Welcome to the North American Subaru Impreza Owners Club Saturday February 13, 2016
Old 12-02-2012, 11:21 PM   #1
gustavito63007
Member#: 309439
2006 Impreza 2.5i
Default Alignment problem???
I just had my front sway bar links and bushings replaced, new tires, than got my alignment. Car pulls to the right, if going like 70mph pulls considerably. The print out showed everything was in alignment. The steering also seems little more loose. Could it be the new tires needing to be kind of broken in? Or from somewhere I read, maybe the toe is still outa wack? Thanks for you help !
gustavito63007 is offline   Reply With Quote
Old 12-03-2012, 12:03 AM   #2
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Alignment is probably not right.
Can you show us the alignment sheet?
Where was it done, a chain tire/ sears type place?
Bikelok is offline   Reply With Quote
Old 12-03-2012, 12:12 AM   #3
gustavito63007
Member#: 309439
2006 Impreza 2.5i
Town fair tire..
Old 12-03-2012, 12:14 AM   #4
leecea
Member#: 37359
2003 WRX
Sounds like you mean, if you take your hands of the wheel, the car starts moving to the right.
If the alignment is not an issue, check tire pressures. Did you change from a generic type tire to a performance tire? Some will follow road irregularities much more - it's called tramlining - and road camber can also effect them more. Shouldn't be as bad as you describe though.
leecea is offline   Reply With Quote
Old 12-03-2012, 12:28 AM   #5
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
bad tire.....likley
Old 12-03-2012, 04:53 AM   #6
gustavito63007
Member#: 309439
2006 Impreza 2.5i
No just got regular a/s tires. The tire pressures are spot on. To pulls on new smooth tarmac on the highway that was redone about 2 months ago, and pulls the same on the regular highways, that are much older.
Old 12-03-2012, 07:05 AM   #7
Uncle Scotty
OK buy Nates beans
post the alignment printout
and if you have a bad tire it can make it pull
Old 12-03-2012, 08:59 AM   #8
gustavito63007
Member#: 309439
2006 Impreza 2.5i
I will post it up tonight and my tires are maybe 100 miles old and I know that doesn't mean that I couldn't have a bad tire
Old 12-03-2012, 12:12 PM   #9
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Could be bad tires or alignment. Even if the alignment sheet says everything is good it doesn't mean there wasn't a problem with the procedure that can cause the car to drive poorly. You could swap the front tires and see if the car pulls the other direction. Otherwise I would take it back to them.
Tony
Old 12-03-2012, 08:22 PM   #10
gustavito63007
Member#: 309439
2006 Impreza 2.5i
Well tomorrow I'm going to have my sway bar links and bushings doubled checked and tightened, rebalance the wheels than redo the Alignment.
