Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 12-02-2012, 11:06 PM   #1
ZOMBIE RX7
Member#: 213871
2007 WRX TR
UGM
Default Homeless grounf wire after clutch replacement.
I have a large ground wire without a home after my clutch replacement on my 2007 WRX. I thought I had labeled everything but I must have missed it. It's the large ground with that comes off the battery. Any help would be great!
ZOMBIE RX7 is offline   Reply With Quote
Old 12-03-2012, 11:15 PM   #2
ringlander
Member#: 336100
2011 sti
Pick a bell housing bolt and be done.
ringlander is offline   Reply With Quote
Old 12-04-2012, 12:28 AM   #3
banshee04
Member#: 179014
'06 WRX/STi
Built Motor/6766/E85
+1
Factory, it goes on the stud at the bottom of the block, but you can put it anywhere.
banshee04 is offline   Reply With Quote
Old 12-05-2012, 02:58 AM   #4
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Originally Posted by banshee04 View Post
+1
False sir, it is attached to the top Starter bolt/bellhosing bolt. Its like this on EVERY subaru since 1990
UK-Wagon is offline   Reply With Quote
Old 12-05-2012, 08:25 AM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
there is a bracket that goes with top start bolt. and it fits
on to the bracket with 12mm bolt. the bracket is factory ground
Old 12-05-2012, 12:38 PM   #6
GrimmSpeed
Member#: 136396
2013 BRZ
Is it black and yellow? If so there should be a spot on or around the bell housing for it.
Mike
GrimmSpeed is online now   Reply With Quote
Old 12-23-2012, 10:09 PM   #7
DuckStu
Member#: 124060
2004 WRX STI
It's supposed to be held on with the upper starter motor bolt.
DuckStu is offline   Reply With Quote
