Old 04-24-2012, 06:52 PM   #1
aphilli85
Member#: 286966
1999 Impreza OBS
Green
Default DIY LED Tail lights
HEy does anyone know how to DIY LED Tail Lights for a 99 OBS?
aphilli85 is offline   Reply With Quote
Old 04-24-2012, 08:31 PM   #2
dave_88
Member#: 65864
WRX gone; hate the
Honda forums so much.
i did one for my past cars and holy hell was it a project.
you have to research about the correct LEDs to use and then figure out the arrangement and wiring (resistors mainly) - but that's really the hardest part.
the wiring is easy and tearing apart your taillights isn't that hard. of course you gotta figure what type of lighting your car uses to make it all work.
Also, if a set of bulbs is used as the parking lights but then is also used as the brake lights, then you need a module to essentially dim that array of LED and then make them come on full brightness when you want to use them as brakes. I have that module laying around but forgot what it's called.
also, depending on the inside of your taillights lens, it might require you to sand it down smooth.
dave_88 is offline   Reply With Quote
Old 04-24-2012, 08:36 PM   #3
Andrew025
Member#: 303408
04 STi
It's called a PWM.
And sanding down your taillight lenses will most likely not turn out very good.
Andrew025 is offline   Reply With Quote
Old 04-24-2012, 08:53 PM   #4
draco159
Member#: 204121
2005 WRX Wagon
CGM
I would just get good quality LED bulbs, it would be a TON easier IMO.
draco159 is offline   Reply With Quote
Old 04-24-2012, 11:34 PM   #5
sars101
Member#: 280420
2005 2.5 rs
silver ish
i would think your car would be the same as any other car. maybe you should asking for pictures of your lights with leds cause it might not be as bright as the regular bulbs.
i like leds but not on my car i seen other impreza but mine are better.
sars101 is offline   Reply With Quote
Old 04-25-2012, 12:33 AM   #6
dave_88
Member#: 65864
WRX gone; hate the
Originally Posted by Andrew025 View Post
It's called a PWM.
yes a Pulse Width Modulator
the point of sanding down the lens on the inside is to prevent the light from spreading inside of the housing - for aesthetics really. some lens are molded with 'ridges' to spread the light from the single source.
Old 04-25-2012, 12:45 AM   #7
Andrew025
Member#: 303408
04 STi
I know the idea behind it, it just never turns out good. Especially if it's colored plastic.
Old 04-25-2012, 02:05 PM   #8
apkarian100
Member#: 207053
2013 XV Crosstrek
Turned out good for me:
apkarian100 is offline   Reply With Quote
Old 04-25-2012, 02:35 PM   #9
Andrew025
Member#: 303408
04 STi
Do you have close up pictures of the lens?
Old 04-25-2012, 03:02 PM   #10
Tesh
Member#: 266270
Chapter/Region: HIIC
'11 GR.STI.SDN
just tossing this out there, but i plan to diy-led my taillights when i have time someday, until then i'll just put this out there:
harbor freight etc have DOT rated LED trailer lights (in fact, i saw a set, quite bright at kmart for $20 iirc?)
1. buy lights
2. remove housings and just use the internal boards / wiring
3. open stock tails and create mounting points for trailer led internals
4. ???
5. profit!
if you're handy with a soldering iron and have some electrical experience, this is a pretty easy task
Tesh is offline   Reply With Quote
Old 04-28-2012, 05:27 PM   #11
burkart
Member#: 305000
2005 Legacy GT 5MT
Bright Silver Metallic
i found afew cadillac sts's in a junkyard and ripped out the huge long LED center stop lamp. its pretty interesting how it works. basically uses reflectors to siluate a contuniuos band of light. it is actually four long skinny circuit boards, connected by their wiring.
anyway, i put it in my rear glass area- 3m heavy duty double stick taped. i spliced into the spoiler brake light
http://www.flickr.com/photos/tommybu...ream/lightbox/
oh, best part! they didnt charge me
burkart is offline   Reply With Quote
Old 04-28-2012, 07:39 PM   #12
RallySoob
Member#: 74872
2006 STi
White/Black
that looks rad Burkart! thats some serious exhaust tips you got too... I dig
RallySoob is offline   Reply With Quote
Old 04-28-2012, 09:54 PM   #13
burkart
Member#: 305000
2005 Legacy GT 5MT
thanks dude. some better pics. hard to capture the LED effect... but hr goes
*updated url
http://www.flickr.com/photos/tommybu...7629822638635/
Old 04-28-2012, 09:55 PM   #14
burkart
Member#: 305000
2005 Legacy GT 5MT
now i wonder if i should snip the oem tail spoiler stop lamp.....
Old 04-28-2012, 11:08 PM   #15
altezza2impreza
Member#: 95516
ehhhh i dont think this mod should be done on older cars. LEDs are clean and crisp whereas the older tail lights look well old and outdated. it just doesnt flow for me.
altezza2impreza is offline   Reply With Quote
Old 04-29-2012, 03:27 AM   #16
That One Guy
Member#: 307270
I think apkarian's are beautiful. I would pay some damn good money for those. You should do a set and do a writeup. I'd mail you mine...
That One Guy is online now   Reply With Quote
Old 04-29-2012, 12:25 PM   #17
burkart
Member#: 305000
2005 Legacy GT 5MT
link?
Old 04-29-2012, 12:27 PM   #18
burkart
Member#: 305000
2005 Legacy GT 5MT
hey i agree, partially. i also dont like the look of LEDs when combined with incandescent bulb lamps. the LEDs light up faster and make the other lamps look janky.
However, if all the bulbs are LED, i'm ok with it. switching out your old bulbs for LED bulbs can really make a difference. it wont be individual dot's (a la nissan murano etc) but it will make them all super-fast-reacting and consistent looking
Old 04-29-2012, 01:42 PM   #19
That One Guy
Member#: 307270
Originally Posted by burkart View Post
link?
Post #8?
Old 04-29-2012, 01:44 PM   #20
burkart
Member#: 305000
2005 Legacy GT 5MT
gotcha. sorry. post #9 =]
Old 04-29-2012, 01:46 PM   #21
That One Guy
Member#: 307270
It's fine, I wish I had a writeup.
Old 04-29-2012, 01:55 PM   #22
burkart
Member#: 305000
2005 Legacy GT 5MT
i can help you! what do you want to do to yours? probably the best way is to buy some side-emitting LED flexi-strips in red, dremel open the side of taillamp assembly, superglue or double stick them in place, then splice them into brake wiring. the two biggest tips i have are:
- DONT BAKE your taillights. this method works to get headlights unstuck -but doesnt for tails. they are sealed up tight and will melt before they open the back clamshell piece.
- for me, so far, LEDs from amazon and ebay have been underwhelming. they looks great, but they fail or start flickering within 4 weeks. ive ripped them all out now. but obv the headlight work takes so long that its impractical to be fixing blinky LEDs constantly.
ive been futzing with my lights alot over the last 6-mo....
LEDs ringing internals of factory taillamps (LGT wagon)
DSC_2257 by tommyburkart, on Flickr
on car
DSC_2264 by tommyburkart, on Flickr
Old 04-29-2012, 01:57 PM   #23
SAFJrider
Member#: 318508
I did LEDs on my Honda but went back to stock after awhile-they just didn't seem that bright or the LEDs were crapping out too early
SAFJrider is offline   Reply With Quote
Old 04-29-2012, 02:46 PM   #24
burkart
Member#: 305000
2005 Legacy GT 5MT
if interested.. here's more info on the re-purposed cadillac STS light bar - DIY LED taillight behind glass mod.
i snapped some pics of the lightbar parts. it's made up of 4 skinny circuit boards with about 10 LEDs each. these are all linked by their wiring. there are 50 or so lenses that clip on to each LED section of the boards.
in these new pics with the trunk open, you can see my setup. it is exactly 3 circuitboards wide, so i trimmed off the extra board. (*damn didnt realize how enormous the 91-09 STS/SLS bitches were) - 4 boards.
with the lenses attached, the LEDs are amazing when viewed from behind at traffic level. theyre prismactic.
my setup is two layers of boards, one with the reflector lenses, one without. the OEM reliability of the LEDs gives me confidence that they'll last. i dont recall ever seeing a caddy with its lightbar out, in fact.
enjoy.
re-purposed cadillac STS light bar - DIY LED taillight glass
Old 12-04-2012, 06:15 PM   #25
burkart
Member#: 305000
2005 Legacy GT 5MT
LED tail light bulb install cause Diff Cntlr & Cruise cntrl to fail? REDDOG General Community 20 05-02-2008 07:49 PM
LED tail light bulb install cause Diff Cntlr & Cruise cntrl to fail? REDDOG Electrical & Lighting 5 05-02-2008 07:20 PM
06 STI Differential & Cruise control prob from LED tail light bulbs REDDOG Drivetrain 0 05-02-2008 06:20 PM
LED Tail lights Sephro Off-Topic 39 05-16-2007 09:16 PM
Video : LED Tail lights , headlights with Rockblocker film ZoomnWRX Member's Car Gallery 10 11-06-2006 09:40 PM
