| View Poll Results: How often do you clean your MAF sensor? | |||
| Once a month or more |
21 | 3.55% |
| When i change my oil |
79 | 13.37% |
| When it needs it, I can tell by my EM or my butt dyno |
142 | 24.03% |
| NevAR |
352 | 59.56% |
| Multiple Choice Poll. Voters: 591. You may not vote on this poll | |||
#151 | |
Member#: 180547
Vehicle:2007 VF39 WRX STi Mikey tuned |
#152 |
Member#: 286999
SCIC
Vehicle:2004 Impreza WRX STI WRB |
#153 |
Member#: 14970
BAIC
Vehicle:1997 GF8 multi |
roughly every 3-4 oil changes... annually then I suppose
#154 |
Member#: 240649
South East
Vehicle:2004 WRX STi WRB |
I'm going to try this myself soon with MAF cleaner. I saw a video on how to clean a mustang one but is it basically the same deal with the subaru MAF? Just take it out, spray it a bunch, let it sit for an hour and reinstall? Anything I should know about wiping it or anything? I am currently a stage 2 cobb map, I don't need to reset anything to clean the MAF right?
#155 | |
Member#: 282134
#156 |
Member#: 239953
Vehicle:2004 Subaru WRX PSM |
How do I reset my ECU if I am using Cobb Stage 2 AP? Is it the same with or without the the AP because I would like to clean my MAF, and IACV valve the same time but I hear it is neccesary to reset the ECU. Thanks guys
#157 |
Member#: 60142
Vehicle:2011 WRX Grey |
You don't need to reset the ECU, but if you want to just use the AP. Make sure you're still running the right map, however, as I'm pretty sure a reset will delete any realtime map you have loaded; the base map will still be there, but any realtime map and all learning will go bye-bye.
#158 |
Member#: 239953
So its not neccesary then when cleaning the MAF and IACV? I just dont want anything to go wrong, and hear people of resetting the ecu.
#159 |
Member#: 180547
An ECU reset (disconnection of battery) is a good idea with any "new" mod. It let's the ECU learn the clean MAF values easier. But as stated above, make sure your running your correct map if using an AP.
#160 |
Member#: 60142
You can reset the ECU with the AP, no need for a battery disconnect.
#161 | |
Member#: 180547
#162 |
Member#: 60142
I figured that, but vic92189 has one and I didn't want him to get confused. I'm kinda surprised, however, that he hasn't noticed the "reset ECU" option on the AP menu...
#163 |
Member#: 239953
haha.. I did.. but thanks guys, im going to do it tomorrow. I just didnt know when resetting the ECU if I should do it through my ECU, or there is a process in doing it elseway. thanks guys.
#164 |
Member#: 268708
Vehicle:2010 WRX White |
I have never cleaned mine nor had problems and I use a K and N filter, but will probably switch over to a dry flow filter soon to avoid problems
#165 |
Member#: 258165
Vehicle:2006 WRX Wagon WRB |
I clean mine every other oil change when I rotate tires. It takes just a couple min and is cheap. Why wouldn't you do it?
#166 |
Member#: 134005
Vehicle:2004 WRX Premium PSM |
I'm at 97k and mine very well may have never been done. I've had it for the last 3-4k.
My AF learning 1 values have been in the 8-11% range. I did a vacuum test and it didn't show any leaks. MAF is next on my checklist... and maybe even an O2 sensor... but you can't clean those. Thanks for the thread. |
#167 |
Member#: 243992
Vehicle:2006 WRX TR WRB |
Never, I don't have one
#168 |
Member#: 255776
Vehicle:2010 LR WRX MPS and PAR powered. |
^^^Damn...you beat me to it
#169 |
Member#: 340256
How do you know if your MAF is dirty & are their symptoms for it being dirty? I'm not sure If that is the case, or If I have a vacuum leak.
#170 |
Member#: 324808
E. Canada
Vehicle:2006 IWL Stg2 OBP |
what does cleaning the MAF do? instructions to clean it?
-on behalf of the curious souls |
#171 |
Member#: 134005
Just reporting back... since finding this thread, I cleaned mine.. 2004 WRX with 98k and I'm assuming it's never been touched. It was dirty, but not as dirty as I would expect.
Didn't do a damn thing for mileage or for my high AF learning values. Turns out, it was a leaky BPV gasket causing that. As for cleaning the MAF, I'd only recommend it if you have a MAF related problem.... or 'maybe' every 100k. Butt dyno didn't change, even after resetting the ECU and letting it learn. |
| Thread Tools | |
| Display Modes | |
| How often do you change your synth oil in your wrx | D-I-Z-Z-L-E | Factory 2.0L Turbo Powertrain | 58 | 12-03-2012 08:30 PM |
| How often do you wash your hair (if you have any)? | HoRo1 | Off-Topic | 33 | 12-02-2003 03:22 PM |
| How often do you clean your K&N/reusable air filter??? | megatron | Factory 2.0L Turbo Powertrain | 1 | 10-18-2002 11:05 AM |
| how often do you wash your car? | inpreza kid | Canada Region Forum | 12 | 02-24-2001 05:07 PM |
| How often do you clean your rims? | John2.5RS | General Forum Archive | 12 | 05-22-2000 08:02 AM |
