Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 09-21-2011, 12:49 PM   #26
Member#: 141182
96 Impreza Coupe
Good thread.
96 Brighton coupe:
Fxt trans 4.44
Wrx 12lbs flywheel
2.5rs rear LSD 4.44
02+ brakes all around
2.5rs body bits
9something legacy turbo trans crossmemeber
Sti 5 speed short shifter w/ linkage kit
Hydraulic hand brake
225/65/16 snowtires
WRXbrother is offline   Reply With Quote
Old 09-21-2011, 12:54 PM   #27
Member#: 141182
96 Impreza Coupe
After reading this whole thread, it feels like AA for swapped Subaru owners
"Hi, I'm Scott, I've been swapped for two years. But I still have thoughts of swapping again"...
Old 10-17-2011, 07:36 AM   #28
Member#: 153412
1998 Impreza wrxRS
Lol with u on that
subieguy87 is offline   Reply With Quote
Old 11-22-2011, 03:16 PM   #29
Member#: 98777
Just finished my swap.
2002 WRX EJ205 into 1998 Legacy GT wagon.
Notes: (I'll add to this)
-I used the stock LGT 5 speed transmission. I used a clutch disc, plate and flywheel from a 2006 WRX
-Wiring was done by iWire. Brand new OEM bulkhead harness from the Legacy, complete donor chassis harness
-Taking the dashboard out sucks. Label everything. Every screw, every connector. You don't want to put it all back together and realize you missed a plug. Twice.
-I used a first generation Legacy turbo crossmember. The engine will sit higher than it does in the WRX engine bay. This is ok. The hood closes.
-I used the factory Legacy throttle cable (DOHC) and bent the WRX throttle cable bracket slightly so the cable would reach.
-I did not hook up the cruise control. Hopefully I wont miss it. The engine bay is cluttered enough.
-Relocate the PS pump reservoir. Easy enough.
-To retain the factory MAFS and airbox, I used the lower half of the Legacy air box, and the upper half of the WRX box.
-I had originally tried the "hack" method for the coolant lines. I cut the spring out of the radiator cap, added a second seal, but could never get it to completely seal. I ended up deleting the waterbox by the intake manifold. Just run a section of hose from the turbo water pipe to the crossover pipe, and set the radiator up like normal. So far so good.
-Invest in plenty of zip ties and assorted sizes and lengths of rubber hoses and clamps.
-The engine bay gets tight. A set of slim fans might help with clearance up front.
-My TMIC fit without any modification to the engine bay. However, to use the duct for the hood scoop, you'll need to cut and drill to get it to fit.
-Burp your cooling system afterwards. Theres a step by step procedure somewhere on a forum.
-I haven't installed the AC condensor and lines yet. I have all winter to procrastinate.
Oh yeah, and of course it was totally worth it. PM me if you have any questions. This job will be burned in my memory for a while.
Subachouli is offline   Reply With Quote
Old 11-23-2011, 01:23 AM   #30
Member#: 204358
01 2.5RS W/ EJ257
It's thread like this that make me love subaru.
DHRDAN is offline   Reply With Quote
Old 11-26-2011, 03:53 AM   #31
Member#: 200463
2000 2.5 swaped obs
so i guess this is and old and short thread but heres what i did....
2000 obs with 2.2, i hydrolocked the motor being a retard so i decided to swap to a 2.5 n/a motor form a 2000 rs. All i did was swap intakes, drivers cam gear and, crank gear. it ran like crap for about 20 miles until the ecu learned how to run the motor 2 years later its running like a champ
nickmicho is offline   Reply With Quote
Old 11-28-2011, 08:34 PM   #32
sense of nature
Member#: 112759
2002 STi Mikey Tuned
Here's one of mine
My currant project is a 98LGT swap w/ a 02 Wrx
sense of nature is offline   Reply With Quote
Old 11-28-2011, 09:37 PM   #33
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
91 Legacy SS automatic with 06 Impreza-i SOHC heads & converted to manual 06 Impreza-i transmission
Sadly I sold the car before it was running 100% perfect because I had like $1500 invested with the purchase of the car an parts. Then found that it was not going to be tuneable unless run on stand alone management, witch would basically more have doubled the cost.
It ran great when in boost but at idle and low RPM it was ragged and pig rich.
Full Story Here:
I also currently own a 02 Impreza RS with a 04 STi swap
Full Story Here:
I lost my 97 OBS with 02 WRX swap last year in Oct..... but I did not do that swap.....bought it already done
dangerousatom is offline   Reply With Quote
Old 11-29-2012, 11:02 PM   #34
Dori Ninja
Member#: 73974
04 RSTi
i guess ill chime in...
06 WRX EJ255 into a 00RS..
did the full drive line with interior swap as well so used about 90% of the WRX harness and just had to re wire the fuel pump tail lights doors and sunroof/dome/map lights... wasnt too bad though fairly straight forward if u have access to the wiring diagrams...need to tweak a couple things like my dash beam and then clean everything up yet, but functionally i am good to go!!! lots of mods on her too...plus she will be flared and painted up shortly as well
the hood is off of my DD which is Sedona Red Perl...i traded my hood from this car for an L hood as i have a front mount that just needs the piping tweaked and then ill be rockin a 9K vent
Dori Ninja is offline   Reply With Quote
Old 12-03-2012, 12:28 AM   #35
Member#: 211224
2005 Saabaru
Who knows
Dam I thought I had a problem, But then read about your guys swap stories. Kidding!
Here goes my list
1996 gf wagon
w/ a 2005 wrx wire merged ecu ( did myself and that was fun)
01 ra geared rs trans 4.11
full wrx subframes and brakes
kw v1s
and ran 11.8 1/4 miles
Next is my 05 fxt
has a v9 jdm 2.0 and full 6 speed swap
on 255/45/17 17x9s
has a 32 bit ecu!
currently on winter setup
before winter mode
btw thats a 2" hit on the back
and lastly
MY99 gc 4 door coupe
has a ej257 modded to run avcs on a 16bit jdm ecu
has a 05 lgt box in it with full 02 wrx interior swap
This is another great sleeper of mine.
bumper has been fixed since this picture
amroof is offline   Reply With Quote
Old 01-22-2013, 06:16 PM   #36
Member#: 291684
2004 Rs (Wrx Swap)
San Remo Red
Kevin T
(17 y/o)
2004 2.5 rs.... San Remo Red
02wrx ej205 (everything needed to get this in came from the WRX donor car)
full 02 wrx harness along with anything that is hooked up to the harness (including airbags)
Turbo xs uppipe
Nameless downpipe
xtp stage 2 tune
Silicon turbo inlet
3" catback (it changes a lot)
04rs trans 4.11 final drive
04rs rear diff.
Act street disk
Act pressure plate for a 4puck ceramic kit
Short throw shift kit
Stock wrx struts
Eibach 22mm f/r swaybar kit
HD endlinks
02 wrx ront brakes (rears will be replaced when the RS ones go bad)
Aftermarket Trailing arms
Whiteline Steering rack bushings.
Full 02 wrx interior
04 rs gauge cluster (keep the mileage the same)
Glowshift boost gauge ($15 special)
Pioneer DEH-P5800mp headunit
PSM 04 sti hood w/04wrx hoodscoop. (hard to find SSR wrx hoods)
KevinT. is offline   Reply With Quote
Old 02-18-2013, 06:24 PM   #37
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
There are some nice swaps in here
arco is offline   Reply With Quote
Auto to Manual conversion successful! PaulN Transmission (AT/MT) & Driveline 6 04-19-2009 12:08 PM
Rear disk conversion/diff conversion the mike Subaru Conversions 5 12-19-2004 08:50 AM
'95 L Steering Pump Repair - Conversion to MY00 Pump Resevoir: Success!!! Kostamojen Subaru Conversions 4 06-27-2003 04:23 AM
WRX Front Rotor Conversion and Legacy Rear Rotor Conversion on a 01RS? RS_NW Brakes, Steering & Suspension 4 08-09-2002 09:34 PM
Poll: What type of board or boards do you ride & what would your next purchase be? breaka19 New England Impreza Club Forum -- NESIC 21 10-09-2000 09:02 AM
