Old 12-04-2012, 01:43 PM   #1
avikm289
Member#: 315748
2012 wrx
White pearl
Default Is this normal?
I installed sti brembos on my 2012 wrx, along with dba 4000 slotted rotors, ss brake lines, a grimspeed master cylinder brace as well as a beak fluid flush with the blue dot 4 fluid a few days ago. I notice when I brake heavy on highway speeds the rear end wants to swing left and twists a lil. Is that normal? Will chassis bracing help or sway bars? Or did I do something wrong
avikm289 is offline   Reply With Quote
Old 12-04-2012, 01:51 PM   #2
Badler
Member#: 133597
Not normal. New or used?
Badler is online now   Reply With Quote
Old 12-04-2012, 02:05 PM   #3
avikm289
Member#: 315748
2012 wrx
White pearl
Used brembos, powder coated and rebuilt before install
Old 12-04-2012, 02:15 PM   #4
Badler
Member#: 133597
It sounds like the back right one isn't working.
Old 12-04-2012, 02:24 PM   #5
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Or the right front.
Bacon117 is offline   Reply With Quote
Old 12-04-2012, 02:28 PM   #6
chapstien
Member#: 68284
1988 Corolla SR5
0-points
Or an alignment issue.
chapstien is offline   Reply With Quote
Old 12-04-2012, 02:30 PM   #7
avikm289
Member#: 315748
2012 wrx
White pearl
The brakes feel great, I bled them all and fluid came through both nozzles on each caliper. This only occurs when I almost literally slam the brakes at around 70is, but under regular braking it works beautiful. If I slam the brakes around 30-40 it doesn't kick out. When it kicks out the tail kicks out a lil to the left
Old 12-04-2012, 02:33 PM   #8
Badler
Member#: 133597
Check this then.
Old 12-04-2012, 02:35 PM   #9
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Ok, so does the car want to turn to the left or turn to the right? "kicks out to the left" is a little ambiguous.
Check tire pressure.
If the car didn't do it, you replaced the brakes, now it does, chances are something went wrong with the installation. Did you bed the brakes properly?
Old 12-04-2012, 02:38 PM   #10
avikm289
Member#: 315748
2012 wrx
White pearl
Talking about the alignment issue, I had one a few months show when my coilover camber was set too negative on the front left, as it ate alot of the inner wall of the tire, almost no grooves on the tread. I put that tire on the back left it just so happens. Maybe a connection?
Old 12-04-2012, 02:40 PM   #11
avikm289
Member#: 315748
2012 wrx
White pearl
I used that blue dot 4 fluid to bleed it. When I say kick out, it's like it wants to spin out but it's controllable if I let of the brakes. It's not agressivly violent, but you feel and see the bak swerve out a lik
Old 12-04-2012, 02:40 PM   #12
avikm289
Member#: 315748
2012 wrx
White pearl
Btw thanks for the responce fellas
Old 12-04-2012, 02:47 PM   #13
avikm289
Member#: 315748
2012 wrx
White pearl
That's what I wanna see, I put bigger brakes, slotted rotors, steel lines and a master cylinder brace so braking is much batter than the old 2 piston front and 1 piston rear. First time with "fully" upgraded brakes
Old 12-04-2012, 02:52 PM   #14
Badler
Member#: 133597
Are you sure one of them isn't seized? Did you rebuild them yourself?
Old 12-04-2012, 03:02 PM   #15
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Yes, it really sounds like one of the brakes isn't doing the same work as the others. It might be time to take it to a professional to diagnose...
Old 12-04-2012, 03:13 PM   #16
avikm289
Member#: 315748
2012 wrx
White pearl
I gt the Machspeed rebuild kit and had a vendor on here rebuild them for me along with the powder coat. I sprayed brake cleaner on all calipers from the outside of the wheel so ill let it sit. If a pistons stuck how can I clear it? Fluid comes out all calipers on both ends, I bled them myself. Should I re-bleed?
Old 12-04-2012, 03:17 PM   #17
Badler
Member#: 133597
Bleeding isn't the problem. You can bleed a stuck caliper. Check the slide pins.
I hope you didn't really just blast your freshly PCd calipers with brake cleaner?
Old 12-04-2012, 03:20 PM   #18
avikm289
Member#: 315748
2012 wrx
White pearl
I just did
Old 12-04-2012, 03:21 PM   #19
avikm289
Member#: 315748
2012 wrx
White pearl
The front has brand new from dealer slider pins and retainer, but I re used the rears
Old 12-04-2012, 03:27 PM   #20
Badler
Member#: 133597
Grease the rear slide pins. Doesn't take much.
Chances are you're fine with the cleaner, it's just not something I would do.
Old 12-04-2012, 03:40 PM   #21
avikm289
Member#: 315748
2012 wrx
White pearl
Uploaded with ImageShack.us
just for ref, this is my rear left tire. had a bad camber in the front and i swapped it to the back
Old 12-04-2012, 03:41 PM   #22
avikm289
Member#: 315748
2012 wrx
White pearl
id buy you lunch if you were near me
Old 12-04-2012, 03:43 PM   #23
Badler
Member#: 133597
It also had some bad toe to do that. That wouldn't cause what you're describing.
Old 12-04-2012, 04:56 PM   #24
avikm289
Member#: 315748
2012 wrx
White pearl
I was hoping it would have I make it simpler, but modding is never simple. Ill grease up all caliper pins, and if it continues ill re-bleed
Old 12-04-2012, 04:57 PM   #25
avikm289
Member#: 315748
2012 wrx
White pearl
Also when I tap the brakes to stop I hear like a clicking/knocking sound from the front right every tap
