Old 11-29-2012, 10:18 PM   #1
666pack
Member#: 339296
2006 WRX STI
Steel grey
Default How can I tell if my car is tuned or not...
stupid question.
first subaru i bought from a dealer. 2011 wrx. The dealer sold it to me cert preowned with an invidia down and borla cat back exhaust. Id like to know if its tuned or not, seems like they were unsure while answering. whats the easiest way to find out.
my apologies for posting, i come from vw roots so cobb tuning etc is new to me.
666pack is offline   Reply With Quote
Old 11-29-2012, 10:21 PM   #2
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
Hello and welcome! Hmm, your car is probably tuned. But I'd buy an Accessport or something to be on the safe side. Pay attention for over boosting. Good luck getting answers from the pros!
Navendra94 is offline   Reply With Quote
Old 11-29-2012, 10:24 PM   #3
666pack
Member#: 339296
2006 WRX STI
Steel grey
is there a way i can check? if it is awesome, if its not ill def buy one.
Old 11-29-2012, 10:26 PM   #4
RoadKillDMD
Member#: 284792
2011 STI
Blurple
If your car runs, it is definitely tuned
On a serious note, no your car probably isn't tuned for those mods. Being 'certified pre-owned', the dealership would have most likely flashed the ECU back to the stock map when they were prepping it for resale. I would take your car to get tuned or at least get a Cobb AP and flash stage 2.
RoadKillDMD is offline   Reply With Quote
Old 11-29-2012, 10:31 PM   #5
666pack
Member#: 339296
2006 WRX STI
Steel grey
im going to have to do research....i mean...it feels tuned haha. I feel like its running slightly rich. not throwing any codes at all tho.
Old 11-29-2012, 10:38 PM   #6
Shohin
Member#: 170188
2016 STI Limited
I'm no expert, but how can the car be "Certified" with aftermarket parts? Because technically, now those parts are covered under warranty.
Shohin is offline   Reply With Quote
Old 11-29-2012, 10:40 PM   #7
Wikki
Member#: 331744
2006 Subaru WRX
I had the same issue but my wasn't boosting to its ill potential thank goodness... But I would take it to either a tune shop and see if they can check for a tune for you they may charge I dunno or definitely go with the Cobb ap... You won't regret it
Wikki is offline   Reply With Quote
Old 11-29-2012, 10:47 PM   #8
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
...can't the stealership check the checksum to see if it's a stock tune or not?
Old 11-30-2012, 12:22 AM   #9
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
No CEL's means it's most likely tuned. Even a catted downpipe will likely throw a CEL unless there's a mechanical fix. I'd definately find someone with tuning software and do some logs to find out.
Old 11-30-2012, 12:59 AM   #10
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
This is a perfect example of why newbies are asked to fill out their profiles. If you tell NASIOC what part of the world you're from, someone from that part of the world will eventually post and say, "hey dude! I can help! I live/work/panhandle just down the street from you."
Moral of the story...fill out your profile...newbie.
And welcome to the forum.
Gallo2011 is offline   Reply With Quote
Old 11-30-2012, 01:09 AM   #11
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Find someone with a tactrix cable near you.
Driving it you won't be able to tell whether it's tuned or not.
Jubert69 is offline   Reply With Quote
Old 11-30-2012, 02:17 AM   #12
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
If it is tuned you're likely not tuned with an Access Port, because the previous owner (unless he is an idiot) would have unmarried his AP before selling the car which would have deleted the tune. The next likely option if it is tuned is that it is tuned with open source. You can easily check this by finding someone in your area with a tactrix cable (as said above) and having them pull your map and comparing it to your stock map which you can find on the forums on the romraider site.
Oh, and please fill out your profile.
OUScooby is offline   Reply With Quote
Old 11-30-2012, 02:32 AM   #13
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Don't even need to pull the map. Just do a learning view check and post a screenshot. Looking at the timing tables people here will be able to tell.
Old 11-30-2012, 02:44 AM   #14
sc00by4life
Member#: 97135
No they aren't.
Old 11-30-2012, 06:39 AM   #15
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Fill out profile. That's step one.
You won't be able to "feel" if it's tuned, it makes no difference. Like Drew pointed out, no CEL might be a good indication something has tuned it. Best bet is find a local tuner (hence filling out your profile) and take it to them ASAP. And until you know something, I would baby that car.
Old 11-30-2012, 08:12 AM   #16
666pack
Member#: 339296
2006 WRX STI
Steel grey
profile fixed.
anyone know of resources in DE?
Old 11-30-2012, 08:24 AM   #17
crfnick56
Member#: 329410
2003 bugeye wagon
Sonic Yellow
I work at a dealer in parts and I was always under the impression that "certified" meant that the car had to go back to factory parts? My dealer here has even gone as far as taking out K&N filters to replace with OEM Subaru air filters so to certify a car with turboback exhaust baffles me
crfnick56 is offline   Reply With Quote
Old 11-30-2012, 10:06 AM   #18
NoGraffix
Member#: 276209
I am Rub
Function>Form
Originally Posted by 666pack View Post
stupid question.
The only way to know if it's tuned 100% is if you have someone pull the map and compare the tables to a stock map. If you aren't throwing a CEL for the aftermarket down pipe it likely has some sort of modification to the stock tune for it, even if that is only shutting the code off .
At this point what you need to do is find a local with a tactrix cable, purchase a stage 2 map from TP, and get that loaded (or you can buy an AP and do the same, but I prefer OS so I'm impartial hah). There is absolutely no way I'd ever trust an unknown tune on my car, it's simply not worth the risk.
NoGraffix is offline   Reply With Quote
Old 11-30-2012, 11:46 AM   #19
RM_2
Member#: 163058
'16 BRZ Limited WRB
'06 Saab 9-2X 2.5i NGM
Downpipe - Yeah, you'll need a tune for that. You should get that all checked out otherwise...bad things could happen. Since you already have a DP, you might already be denied for powertrain related warranty work.
RM_2 is offline   Reply With Quote
Old 11-30-2012, 01:41 PM   #20
Shohin
Member#: 170188
2016 STI Limited
This.
Originally Posted by sc00by4life View Post
No they aren't.
I realize that they shouldn't be covered, but if a dealer "Certified" a car, then that car is covered under the "Certified" warranty in the state in which it was "certified" . . . in this case then, with aftermarket parts. I've dealt with MANY a certified car and this is exactly how it works with most (if not all) other manufacturers.
Old 11-30-2012, 01:53 PM   #21
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
The dealer violated his agreement to thoroughly inspect and bring the car into compliance for Subaru certification. While the dealer may think he sold you a certified car, if you go to another dealer, you're likely going to get an "I'm sorry, there's nothing we can do to your modified car".
And if that downpipe doesn't have a cat in it, the dealer violated federal law and is subject to a $10,000 fine.
Personally, I'd bring it to the attention of SOA. At the very least, the dealer is very sloppy.
Old 11-30-2012, 03:27 PM   #22
SpamBot
Member#: 287534
If the dealer sold you that car as a Certified vehicle with no catalytic converter, the car never should have been sold. As Jack mentioned, it's against Federal law.
If the car has been tuned and he sold it as a Certified car, you may be in for a surprise if you have to bring it to another dealer for a warranty claim. The claim coverage could be denied, and your VIN flagged (if it hasn't been already).
I would seriously consider asking the dealer for a refund, and return the car, unless you aren't at all concerned about any of this.
SpamBot is offline   Reply With Quote
Old 12-03-2012, 01:35 PM   #23
dvrmstrng
Member#: 274717
2011 WRX TP Stg2+
His car has a catted Invidia DP..
dvrmstrng is offline   Reply With Quote
Old 12-03-2012, 04:01 PM   #24
MaddMax
Member#: 9264
2016 BMW M235i 6MT
^This.
Old 03-09-2013, 05:51 PM   #25
jedimastere
Member#: 346981
Default I'm in the same predicament.
Hello Nasioc!
Sorry to bump an old thread, but I was searching because I'm in the same boat right now as a potential buyer of a 2011 WRX.
upon inspection of the car today along with my dad who's a certified mechanic, we saw that the intake and turboback exhaust was modified. there was even a Grimmspeed turbo shield on it.
I'm in question whether the car has a tune or not because I know from searching on this resourceful site, that cars WRX with this type of modifications MUST be tuned to run properly. There was no CEL, it ran fine, but my father wasn't sure he liked the way the lifters were ticking. That's what he said. We're going to head back up there sometime tomorrow to test drive a brand new WRX to see any differences.
I have a friend who has an AP, but it's for his MS3. So i'm not sure how that will work out lol.
I really just wanted some form of input from the community on the situation. here's the VIN if anyone has a way of looking something up for me, as i am new to Subaru. JF1GV7E64BG509109 and the site the car can be looked at is.....
http://www.chryslerjeepofnorthbrowar...FL/vd/13688463
I'm interested in a Subaru because of the reliability, low theft rate, high re-sale value, and because it just looks more mature for my taste. Thank you for any input. I greatly appreciate it.
jedimastere is offline   Reply With Quote
