Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 10-29-2012, 10:47 PM   #1601
gtasti
Member#: 152036
2004 Sti
Originally Posted by mxer254 View Post
with how much fuel? last time my 04 wrx was on the scales it came in at 2973 with a 1/4 tank of fuel without me in it
SS headers going on soon...
Just over 1/2 tank
And yea remember mine is the sti
gtasti is offline   Reply With Quote
Old 10-30-2012, 09:34 PM   #1602
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
11.9@117 dd
bump for new ideas, Im already sub 2800 with the seats in
Str8Gone is offline   Reply With Quote
Old 10-30-2012, 09:47 PM   #1603
sc00by4life
Member#: 97135
Originally Posted by tuzzio View Post
Don't forget the longer axles, and that stupid wing.
uh? maybe comparing a sedan to a wagon......
Old 11-12-2012, 08:34 PM   #1604
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
So after spending money for my crash beam, i find this. Thought I share.
http://www.amsperformance.com/cart/a...crash-bar.html
bue car is offline   Reply With Quote
Old 11-12-2012, 10:10 PM   #1605
gtasti
Member#: 152036
2004 Sti
Im sure urs didn't cost 120 bucks tho
Old 11-12-2012, 11:46 PM   #1606
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
that is where you are wrong unfortunately
Old 11-13-2012, 09:19 PM   #1607
b3delta
Member#: 242814
Midnight Black Pearl
for those who removed the fron bumper beam, how did you reattach the bumper? all the popits plug into the beam so whats holding ur bumper on?
b3delta is offline   Reply With Quote
Old 11-14-2012, 12:10 AM   #1608
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
My aftermarket one does not.
Old 11-14-2012, 02:26 AM   #1609
dub c
Member#: 145069
Keep It Sleazy
^Dont they?
I have a Turbo XS (I think) FMIC bracket to hold my bumper up.
It's made from sheet aluminum and has tabs for the popit plug's you speak of.
dub c is offline   Reply With Quote
Old 11-14-2012, 11:10 AM   #1610
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
I guess you are right.
Old 11-14-2012, 05:14 PM   #1611
b3delta
Member#: 242814
on the 03 WRX, you pull off the one piece grill and the two small pieces that cover the headlight mounts. there are 6 or seven popits that connect to the top of the crash beam, holding the bumper cover on, with the stock USDM beam removed, there is no way to attach the bumper cover except for the popits in the wheel well.
Looking down on the beam as if it is attached to the car you can see the holes
Old 11-14-2012, 05:21 PM   #1612
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
Hmm I guess you are right, my bumper does not connect there anymore.
Old 11-14-2012, 06:32 PM   #1613
crotchbuffet
Member#: 205324
2002 Impreza wrx
midnight blue pearl
i have the ams beam on my bugeye. i just didnt use any of those plugs in the middle. its attached by the two points at either edge of the bumper by the wheels and the four plugs that attach to the pieces between the grill and the headlights
crotchbuffet is offline   Reply With Quote
Old 11-14-2012, 08:01 PM   #1614
b3delta
Member#: 242814
yeh my wheel well liners are cracked and broke so im trying to see if theres some way to rig it up without the beam and just2 plugs
Old 11-21-2012, 09:35 PM   #1615
DamnThatRevLimiter
Member#: 174294
02 WRX , 2013 FXT
VF30 Stage 8 billion
Found this to read it has some related material.
http://www.rs25.com/forums/f145/t837...ly-driver.html
DamnThatRevLimiter is offline   Reply With Quote
Old 11-21-2012, 09:40 PM   #1616
DamnThatRevLimiter
Member#: 174294
02 WRX , 2013 FXT
Old 11-21-2012, 09:46 PM   #1617
DamnThatRevLimiter
Member#: 174294
02 WRX , 2013 FXT
This one Gain weight,but is way more stiff compared to stock. Note the part about "Glue"
http://www.modified.com/features/061...z/viewall.html
Old 11-21-2012, 09:50 PM   #1618
DamnThatRevLimiter
Member#: 174294
02 WRX , 2013 FXT
And here is the last of the three from opera, and for me this was the best.
http://www.modified.com/features/061...0/viewall.html
Old 12-04-2012, 02:27 PM   #1619
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Originally Posted by RRR View Post
What a thread.. Inspired, Ive read the whole thing now (took 1 month, gave me 2 pages of work to do ).
Anyways, there is so much fuzz on these bumper beams, and for the record these appear to be USDM only. European cars dont have them as far as I can tell, checked 2 now (GD).
Anyone with the windscreen washer fluid in the trunk? How do you route it? I suppose the intercooler spray line would work, but I dont have that....
Im quite worried about wheight distribution. These things are 60/40 stock, and 3/4 of the wheight removed in this thread appear to go from the rear... Good excuse for keeping that big rear wing though. Ill also go for the battery in the trunk, I feel those extra oz of wire is worth the slightly better distribution.
I relocated the reservoir to the rear, its pretty straight forward.
Coilovers will be the money maker in weight distribution. You can adjust ride height to shift weight, I highly recommend it if you're serious.
On the M3 I went from a 50/50 stock distribution sitting at 3420 lbs to 2980 and a 49/51 split. Before I added Coilovers I was around a 56/44 split. Those Coilovers did good!
u2_m4r1n3 is offline   Reply With Quote
Old 12-30-2012, 01:07 AM   #1620
dribbler
Member#: 310371
007 Subanger
What about seats? how much lighter would Corbeau's or Bride's be?
dribbler is offline   Reply With Quote
Old 12-30-2012, 02:34 AM   #1621
MOST 'good' coilovers---the ones with stainless bodies... are only a couple pounds each...think less than 5...lighter than a strut/spring
the BEST way to save weight on the front of the car is...
battery
'U' brace
lw wheels/tires
'gbod'
lw crank pulley
lw bumper beam
the above will take an EASY #125 off the front of the car...forget struts
and all the other misc things that add up to an easy #20
and i see a lot of people doing a lot of real stupid things to these cars in this thread....quite shocking, really
Old 12-30-2012, 12:39 PM   #1622
dribbler
Member#: 310371
007 Subanger
what exactly are these green brackets? of death... and u-brace?
Old 12-30-2012, 12:46 PM   #1623
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Use google for gbod pics, they're basically a piece of metal that covers the fuel injectors. They are a MASSIVE pain in the dick to remove.
The U brace is a large piece of metal, shaped like a U, under the front of the car. It has your front tie down points on it and is basically only there for that and additional crash safety.
Old 12-30-2012, 01:26 PM   #1624
dribbler
Member#: 310371
007 Subanger
nm....
Old 12-30-2012, 03:00 PM   #1625
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Here is some info which may help some..
Some research I did suggests that the R180 in an '07 Sti is heavier than the R180 in an '06 Sti, possibly adding as much as 20 lb.
This is because the '07 has a torsen limited slip locker, while the '06 has a mechanical, clutch-style locker.
Since the weight difference is rotating mass, it's effects may be equivalent to more than 20lb of weight savings.
A theory I have, which is not verified yet, is that the '06 and '07 6 speed transmissions are heavier than the '04-'05 by quite an amount.
I don't really know what it is, I am thinking it may be 40 lb.
This has to do with the center differential. The '06-'07 have an additional torsen locker, again rotating mass.
FIY, for the JDM cars, the years and nature of diff changes were the same as US. However, for the Spec C, they never went to rear Torsen, although they did so for Sti. I never looked into the center torsen for spec C, but I can look into it.
If you're looking for reliable, low mileage swaps, the JDM swap places usually have low mileage items. However the JDM 6 speed have shorter 5th and 6th.
They always have the same final ratios as the same year USDM Sti.
Total weight reduction or F/R weight distribution more valuable? soslow General Community 17 12-11-2007 01:40 AM
('93-'01) Weight Reduction Questions subarumantoo Impreza Forum 5 05-01-2001 12:02 PM
Some interesting facts about weight reduction Imprezer WRX Forum Archive 5 02-25-2001 11:33 PM
2.5RS Weight Reduction info and questions. Frank General Forum Archive 21 02-16-2001 01:53 AM
