Old 10-27-2012, 09:09 PM   #1
Freeze Plug
Member#: 234613
Default Flywheel Crank bolt circle pattern?
I am wondering if anyone has a drawing or knows the exact dimensions of the EJ series flywheel/crank bolt pattern? I don't have any old flywheels handy at the moment and I certainly don't want to pull an engine to find out. I am looking to make a flywheel adapter for an engine swap that I am considering
Thanks!
Freeze Plug is offline   Reply With Quote
Old 10-27-2012, 11:26 PM   #2
suberdave
Member#: 101865
88 GL-10 STi
i have a spacer from an auto EJ trans, it's about 1/16" thick, but would work as a template.
PM me if interested. will ship it for $3 to cover cost of shiping.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 10-28-2012, 04:54 AM   #3
...CHUCKLES...
Member#: 149674
2006 LimitLess STI
SGM
All measurements taken off of flywheel.
All measurements in inch
Center hole for pilot bearing "Diameter" = 1.2560
Flywheel bolt hole size "Diameter" = .4115 x 8 bolt holes
Edge of "center hole for pilot bearing" to Edge of "flywheel bolt hole" = .4695 x 8 equal spaces
Edge of "flywheel bolt hole" to Edge of "flywheel bolt hole" = .5850 x 8 equal spaces
Hope this helps just hit me up if you need mor info.
...CHUCKLES... is offline   Reply With Quote
Old 10-28-2012, 06:39 AM   #4
Freeze Plug
Member#: 234613
awesome, that should do it! thanks!
Old 12-04-2012, 09:25 PM   #5
Swimminginblues
Member#: 336702
so all of the EJ series share the same bolt pattern?
Swimminginblues is offline   Reply With Quote
Old 12-04-2012, 09:48 PM   #6
eg33GC
Member#: 206851
56 Belair
Pro Street
yes, and eg and ez
