| View Poll Results: How often do you cahnge your synth oil? | |||
| 1-3k |
1 | 0.60% |
| 3k every time |
84 | 50.60% |
| 5k |
58 | 34.94% |
| 5-10k |
23 | 13.86% |
| Voters: 166. You may not vote on this poll | |||
#51 |
Member#: 21866
Vehicle:2002 WRX Silver 13.82 1/4 Almost Stock |
I have been anywhere from 3 to 7000k between changes...
I have never noticed any loss of oil whatsoever in using dyno or synth.... It always stays exactly at the same level on the dipstick.....and thats for 41k miles now...go figure... And i have never driven my car any other way but FAST ![]()
#52 |
Member#: 161335
Around 10-15K....
Used to be M1 0w-40 until that changed, now Shell Rotella T6 5w-40. I have to add a quart every thousand or so (prob. need a turbo rebuild), but so far so good. Make sure you have very high quality filters if you go this route... Livin' on the edge ![]() |
#53 |
Member#: 89628
Vehicle:'02 Wagon VF39'd & Quick Racked |
Wow.
#54 |
Member#: 87067
AKIC
Vehicle:02 Old but tasty SRP |
8-10k with labs. No adding. RT6/ purolator filter. Every motor is different. Do your own research...or dont.
#55 |
Member#: 120273
SWIC
Vehicle:06 WRBWRXWGN Now with 100% more Spec-C |
I generally burn/leak so much oil that I only ever need to fill the car. It changes itself automatically. It's what makes a Subaru, a Subaru.
#56 |
Member#: 316415
Vehicle:2006 WRX WRB |
^^^ sigh
#57 |
Member#: 329025
SWIC
Vehicle:2002 WRX Wagon Aspen White |
I think anyone who changes every 3K without having their oil analyzed is wasting money. Blackstone charges $30 to do an analysis. Just pull a sample every 3K and have it analyzed. I think most will find they can go up to a year between changes if they're using a good synthetic.
#58 | |
Member#: 170906
South East
Vehicle:2002 WRX psm |
At 3k I start thinking about it, and it's done somewhere between there and 4k every time. Sure the oil likely has some more life, but they recycle it nowadays at least and that's not a whole lot of miles from what's recommended by the MFG. Having said that I will also occasionally get a UOA from Blackstone, but it's a health check. |
#59 |
Member#: 122043
MWSOC
Vehicle:04 wagonier psm |
6-8k. On amsoil
| Thread Tools | |
| Display Modes | |
| How often do you change your oil?... | Hazdaz | Off-Topic | 56 | 04-02-2007 06:37 PM |
| How often do you change your oil? | wyn525i | Off-Topic | 58 | 12-23-2006 01:08 PM |
| How often do you change your oil? | Chris51080 | Service & Maintenance | 14 | 04-23-2003 07:52 AM |
| How often do you change engine oil with synthetic oil? | malelee21 | Service & Maintenance | 53 | 04-14-2002 10:33 AM |
| Newby question, how often do you change your oil? | SteveGood | Factory 2.0L Turbo Powertrain | 2 | 09-21-2001 02:53 PM |
