Old 11-21-2012, 10:12 PM   #1
tuzzio
Member#: 292532
05 STI
Default Defi sender connector.
So, long story short. My oil pressure sender is shorting out, due to a wire or two pulling out of the connector that plugs into the controller. I figure if I could find a place that has these with some wires plugged in, I could just splice them in correct? Does this such thing occur, or do i need to just buy a sender? Its for the old style defi controller.
tuzzio is offline   Reply With Quote
Old 12-01-2012, 12:26 AM   #2
181stLeader
Member#: 184183
1996 Impreza RSTi
V8 EJ207 Aerosim Carbon
I have used the gauge daisy chain harnesses to fix plugs on the BF series Defi's. All you have to do is cut & file down the connector till it fits in the socket, then splice the wires in to the sensor. It still retains about a 1/3 of the clip on the top of the connector so it still clips in like normal. This will be a lot less $ than buying a new sensor.
181stLeader is offline   Reply With Quote
Old 12-03-2012, 11:14 AM   #3
tuzzio
Member#: 292532
05 STI
Hmmm. I looked at the daisy chain connecter, and realized that it wouldn't fit... Never thought of that. Thanks!
Old 12-03-2012, 09:08 PM   #4
tuzzio
Member#: 292532
05 STI
Just did it. Little more tedious then I thought. Those connectors are a little more fragile then I thought. Test it out tomorrow
