23-2013, 11:16 PM   #333
DZXN
Member#: 306186
2002 Subaru WRX
There is a link or two in the TMIC section of the manifesto about 08+ Sti I/C on 02-07. If you are going to run it with the td04 you will run into a problem with the wg actuator. If running with a vf you will only need to do some minor mounting mods.
DZXN is offline   Reply With Quote
USDM STI TMIC on 06 WRX- Install Question Flexx999 Factory 2.5L Turbo Powertrain 8 07-16-2006 04:20 PM
Impression after installing USDM STi TMIC... gopsu Factory 2.0L Turbo Powertrain 24 03-14-2006 06:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated Private 'Wanted' Classifieds 0 02-09-2006 03:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated MWSOC Private Classifieds 0 01-31-2006 02:26 PM
JDM V7 STi TMIC vs USDM STi TMIC crystalhelix Factory 2.5L Turbo Powertrain 18 01-13-2006 03:16 PM
Message Board Statistics All times are GMT -4. The time now is 11:13 AM.
