Old 09-07-2012, 08:40 PM   #26
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
WOW keep up the great work man...
Old 09-08-2012, 02:06 PM   #27
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
AN brake lines are not double flared, those are SAE flares.
I converted mine to all AN because the tools are cheaper and it's easier to do the flares. You can get some nice RIDGID tools for about $120 or so for a bender and the flaring tool.
dwx is offline   Reply With Quote
Old 09-08-2012, 08:34 PM   #28
Darcros
Member#: 196496
2006 STI
Im really not sure what your getting at. I understand that you can buy a cheaper tool to do the job.
ISO flares (ISO Bubble) , SAE flares ( Double flare) , Din ( Mushroom ) are the standard that is used for / by OEM past and or present .
The tube nuts and collars that I used for my brake system called for a double flare. First the single flare then the roll over of the collar into it self.
Darcros is offline   Reply With Quote
Old 09-09-2012, 03:13 AM   #29
Darcros
Member#: 196496
2006 STI
More plumbing parts .
Proportioning valve installed
Sparco wheel with release Installed.
Uploaded with ImageShack.us
Old 09-09-2012, 03:15 AM   #30
Darcros
Member#: 196496
2006 STI
As we sit right now. Engine bay area.
-6 lines ran to front of bay.
Some odd and other ends added .
By christoypher at 2012-09-09
Old 09-09-2012, 03:16 AM   #31
Darcros
Member#: 196496
2006 STI
THANK YOU
Old 09-15-2012, 02:55 PM   #32
Darcros
Member#: 196496
2006 STI
Taking her over to my friends shop for the engine install . Full build 2.5 for some e85 madness.
Old 09-15-2012, 03:14 PM   #33
BlueSTI4Me
Member#: 34361
04.7 STI
Originally Posted by Darcros View Post
The must have tool for doing the hard A/N Brake lines. IMO . ( Double flare )
The hydraulic tool makes the job much more simple.
The Mastercool deluxe Master Universal Hydraulic Flaring Tool Kit
Lucky mi amigo had one of these i could barrow. The price tag is a bit scary but after using the tool is worth every penny.
Yesssirrrrrrrrrrrr^^^^^
BlueSTI4Me is offline   Reply With Quote
Old 09-15-2012, 03:19 PM   #34
Darcros
Member#: 196496
2006 STI
Old 09-15-2012, 03:28 PM   #35
Rex_Revo
Member#: 311324
You should weld the rear doors... You can't use the back anyway.
Rex_Revo is offline   Reply With Quote
Old 09-15-2012, 06:00 PM   #36
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
The start of the engine bay brake line assembly.
Those adapters and the flare you show in the picture donít match up. Those inverted to AN flare adapters on the MC donít require a double flare at all, they are single AN flare 37 degree. You had the right tool and could have done the inverted flare right into the MC had you used the original tube nuts. What the other poster was saying is for std AN flares the Ridged tool for 120$ is hands down faster and easier to use when doing lots of single AN flares, they even have one for inverted flares. Canít tell if you used stainless or not but typically the rule is with steel line you double flare, and with stainless you can get away with single flare. I own the Master Cool, and both Ridged tools.
Token-Negro is offline   Reply With Quote
Old 09-15-2012, 06:02 PM   #37
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
With the ABS removed what DCCD controller are you planning on using?
Old 09-15-2012, 06:32 PM   #38
Darcros
Member#: 196496
2006 STI
JDM 6Speed. Kaaz Diff. No DCCD.
Old 09-15-2012, 06:35 PM   #39
Darcros
Member#: 196496
2006 STI
I took the picture off. The picture was just confusing every one.
Old 12-03-2012, 09:06 PM   #40
Darcros
Member#: 196496
2006 STI
Any way the build is continuing . More pics will be up soon ..
Old 12-04-2012, 02:00 PM   #41
Ballistic1350
Member#: 156877
04 sti
Looking good! mind showing us where your mounting your battery and kill switch?
Ballistic1350 is offline   Reply With Quote
Old 12-05-2012, 06:46 PM   #42
Darcros
Member#: 196496
2006 STI
The battery will be in the stock location. Will use a Odyssey Lightweight battery. The Switch will be located on the "A" pillar of the drivers side. (NASA,SCCA common location) No need to relocate the battery and add cable weight .
Old 12-05-2012, 10:24 PM   #43
hmnewtech
Member#: 339721
2003 WRX Hawkeye
mad looking car, and with the planned set up it's going to be a beast.
hmnewtech is offline   Reply With Quote
Old 12-05-2012, 10:40 PM   #44
boostjuice
Member#: 89492
2006 STi
what an amazing, jealousy inducing build!
Great work on that cage! cant wait to see the rest!!!!
boostjuice is offline   Reply With Quote
Old 12-05-2012, 10:51 PM   #45
KillerRabbit
Member#: 184772
2004 WRX
World Rally Blue
Nice build! Love the cage, i wanna see the rest of the interior in!
KillerRabbit is offline   Reply With Quote
Old 12-29-2012, 08:22 AM   #46
Scargod
Member#: 260314
2008 STI hatch
Originally Posted by mjfubar101 View Post
Got to have interior for alot of rules in different series unless you want to jump to the next class
You say track days, but what series/classes/sanctioning bodies are you trying to fit into?
I am most curious about what you are doing for your built engine. Any specs?
Surprised you don't put battery in the back for balance and to clean up the engine bay.
Scargod is offline   Reply With Quote
Old 12-29-2012, 11:03 AM   #47
Darcros
Member#: 196496
2006 STI
Following along the lines of showroom stock for interior. ( SCCA/ NASA )
Engine will be mostly all stock. Unlimited on exhaust. E85.
We run light weight Odyssey batteries. 12-15 lbs. Why add all that cable? (Weight )
Old 01-04-2013, 10:27 AM   #48
Bullet Bob
Member#: 336370
Nice job.
Bullet Bob is offline   Reply With Quote
Old 01-04-2013, 01:55 PM   #49
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
I say STU.
Patrick L is offline   Reply With Quote
Old 01-04-2013, 03:14 PM   #50
Himynameisgreg
Member#: 200420
'15 LR WRX
'05 AW STI Track Car
Why full interior? BECAUSE SHOW CAR!!
haha j/k
looking good, i'll be following this build. good luck!
Himynameisgreg is offline   Reply With Quote
