Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Closed Thread
Old 12-03-2012, 01:20 PM   #876
Turn in Concepts
Vendor Sales Rating: (159)
Member#: 93646
Many Track Records
Let us help you go fast!
Originally Posted by imma_stocker View Post
Did a turbo swap, injectors, fuel lines, FPR, inlet swap, FMIC, complete intake, spark plugs, ACT streetlight flywheel, Grimmspeed crank pulley, and meth at the same time as this. Order of parts heads up: heads -> 3mm phenolic spacer with lower gasket -> composite TGV housing with o-ring and no gasket -> intake manifold with o-ring and no gasket. Used a new gasket for the heads to spacer.
Idle misfires on all 4 cylinders. New plugs, new injectors, no change swapping around coil packs, low load misfires on all 4, no pattern I can see yet. No misfires under load. Did a BUNCH of mods at the same time so it could be anything. Might be leaking inlet coupler, might be leaking FMIC couplers, might be change in catch can routing,.... lot of "might be" but no real evidence to say what it really is. Re-used a few gaskets that looked good as I already planned to change them for a fresh piece during motor build. BOV gasket leaked over 22psi, throttle body gasket doesn't seem to leak but might also leak over a certain psi, can't find any other leak and misfires are random.
Revised my fuel lines so both banks get equal length parallel fuel lines (kinda helped). Before they were parallel but ran out of line and fittings so had to do an unequal parallel setup which still worked.
EDIT: Just to be clear this is a strange misfire that's been a monster to trace and correct. It will probably be something silly as it is random and doesn't happen under meaningful load. Idle misfires I pretty much ignore as it could be the lightened flywheel and crank pulley. I haven't noticed a repeatable pattern yet so it could literally be anything. Hell the rings might be letting too much blowby through which could cause a misfire.
Have you done a boost leak test yet?
__________________
__________________
Turn in Concepts is offline
Old 12-03-2012, 02:56 PM   #877
sabreofsd
Member Sales Rating: (8)
Member#: 48943
2004 95%*STi Blu/Gld
www.dcawd.com
It's probably because of your lightened flywheel. What are you using to tune it? Feel free to PM so we don't clutter up this thread.
sabreofsd is offline
Old 12-04-2012, 11:44 AM   #878
imma_stocker
Member Sales Rating: (23)
Member#: 97043
08 STI
02 Z28 - project
Boost leak test found the gaskets and coupler leaks. Sealed those which helped but I think the idle misfires are from light weight parts.
imma_stocker is offline
Old 12-05-2012, 04:44 PM   #879
Turn in Concepts
Member#: 93646
Many Track Records
Ok guys - I know who is left, and who has not paid. I'm on top of that, and so it's time to close this thread.
For everyone that participated thank you very much. If you have any questions please shoot us an email on the support account or give us a ring.
If you'd like to leave a review of the part please put it in the car part review area.
If you'd like to leave a review of us please leave it in the vendor review area.
Now off to post up the next group buy...
__________________
__________________
Closed Thread
