Old 11-28-2012, 12:51 PM   #3201
303GWRX
Member#: 298980
2003 Forester XS
JBP
Originally Posted by Turtlefart View Post
Would you mind posting a shot of how you ran the wires for your gauge? Were you able to wedge them behind the dash hood? Thanks in advance
303GWRX is offline   Reply With Quote
Old 11-29-2012, 03:44 AM   #3202
cianuro
Member#: 235475
Chapter/Region: PRSIC
2008 WRX
In my case, I dremmeled a small notch right where the hood ends and joins with the rest of the dash. The hood has some integrated clips, and kind of like a recessed border between these clips that hide behind the dash when the hood is in place. The notch is done on that border, enough to fit the wiring through but staying hidden under the dash. It looks like the wiring is squished between the hood and the dash, but it isn't.
Not a great pic, but you can see where the wires go into the dash:
At least that way there are no visible drilled holes on the cluster hood. After that, I ran the wires behind the cluster down to the fuse box for power, and behind the glove box for the wideband module.
cianuro is offline   Reply With Quote
Old 11-29-2012, 11:52 AM   #3203
303GWRX
Member#: 298980
2003 Forester XS
JBP
Awesome! Thanks for the info
Old 11-29-2012, 05:11 PM   #3204
tersplat
Member#: 337888
2003 WRX Wagon
Just using my glowshift pod and my boost gauge for now.
tersplat is online now   Reply With Quote
Old 12-02-2012, 11:08 PM   #3205
jimbosv650
Member#: 261307
04 wrx wagon
Picked up a used 66mm autometer boost gauge for $20 yesterday. Opened it up and wired in 3 LEDs, then molded my old 52mm pod to work with the much bigger gauge. Used a dremel and heat gun, and modified the a pillar itself, but it needs more work. I'll refine it a bit more in the near future with body filler and whatnot.
jimbosv650 is online now   Reply With Quote
Old 12-03-2012, 02:10 PM   #3206
Bansheeboy11
Member#: 182415
1999 RS
Picked this up a few weeks ago, it's replacing my Omoris.
Bansheeboy11 is offline   Reply With Quote
Old 12-03-2012, 02:24 PM   #3207
mtarr07
Member#: 246990
2010 Wrx
subscribed
mtarr07 is offline   Reply With Quote
Old 12-03-2012, 03:05 PM   #3208
Pearly_Whites
Member#: 164714
2007 WRX TR
Interesting.. kind of like my zeitronix lcd display. External sensors or does it read off of the obd port?
Pearly_Whites is offline   Reply With Quote
Old 12-04-2012, 10:10 PM   #3209
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
zeitronix are nice!
Old 01-02-2013, 01:42 PM   #3210
01Twinturbo
Member#: 317871
Here is my new gauge set up, using a Edge CTS Insight monitor, little hard to read but i have Oil Temp, Egt, Oil pressure, ECT and Fuel pressure. Had to use Accessory sensors for everything but the ECT the insight pulled that off the OBD port
Here is better picture during the day, so you can see that the CTS is mounted in the pod with the pod mount, dont pay attention to the screen... sensors werent hooked up yet
01Twinturbo is offline   Reply With Quote
Old 01-02-2013, 03:02 PM   #3211
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Just finished retro fitting my V7 Prodrive Cluster and Defi D-series gauges in LED Blue
http://forums.nasioc.com/forums/show...ighlight=wagon
dangerousatom is offline   Reply With Quote
Old 01-02-2013, 08:02 PM   #3212
C-Farm
Member#: 280621
2007 WRX
98 Legacy Outback
I wanted to install my boost gauge somewhere that would not look out of place or something that was "added" for that matter, and at the same time be very clean. I was able to acquire the STI Genome Defi boost gauge. I don't really look at the gauge too often except when I look to verify correct vacuum and to make sure that I'm achieving the correct boost levels. So I went ahead and purchased the Subtle Solutions Gauge Bezel. I also decided to give it an OEM texture as well as retaining the factory 12v socket and light ring.
C-Farm is online now   Reply With Quote
Old 01-03-2013, 01:30 AM   #3213
sc00by4life
Member#: 97135
too bad there is no feasible way to see it when driving.
cool idea though.
Old 01-03-2013, 02:03 AM   #3214
CanadianImprezaSTi
Member#: 312159
2004 WRX
AEM Boost/AF/Oil pressure.
ATI clock pod.
CanadianImprezaSTi is offline   Reply With Quote
Old 01-03-2013, 03:21 PM   #3215
C-Farm
Member#: 280621
2007 WRX
98 Legacy Outback
cool idea though.
I can see it just fine but yes its not easily visable without having to take my eyes off the road.
Old 01-03-2013, 10:18 PM   #3216
leemarchais
Member#: 341215
cool idea though.
Cool idea
leemarchais is offline   Reply With Quote
Old 01-04-2013, 04:03 PM   #3217
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
Who makes this pod? I am going to run a AEM wideband and put it in that corner......also would it be hard to get the wires to and from this pod?
shamrock 05 is offline   Reply With Quote
Old 01-05-2013, 10:18 AM   #3218
Fanboyt
Member#: 341413
good
Fanboyt is offline   Reply With Quote
Old 01-05-2013, 09:09 PM   #3219
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
This is my second Autometer dual gauge bezel. The first one was flimsy and I ended up cracking it. The second one I think I got from ImportImageRacing but it wasn't advertised as an Autometer. When it arrived there was a piece of paper in it that had Autometer stamped on it with instructions. This one was a little darker and thicker. The top does not bend down like the first one (which was annoying).
Gauges are AEM digital boost and wideband.
flimflamman is offline   Reply With Quote
Old 01-05-2013, 10:48 PM   #3220
1VIPWRX
Member#: 107554
yellow
Aem failsafe gauge being blocked on the right
1VIPWRX is offline   Reply With Quote
Old 01-07-2013, 10:32 AM   #3221
shamrock 05
Member#: 120057
^^^^^^^This pisses me off... I have Autometers too and a mechanical boost gauge. The gauge used to be a 20 psi in vac at idle and now its at 15 psi at idle.....while driving and letting off the gas the needle would sink down to 23-24 psi in vac and now it only goes down to 20 psi MAX.....so WTF
Old 01-07-2013, 02:55 PM   #3222
tmburke
Member#: 342345
2008 WRX Hatch VF-52
SSM
Sounds like you got a leak somewhere down the line....
tmburke is offline   Reply With Quote
Old 01-07-2013, 05:48 PM   #3223
Pearly_Whites
Member#: 164714
2007 WRX TR
Might want to pressure test that gauge and make sure its accurate. You shouldnt be seeing that much vacuum
Old 01-08-2013, 10:52 AM   #3224
shamrock 05
Member#: 120057
Well I had a boost leak test done on the car and no it came back fine....no leaks at all.
"Seeing that much vacuum" As in what part.....like I said it used to...
hit 21-23psi while driving and letting off the gas NOW it hits like 17-19psi
and at idle/red lights it used to sit at 20psi NOW it only drops to 15psi
Old 01-08-2013, 11:23 AM   #3225
Pearly_Whites
Member#: 164714
2007 WRX TR
It could be how you worded it and your units of measure. Vacuum reads in 'inhg'. -20inhg is around 9psi of vacuum.
So which is it?
Post Pics Of Your Navigation Setup ( Eclipse , N1 ,N2 .... ) minx1225 Interior & Exterior Modification 1 09-06-2005 01:43 AM
Post pics of your FMIC setup KitchenerWRX Member's Car Gallery 2 08-30-2005 01:27 PM
Post pics of your gauges lit up... MomoWRX Electrical & Lighting 22 12-11-2004 10:21 PM
post pics of your gauge clusters/bezels 03wrx 03twrx South East Region Forum 5 11-13-2004 09:28 PM
Post Pics of your gauges and cluster shots! Leo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 02-19-2004 10:16 AM
