#301 |
Member#: 179775
Vehicle:. 03 WRX/05 FXT WRB/CGM |
I got my vf48 tuned a little while back at Cobb Tuning Plano, I love the new found power!
Car: 2003 WRX Engine: 2.0 L Milage: 102,XXX Dyno: Cobb Plano's Mustang Engine Mods: VF48 turbo Turbo XS TMIC Cobb SF intake Cobb catless tbe Cobb bpv Walbro 255 fuel pump ID 750 injectors Gimmick turbo inlet 3 port boost controller Cobb turbo heat shield Cobb AP tuned by Calvin at Cobb Plano peaks at 19.5 psi ![]() Graph says vf39, but should say vf48
#302 |
Member#: 259257
^ is yours the gold on blue? Would you happen to have a data log you could post or at least do to know what kind of timing on this tune?
#303 |
Member#: 179775
Yeah that sounds like my car, gold rpf1s. I don't have any data logs saved at the moment and to be honest, I don't know what kind of timing I'm running. If I get a chance this weekend I'll look into it. I need to replace my front O2 sensor and hunt for a little vacuum leak as well
#304 |
Member#: 296532
E. Canada
Vehicle:2006 STi WRB |
Car: STi 2006, 2.5L stock internals
Millage: 92xxx Mods: VF48, 850cc side feed injectors, DW200 fuel pump, K&N typhoon intake, 3'' TBE catted, EL headers, uppipe, 3-port EBCS Gas: 94 octane Dyno: Maha ![]() |
#305 |
Member#: 117767
RMIC
Vehicle:2007 WRX Limited OBP - VF48 |
2007 WRX / 50k miles
- VF48 - STI TMIC / Y pipe / Air Splitter - Perrin Turbo Inlet - Grimmspeed 3 port EBCS - SPT Intake - COBB 3" TBE (catted) 17.5psi - 280whp/315ft-lb TQ @5200ft above sea level ![]() My tuner made me an additional 19psi tune which put down 308whp/327ft-lb TQ IIRC. But he only recommended running that on occasion and only when it was sub 65 degrees outside. Last edited by sc00ter; 04-16-2012 at 03:19 PM. |
#306 |
Member#: 149806
06 wrx tr
Vf48 Cobb sf intake Cobb catless dp Cobb cat back Forge bpv Cobb ap 284whp/334wtq tune by efi mustang dyno 19.5 psi |
#307 |
Member#: 142559
RMIC
Vehicle:02 psm wagg 06 GSXR 1000 |
I need honest opinions......I have an 02 WRX Wagon with 108k on the odo, and I have a friend selling the VF48, injectors, TMIC and fuel pump from his 2011 STi. They had around 4k miles on them when he took them off, and he'd probably give me a killer deal if I wanted them.
Just wondering if you'd think it'd be safe, and/or worth it to throw those on the old 02 wagon. My first WRX was an 03, and I put the VF39 on it with supporting mods, and it was a blast, but that car had 60k miles when I did that. I want to do this but I'm a little hesitant, this car is my DD and I commute 50 miles a day, so I'm sure it would kill my gas mileage. Anyways, come at me with your opinions. |
#308 |
Member#: 306870
Vehicle:2003 WRX STI 2.0 |
If squeeze it into snot, as wheel forces can be removed?
On boost 1.5 each, can ride every day? |
#309 |
Member#: 236092
Vehicle:2004 wrx full exhaus vf48 aps big tmic nstuff |
sc00ter and wrxstage2 are you guys running upgraded injectors/fuel pump?
#310 |
Member#: 215042
Vehicle:2006 wrx |
2006 wrx limited
turboxs 4" downpipe gimmick motorsports cat back tgv delete spt intake walbro 255 fuel pump 3 port ebcs vf48 sti intercooler 294hp 321tq mustang dyno at rs motors in burnsville, mn. |
#311 |
Member#: 130990
Vehicle:06 Red Wagon hta68 MPS tuned JDM 6-speed |
#312 |
Member#: 301918
BAIC
Vehicle:2003 Impreza WRX VF-48 EQ hybrid |
2003 WRX wagon
Equilibrium Tuning built hybrid Perrin after-maf, inlet and intercooler hoses STi TMIC DW 650cc and Walbro 255 Hallman Pro RX MBC STi UP Perrin catless DP SPT exhaust 275.6 whp and 295.8 ft-lbs @ 17.5 psi on 91 octane at EQ |
#313 |
Member#: 142029
Vehicle:2013 Fozz 2004 STi, 1991 Miata BRG |
2004 STi
vf48 Samco inlet Harman Motive CAI Grimmspeed EBCS Grimmspeed uppipe Maddad catted downpipe SRS CBE Walbro 255 Kartboy crank pulley Cobb AP stock TMIC and injectors 314whp 360wtq on 93 octane tuned by STI Mikey at TheShopCT |
#314 |
Member#: 193757
Vehicle:2006 XTI Limited OBP, Junior tuned |
2006 FXT-XTI full STI mechanical conversion 07 STI 6 speed/ R180
4th gear Cobb AP v2 Stock EJ255 VF48 w/ WG welded shut, H/S PnP'd Cobb SF intake GMS inlet & AFTA MAF ETS TMIC GS EBCS Killer B Holy Header w/ custom up pipe & Tial MVR EWG Cobb full 3" custom catted exhaust w/ +12" resonator in mid pipe Full 1.75" EWG exhaust Walbro 400 E85 FP Aeromotive FPR Perrin Fuel rails DW 850cc injectors dyno. stock STI: 230 WHP Junior tuned Stock STI clutch let go at 440 WTQ, probably would have made more TQ and HP ![]() 2@ E85 pulls 93 pull ![]() ![]() ![]() Last edited by manitou; 01-06-2013 at 03:21 AM. |
#315 |
Member#: 121704
Vehicle:07 WRX LTD WRB |
07 WRX Limited
K&N panel filter Samco turbo inlet Grimmspeed BCS VF48 @ 20 PSI STi TMIC & splitter TGV delete ID1000's DW300 pump Invidia V2 catless DP SPT muffler section Cobb AP Pro Tune from Chris Black @ AMS Performance in W Chicago (Tuner of the Alpha12 GT-R WR 1500 hp street car) 288 AWHP 324 ft-lbs on a Mustang Dyno I will post dyno sheet, I'm trying to enhance it so that it is easier to read. If I can remember how to get it posted I will do that next. AMS' shop is nothing shy of spectacular. I pulled in from StL and counted 7 GT-R's 2 full rally race prepped Evo's, a couple of street Evo's and a few road race Porsche 997 911's. Needless to say I felt a little under gunned pulling in with my all but stock lil' 07 WRX, but they treated me with the utmost respect and acted as if my car was just as important as the guy getting the $63,999 Alpha10 GT-R pkg. Really nice folks. My only regret is that I didn't ask for the tour, they said I could be there for the dyno session but I missed the morning train from the city to get back out to W Chicago (my bad and my bummer). They even saved me some $ from the original estimate AFTER they found more work that had to be concluded before she was dyno worthy AND they threw in an AMS beanie on top of all that. Can't beat that with a stick. I definitely love the new found power, I'm not beating on the car (I have never driven like that) but I want to make sure all is tight and good before I give her the full beans. There is still a little more lag than I would have thought would be there and I will be in discussion with them as to how to get rid of this as my intentions were to build around throttle response not top end or dyno numbers. All in all AMS is an A#1 shop that I would recommend to anyone. A little on the pricey side but you know- and this is why I stayed with them after the estimate- you get what you pay for. I knew they could handle any and every little thing that might come up, which did and they did. The only used part I had was the STi TMIC and they found a tiny hole in the Y pipe that the previous owner was using to inject (prolly meth, I dunno)and welded it shut pronto, another shop probably wouldn't have even found that and just tried to tune around it. Bravo AMS, bravo. With all the in house engineering and fab work, not to mention the absolute piles of trophies including anything from the SCCA runoffs to Time Attack, I had no doubts my girl was in good hands. And this was before I read anything about Chris Black's reputation as a tuner, I just found his praise on the Injector Dynamics certified BadAss list this evening, after all was said and done. Lucky me! All around great experience, knocking on wood that it stays that way. Like I said I don't beat on cars but I do push it frequently. I'm guessing my next money will be in Tranny work but I need Suspension and wheels and tires next, so the 5 speed has to hang on for awhile yet. The first thing I did was the brakes, SS lines, hawk pads, quality slotted rotors (in front anyway) EBC I think, and that German Blue brake fluid. Figured a car has to be able to stop well enough first before throwing power mods at it. Now it needs to handle as well as it goes, debating coil overs VS Eibach Pro-kit (and sways) witsome quality dampers (preferably adjustable). Then wheels and tires and after all that if I'm not broke Maybe MAYBE I'll get some of the dings taken off her... ![]() |
#316 |
Member#: 121704
![]() All that being said, I am woefully under knowledgeable about the differences in dynos and how they read. Mustang dynos read low? Thats the feeling I'm getting from reading old post after old post. I am just curious what this might read on a more accurate dyno? 300 AWHP maybe? 350 ft-lbs torque? I dunno, anyone with the knowledge please chime in, love to get a more accurate number and a real world figure. Thanks to anyone that might help with that. |
#317 |
Member#: 142029
^^I'm assuming this tune was on 91-93 octane? Since you have 1000's, are you getting retuned on E85?
Re: your question about dynos, take it to the track to get a better idea. If you trap 108-109 as it sits on pump gas, then you have a strong VF setup. 110+ is exceptional on pump with a VF. If you were on E85, then 110-112 would be expected and you could run a high 11. |
#318 |
Member#: 121704
Yes 93 octane. I was thinking about going to e85 in the future, when I did more research because it looks like there are significant gains to be had. Been reading about the stock 5 speeds though, not liking what I'm seeing but again I don't rape the go pedal, so I'm hoping it will last awhile still. I JUST NEED MORE THROTTLE RESPONSE, like my original 05 STi. Wheres the hold up to that in my system here? I've researched the hell out of this and thought I bought all the right parts, it just still has that split second hesitation my 05 did not have. I want that instant GO back.
But all in all , I thought these were great numbers, the daily driving of it hasn't changed one bit, well. its a little louder, but with that perfect SPT boxer rumble I'm OK with that, it's not a droner like a Honda with a fartcan. (And don't get me wrong, I love Hondas, I owned a 95 Civic Si for 11 years). Last edited by paved1; 11-17-2012 at 09:27 AM. |
#319 |
Member#: 237713
Vehicle:2002 WRX Wagon Aspen White |
I have an 02 wrx 2.0L and just bought a vf48. I'm trying to decide what to do for a tune. It looks like a Cobb access port runs $600 new and a Cobb Pro-tune is $400 so I'd be looking at $1000 to do it right. That seems like a lot to pay especially considering the $400 for a tune is only going to last me until I decide to mod further. My friend has a Tactrix cable that I can borrow and he knows someone he claims can tune the car for me. Does anyone here have experience with street tuning through a Tactrix and if so what words of wisdom do you have about going this route vs getting a dyno tune? I was also wondering if anyone has a similar set-up to me and wouldn't mind sending me their map so I have something to start off with. My mod's are as follows:
stock 2.0L block vf48 05 STI TMIC with y-pipe 07 STI injectors (I believe they are 565cc, same as pinks) SPT Intake STI catless uppipe 3" catless TBE Grimmspeed 3 port ECBS Walbro 255lph FP From reading this thread it sounds like I maybe should have gone with DW 650cc injectors. Somebody mentioned the 06 wrx injectors (560cc?) will be running at 97% IDC with this turbo. I plan on getting a wideband O2 sensor so I can monitor my AFR that way if I do toast the injectors I can shut it down before I run lean and kill the turbo. Any feedback on Tactrix cable tuning would be appreciated, and as I mentioned before if someone has a map I can base my tune off of I'd appreciate that as well Thanks |
#320 |
Member#: 237713
Also, I plan on running on 93 octane
#321 | |
Member#: 193757
#322 | |
Member#: 142029
2. You don't need to worry about the turbo being killed from a lean AFR. You need to worry about the motor being killed. As long as the tune is safe and within the limits of your fuel, you should be fine. |
#323 |
Member#: 237713
#324 | |
Member#: 237713
2. I was under the impression that hot exhaust temps can kill the turbo (as well as the motor) |
| Thread Tools | |
| Display Modes | |
| Should I swap VF39 for the VF48 on 03? | guru_method | Factory 2.0L Turbo Powertrain | 24 | 07-31-2010 02:28 PM |
| Deleting the weapon thread.. and the whining thread about me locking it is even lamer | Fish | Texas Impreza Club Forum -- TXIC | 14 | 07-01-2010 12:29 PM |
| What is the max boost for the VF48? | Tuned200 | Factory 2.5L Turbo Powertrain | 14 | 02-17-2009 04:59 PM |
| Quest for 11's in the VF48 Saabaru (How much more can I get out of my VF48?) | cireturbo | Factory 2.5L Turbo Powertrain | 30 | 09-24-2008 01:32 AM |
| Why did the 'Discsussion' thread for the SOA recommendation thread get closed? | left footed whooten | News & Rumors | 6 | 09-05-2006 12:47 PM |
