Old 11-22-2012, 06:42 PM   #26
PitwrkzZ1
Member#: 94316
Originally Posted by polyol View Post
Man, I would never rid the ABS...^^^like others said...
A lot of people use it as a safety feature in deep snow. Apparently it's better to lock up your wheels and plow than for the ABS to kick in. I dunno, I never had the opportunity to use it.
PitwrkzZ1 is offline   Reply With Quote
Old 11-23-2012, 10:54 AM   #27
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Default ABS Relocate
Relocating it is no real problem, but doing it right requires a fair amount of work and tools. Example in this setup.
Token-Negro is offline   Reply With Quote
Old 11-23-2012, 12:28 PM   #28
Rokkit
Member#: 84181
NASA #530 GTS2
Nice setup!
Rokkit is offline   Reply With Quote
Old 11-24-2012, 01:13 AM   #29
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
Originally Posted by PitwrkzZ1 View Post
Best of both worlds is to wire an ABS cutoff switch, easily done through the fuse for the pump. Flip it off, the ABS light comes on, flip it back on and the light goes off. Couldn't be easier.
I pull my fuse on gravel and it works brilliant but on tarmac the rear wheels lock first, you would need to change the bias or get some sort of proportioning valve before deciding whether you prefer the car with or without ABS.
JDwhiteWRX is offline   Reply With Quote
Old 11-24-2012, 01:47 AM   #30
mug23
Member#: 97841
2005 STI Race Ready
OBP/Orange
That's a very nice set up and require a lot of work and tube bending.
mug23 is offline   Reply With Quote
Old 12-04-2012, 12:26 PM   #31
KillerRabbit
Member#: 184772
2004 WRX
That is amazing!
KillerRabbit is offline   Reply With Quote
Old 12-04-2012, 02:04 PM   #32
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
As has been touched on earlier, remember ABS in the STI is tied to the DCCD, EBD, and trail brake assist all of which help you get the most out of your car (in theory).
RallyLegacy is offline   Reply With Quote
Old 12-04-2012, 02:16 PM   #33
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
I say do it and do a write up. We need one on here!
For a track car there is no need for it. Just dead weight.
Old 12-04-2012, 02:27 PM   #34
KillerRabbit
Member#: 184772
2004 WRX
Ive always been told ABS can hide a bad driver, but at the same time ive seen guys that are using the ABS to there advantage. And with the knowledge on knowing how to use it its nice.
Old 12-04-2012, 02:39 PM   #35
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Yes there is. LOL!
If you can never engage ABS then you either need to brake harder or improve your brakes. My current race setup will not engage ABS in a straight line, there is just too much grip and downforce. However if I brake late turning and cresting a hill like the back straight at VIR there is no way anybody could out brake the ABS system. The reason is that without ABS you would have to take break pressure off all four wheels (there is only one brake pedal) to keep the inside rear from locking up.
It does take more skill to master braking without ABS but on most race tracks you cannot beat a modern 4 channel ABS system. Look at all the single wheel lock ups you see in F1, if they had ABS they would never have to come off the brake pedal to keep that one tire from locking up.
You need more aggressive brake pads as a start if you are trying to have enough brake to engage ABS.
Old 12-04-2012, 02:54 PM   #36
tyrel.boyce
Member#: 270178
2002 Subaru WRB
380HP stock motor HTA68
Look up chase bays, they offer a super sick setup for deleting your abs.
tyrel.boyce is offline   Reply With Quote
Old 12-04-2012, 04:35 PM   #37
K1WRC
Member#: 64511
2003 WRX sedan
VF36 EJ207
I agree to keep the ABS. I tried pulling the ABS fuse for a session at my last track day, it was entertaining.... There was just no way that I could carry the same speed into braking zones that weren't a straight line without locking up a tire. Straight line braking was great though... I was about 2 sec a lap slower than my previous sessions.
Sorry to threadjack, but is the STI ABS pump different/better/less intrusive? I have an '06 STI 6 speed, with DCCD pro etc. and was wondering if that would be a worthwhile upgrade on my 03 WRX.
K1WRC is offline   Reply With Quote
Old 12-04-2012, 04:53 PM   #38
Element Tuning
Member#: 54918
673 WHP Element
Yes the STi ABS is way better than the 02-03 WRX ABS which sucks by comparison (when ABS engages it releases too much braking to the other wheels because it's not 4 wheel independent). I'm pretty sure there was a (not recall) bulletin that Subaru would swap the the ABS computer on the early WRX models for free.
Old 12-04-2012, 05:06 PM   #39
mug23
Member#: 97841
2005 STI Race Ready
OBP/Orange
I think I have decided to keep the ABS as it will help out in not flat spotting the tires if it locks up.
I wouldn't re-doing all the hard lines too so, what's cheapest tools would I need to easily bend and flare the lines if I want to relocate the pump? What size and types of lines can I use?
Old 12-04-2012, 07:26 PM   #40
K1WRC
Member#: 64511
2003 WRX sedan
VF36 EJ207
Ok, so I'm guessing all I really need is the control module and not the pump itself. I do have the STI brembos...
Good choice, I think, OP
Old 12-04-2012, 10:34 PM   #41
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Originally Posted by KillerRabbit View Post
That is amazing!
Thanks took about 8hrs, few more for the bracket.
Old 12-04-2012, 11:44 PM   #42
sackytar
Member#: 149262
PrimerGrey
You can say that again I have a 03WRX and it was always a pita. Pulled fuse and its better.
Old 12-05-2012, 01:26 AM   #43
Element Tuning
Member#: 54918
673 WHP Element
I'm pretty sure it's all sold as one unit (pump and computer) and highly unlikely it's plug and play. I had to do a partial rewire from an 05 STi chassis harness to 06 STi abs and the wiring was different.
I would check if the option for the dealer upgrade is still available which would help the abs action.
The abs on the STi is really, really good for road race use. I just wish the bias was better!
Old 12-05-2012, 03:12 PM   #44
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Your local auto parts place should have lengths of brake line with the flares and flare nuts already on them, or without flares and no nuts. If you need to replace a line completely, then you want to buy the pre-flared lines. However, most of the time you should be able to just splice the existing lines (so you can reuse the existing ends with the existing flare nuts), so you can just buy the brake line without flares. IPretty much all the lines (for every car I've ever worked on) are 3/16", so the thing you would need to determine is what size flare nuts you need to match the factory flare nuts.
Those pre-flared lines mean you shouldn't have to mess with making inverted double flares at all. That's good, because they're a pain in the ass to form. When it comes time to splice lines, I strongly encourage you to use 37deg AN single flares. It's painfully easy to make a single flare (particularly compared to how hard it is to do an inverted double flare properly). I used steel unions, tube sleeves and tube nuts from Aircraft Spruce and a nice 37deg flare tool from them as well.
A simple tubing bender (again, available at any auto parts place) is all you'll need to bend the lines. There are expensive, swanky ones that you can get from Eastwood or other companies like that, but I just used one of these from NAPA or Autozone or whoever. Worked fine for me.
Old 12-09-2012, 07:31 PM   #45
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
On my 04 WRX DD/recce/TSD car I have an on/off ABS switch. Its off most of the time except some snow conditions. (yes, on some snow conditions ABS is great)
On my 02 Rally car it came w/o ABS or power brakes, fully manual. Do I miss ABS? Hell no.... For the most part LFB and ABS don't mix well.
REDrum is offline   Reply With Quote
