12-06-2012, 10:44 AM | #26 |
Member#: 318280
It's not about the mods because both are going to be much more with the right mods. It's about looks, a smoother and bulletproof trans and like stated above, it just drives different. I do not have enough seat time in an STi to make a more solid judgement though. I think a lot of my issue is coming from a 2005 Evo MR, I am just used to a more complete machine. I screwed up and thought the WRX limited would be a nicer DD but it just feels lacking to me.
12-06-2012, 10:51 AM | #27 | |
Member#: 316517
Vehicle:2012 WRB WRX Hatch TP Stage III & ELH |
My next "big" mod is a CF driveshaft, not for strength, not for bling/bragging, but just because I absolutely have the two-piece design and its bouncy BS, (another STI part that I'd want to upgrade). |
12-06-2012, 10:54 AM | #28 | |
Member#: 318280
12-06-2012, 11:21 AM | #29 | |
Member#: 309636
Vehicle:2015 STI LE WRB on Gold! |
Plasma, if you're not satisfied with your WRX, go STI. It's as simple as that. Obviously it's cheaper to start with that platform versus playing catch up. Looks are completely subjective between the new widebody WRX and the STI... Unless you're dying for painted calipers and the wing (except you're going hatch so that's even less of a difference) unless you can't paint and find someone willing to trade... For everyone that complements the 6 speed, the longer ratios of the 5 make it a better road warrior, although the 6 obviously keeps you on boil better in the twisties and it feels better... What it comes down to is what you already stated in your OP... Your own personal priorities. I've never questioned the WRX after spending seat time in both... And when I'm a doctor... I'll buy a GT-R... Blehhh, you sound like someone who should've started out with the STI. Last edited by nightdown fox; 12-06-2012 at 11:26 AM. |
12-06-2012, 11:27 AM | #30 | |
Member#: 316517
Even if I had a GT-R, I would still feel the need to modify it because "if it can be made faster....it's not fast enough!" leaving power on the table!
And for anyone wondering, I'm an engineer... It's practically my job to complain and nit-pick and find imperfection so that it may be improved. Last edited by blehhh; 12-06-2012 at 11:50 AM. |
12-06-2012, 12:30 PM | #31 |
Member#: 335784
South East
Vehicle:2013 WRX Crystal Black Silica |
It all comes down to what you use the car for. I don't have any plans to take my car to a racetrack, and I don't live in an area with many winding roads. My plain-jane WRX handles and accelerates much better than I'll ever need on a public road, and the more punishing ride and tighter gear ratios of the STI just aren't needed when a majority of my driving involves going down a straight road. I can afford the STI, but the WRX just fits the bill better for normal driving and still has 9/10ths the performance of the STI. If you track your car, it's worth the premium for the STI... but I just don't see it being worth the extra dough otherwise. In the end it just comes down to what the priorities of the driver are, some people want an STI for nothing more than bragging rights (and there is nothing wrong with that if it makes them happy) and will never drive it anywhere near its potential.
12-06-2012, 01:18 PM | #32 | |
Member#: 9264
Vehicle:2016 BMW M235i 6MT |
Your STI has the same exact plastics, interior panels, seats (minus the center cover inserts), and speakers as a WRX. |
12-06-2012, 01:29 PM | #33 |
Member#: 130990
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
I'd say stock-for-stock the STi is better. Faster? Probably not, unless you take it to the track (not the 1/4 mile!).
If you're going to mod, STi definitely. Just dropped 5k into a jdm 6-speed swap myself. Pay now or pay later. |
12-06-2012, 01:52 PM | #34 | |
Member#: 9264
Many of the WRX's perceived ills are easily corrected. Sloppy shifter? Buy bushings and an STS for around $150. Don't like the softer ride? Swap in Koni/Bilsteins and RCE springs for $1200 or just do the shocks for $800 since that's where most of the improvement comes from. Don't like the initial lean into turns (which really doesn't affect handling that much)? By a $90 STI rear sway bar and do the springs/shocks. Don't like the "feel" of the brakes? Buy a $70 set of Stop Tech Street pads. Remember, the STI comes with near race spec, wider rubber which is largely why it can generate nearly 1g of grip vs the WRX's still impressive 0.90g of grip. Change the tires on the WRX and you'll get nearly the same amount of grip on a softer stock suspension. While you're at it, why not just change out the 17" WRX rims to a set of 18X8.5 to 18X9s and improve the looks? If I had an STI, I'd still change out the rims to differiate and improve the looks. Then there's the fuel mileage. For whatever reason, the STI sees about 15% less MPG than the WRX. For 10,000 miles driven in a year at 91+ fuel at ~$3.80/gal, you're looking at an extra $450-500 in annual fuel costs. |
12-06-2012, 01:55 PM | #35 |
Member#: 9264
No quite sure why so many say this. The 2008+ STI motors (the pistons) are more fragile than their WRX counterparts. The 6MT is beefy, but so is the 2009+ 5MT. Very few come close to maxing out the strength of the newer 5MT.
12-06-2012, 03:18 PM | #36 | |
Member#: 316517
For example, the pitch stop might be a "6/10" on the WRX and an "8/10" on the STi, but a Kartboy for either is like "9.5/10" Both need steering rack inserts. Both need rear diff inserts. Both need transmission mounts. So something to at least consider if planning to buy and upgrade an STi is that some of that additional sticker price went into some of those marginally better STi parts that you will still be wanting to upgrade anyway. xluben is the perfect, albeit extreme, example of this...He's upgraded the tires, wheels, springs, struts, gears, pistons, header, turbo, intercooler, probably all of the drivetrain mods, maybe even brakes? There's not whole lot left of that WRX that came from subaru lol. And I'll bet nearly every part he's touched is now better than what the STi comes with. I wish I could have stood on the assembly line at Subaru and just handed them all of the aftermarket parts I wanted in my car and just pay the true difference, rather than having tons of stock parts lying around for when I have to revert to stock and sell it Last edited by blehhh; 12-06-2012 at 04:00 PM. |
12-06-2012, 04:00 PM | #37 |
Member#: 45076
Vehicle:2004 Stg 2 wagon AT 16 BRZ. Both silver |
Its simple for DD you do not need an STI - it is purely a want. If you can afford it do it. No doubt it is a better enthusiast car to start from.
In May 2003 I wanted a wagon and there was no STI wagon, so I got a WRX. I knew I was modding over time so it was fine to enjoy the car stock under warranty and slowly upgrade to where I wanted it. If there was an STI wagon at the time - I would have likely got it and done the same thing - the extra cost over a 5 year loan would have been just fine. |
12-06-2012, 04:01 PM | #38 |
Member#: 45076
They could do that, but its not likely you would have a factory warranty.
12-06-2012, 07:42 PM | #39 | |
Member#: 318280
You're right that it will come down to my personal opinions/priorities. I suppose I need more seat time in a STi to really decide if its what I'm looking for. I really just wanted to hear what people who went from 2011/12 wrx to 2011/12/13 STi thought. These are the only people who can give me an informed opinion. |
12-06-2012, 07:47 PM | #40 | |
Member#: 318280
12-06-2012, 07:51 PM | #41 | ||
Member#: 319696
BAIC
Vehicle:2012 Subaru WRX STI DGM |
My coworker traded in his stage 1 wrx (taht's the only mod he did) for an STI after driving mine. He initially wanted an STI but got talked into buying a wrx by the dealership. eventually regreted that choice and a year later traded up to an STI. His reasonings mostly were that he liked the 6 speed transmission and stock suspension more than his wrx. he also mentioned he shoulda just went with his gut rather than trying to rationalize what's practical. His wrx i noticed a 2mpg hit from the dash readings (his says 22 on his wrx while mine says 20 on my sti). I guess in short is if you feel the urge, then its just a matter of time before u cave into it. might as well cave as soon as u can and move on with life! If you're totally stoked with the WRX, then you'd probably wouldnt make this thread. edit: my buddy's an engineer & single so i would take that its easier for him to throw money around. |
12-06-2012, 09:48 PM | #42 |
Member#: 318280
Haha yeah I'm kidless so the money isn't really an issue. Thanks for the input. I know you're right, I think my rational brain is the reason I'm holding out and making posts instead of finding the car. Damn you reasonable brain, must be my dad and his accountant career that gave me this.
12-07-2012, 07:43 AM | #43 |
Member#: 330146
TXIC
Vehicle:2018 STI Limited Pure Red |
This thread has turned into the standard WRX vs higher cost of the STI. A basic premise is that you can not upgrade a WRX to STI specs cheaper than the factory ( unless you happen to own a wrecked STI ). Is the STI perfect, no car is. I think a lot of people mod for the sake of modding. Out of the box both cars are a very good package.
Potential buyers need to evaluate which car best meets their needs and wants. AG |
12-07-2012, 09:10 AM | #44 | |
Member#: 318280
