Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 12-02-2012, 11:59 PM   #1
HawkEyeDelight
Member#: 312052
Default HELP High Oil Pressure
So i have an 06 wrx which is stage 2 and has Prosport gauges, well when i bought the car my oil pressure gauge was not working (before starting the car it would read 100 psi and never moved ever) and was dripping a miniscule amount of oil from the sender unit. I finally got some money and decided to fix it so i got a new sender unit, filter and rotella t6 oil 5w40. Well once the car is fully warmed up its at like 30 psi at idle and the second i start to drive it jumps to 100 psi and never fluctuates. Please someone help me!!!
HawkEyeDelight is offline   Reply With Quote
Old 12-03-2012, 02:25 AM   #2
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Sounds bout right
Coreycarlile911 is offline   Reply With Quote
Old 12-03-2012, 07:19 AM   #3
git_sum
Member#: 303339
2006 Saab 9-2x
Red
mine runs around 70 while it's cold or i'm driving and around 30 when it's warm and i stop at a light or something...
git_sum is offline   Reply With Quote
Old 12-03-2012, 10:15 AM   #4
car_freak85
Member#: 13530
EA63 , EA81T, EG33,
EJ205
This is normal. Pressure is high on startup or while driving. If it goes above 100 or 120 psi, there is a bypass inside the oil pump.
Relax, you're fine.
car_freak85 is offline   Reply With Quote
Old 12-03-2012, 05:59 PM   #5
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Normal. My 06 with RT6- 110-115 when cold, 95 under cruise when hot, 30 at idle when hot.
mechatricity is offline   Reply With Quote
Old 12-03-2012, 08:33 PM   #6
HawkEyeDelight
Member#: 312052
Thanks alot guys, I saw a bunch of posts with people saying 20 pounds at idle and like 50-60 pounds cruising so when I saw 100 pounds on the high way I freaked
Old 12-03-2012, 08:38 PM   #7
HawkEyeDelight
Member#: 312052
So I know I'm probably just being paranoid but your getting 70 while driving and 30 at idle, but I'm running 100 while driving no matter how low the rpms. Sorry if I'm asking too much just don't want to blow my seals or something.
Old 12-03-2012, 08:51 PM   #8
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
100+psi is normal when your foot is anywhere on the gas psi. Idle should be anywhere from 30ish-50psi depending on oil temp/viscosity/new-old oil/motors warm or cold.
Different pumps sizes make different oil presure too.
-10mm is usually just under 100psi
-11mm the WRX standard pump is around 100+psi
-12mm JDM type is 110-115+psi
All of their pressures drop down to 30-50 like mentioned above
dangerousatom is offline   Reply With Quote
Old 12-03-2012, 09:12 PM   #9
HawkEyeDelight
Member#: 312052
Thank you so much I was deffinatly worried about it but you guys saved the day gotta love nasioc for this kind of stuff
