Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 12-03-2012, 06:04 AM   #151
TyConway
Member#: 193189
2002 wrx
well finished welding up the first turbo manifold and ported it out. Then went ahead and fabbed up the 3" stainless charge pipe. All came together nicely.
TyConway is offline   Reply With Quote
Old 12-03-2012, 02:01 PM   #152
03boxer4
Member#: 66622
2002 WRB wrx - Sold
Big White Jeep Unlimited
siiiiiiick.
Props to you and your attention to detail. :
03boxer4 is offline   Reply With Quote
Old 12-04-2012, 01:35 AM   #153
dundunskeert
Member#: 184151
2000 STI RA Limited
Originally Posted by TyConway View Post
Its 1.5" solid chromoly drilled out to 5/8" for the grade 8 bolt to go through. I've done several setups on rock crawlers with no issues, and thats bashing off rocks. I promise the steering rack tie rod would break first. pull the dust cover off and check it, the rod tapers down very tiny. That would break first. Actually Id put some money on it that my spacer and bolt is stronger than that factory tie rod that use to be there.
Its only 3/8" thick at the small point, i know the load is applied at a different angle on that, but I still don't have any concerns with my spacer. I saw the thread about the breaking part, I actually bought some similar for my rx7, they are cast and very brittle. More than likely that car that was pictured, was autocross and hit a hole or slid off the track, then you would expect damage like that.
Good stuff man!!! I can't wait to see this beast move!
dundunskeert is offline   Reply With Quote
Old 12-04-2012, 02:05 AM   #154
dundunskeert
Member#: 184151
2000 STI RA Limited
Thanks, should be the first turbo ls swap, as far as i know.
A friend of mine was working on one for a while, but sadly the project was never completed...
http://wrxatlanta.com/forums/showpos...&postcount=161
Old 12-04-2012, 02:07 AM   #155
TyConway
Member#: 193189
2002 wrx
3" 304 Stainless charge pipes welded up...
Old 12-04-2012, 02:14 AM   #156
TyConway
Member#: 193189
2002 wrx
Yea i've heard of a few that was suspose to be turbo, but never get finished.
But I plan to finish mine, and soon, and with quality, with nothing over looked. Like all the stuff i build, i build it right the first go around.
Old 12-04-2012, 02:21 AM   #157
TyConway
Member#: 193189
2002 wrx
Tried to get a few good close up pics with my digital camera but its about had it, been in too many wet and dirt caves lately.. so if my project doesn't get completed, its b/c i got stuck in a cave lol... but heres the only few that even turned out half decent.
just stuck back on to get a few pics.
Old 12-04-2012, 02:29 AM   #158
TyConway
Member#: 193189
2002 wrx
Also played with my clutch master cylinder... Gonna try the stock one first. Did a few mods to it, for 10 bucks, hell I'll try it. Welded up the stock line hole, redrilled on the side and welded a -4 An female bung to it. But I did this to gain the clearance i needed on the head, It had some contact , so it was either mod the master cylinder or the firewall. Heres what i came up with.
Also the part on the bottom, I tried to turn it again, after welding on it and it unscrewed off. Guess the heat let it come apart, Looks to just be a plug. So going to find out the thread pitch and see if i can just make life easy and screw in an adaptor, and just have a line off the bottom and cut the bung off the side. Why is it you always notice obvious stuff after the point... haha
Old 12-04-2012, 02:31 AM   #159
cpotokar
Member#: 309372
2012 wrx
Satin White
absolutely amazing build, subscribed
cpotokar is offline   Reply With Quote
Old 12-04-2012, 02:36 AM   #160
TyConway
Member#: 193189
2002 wrx
Also the oil pan depth is also going to be shortened up when the engine comes out to get built. But still where its at now it has more clearance than my ls1 rx7.
Old 12-04-2012, 06:41 PM   #161
TyConway
Member#: 193189
2002 wrx
the plug on the bottom of the clutch master cylinder is a m16x1.5, i couldn't find a m16x1.5 to -4 an fitting.
Already swapped the adapter to the bottom and cleaned it back up, be easier to route the line and a hidden look.
Old 12-04-2012, 08:04 PM   #162
cruisnhard
Member#: 254408
2008 Impreza WRX
Amazing build. This is what I like to see. Custom work!!!
Kudos to you Sir!
cruisnhard is offline   Reply With Quote
Old 12-04-2012, 08:42 PM   #163
TrunkMonkeyManiac
Member#: 175898
2002 Impreza
I know you probably are sick of hearing this but too bad! AWESOME! Simply awesome!
TrunkMonkeyManiac is offline   Reply With Quote
Old 12-04-2012, 08:44 PM   #164
BigRob74
Member#: 305107
2012 wrx
360/386 E85
awesome, any ideas when you think its going to be completed?
Old 12-04-2012, 09:10 PM   #165
TyConway
Member#: 193189
2002 wrx
not sure, just really depends on when some other stuff i have sells to free up some cash. Wanted to have it done by first of the yr / feb at the latest.
Old 12-05-2012, 03:17 PM   #166
soberpoet
Member#: 264784
Subaru Blue
dude amazing project definitely subscribing want to see this thing finished!!
soberpoet is offline   Reply With Quote
Old 12-05-2012, 04:00 PM   #167
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
how are you going to route the exhaust header from the far side of the engine?
also, why steel charge pipes? why not Al?
Old 12-05-2012, 04:15 PM   #168
TyConway
Member#: 193189
2002 wrx
right under the front of the oil pan by the steering rack. I built the driver side manifold last night but didn't take any pics yet.
V-bands on both manifolds, connected with 16ga 2.5" 304 stainless with a stainless flex coupler in the center.
I just like 304 stainless, shinny aluminum just looks cheap in my opinion... I don't mind paying a little extra for the 304 stainless.
The charge pipes along with the manifolds will be ceramic coated.
Old 12-05-2012, 04:17 PM   #169
eg33GC
Member#: 206851
56 Belair
Pro Street
how bad was welding that slave? looks like it was pretty good and didnt give much trouble
Old 12-05-2012, 11:03 PM   #170
TyConway
Member#: 193189
2002 wrx
well actually i cut it off and put the bung on the bottom, welded up fine, right now my welder is only on 120V, not 240, so i only have 125 amps to work with so takes a little bit to get heat up to lay a bead. When its on 180amps, it gets down to business fast. haven't done much aluminum though. only on my 3rd bottom of argon in my welder (newbie at tig believe it or not)
Old 12-05-2012, 11:50 PM   #171
. o 69 o .
Member#: 124938
Coolest build I have seen in a long time!
. o 69 o . is offline   Reply With Quote
Old 12-06-2012, 12:34 PM   #172
TyConway
Member#: 193189
2002 wrx
EDITED: using a Wilwood 7/8" compact
revised clutch master cylinder.
Old 12-06-2012, 12:35 PM   #173
TyConway
Member#: 193189
2002 wrx
Driver's side manifold.
Old 12-06-2012, 01:03 PM   #174
rich045
Member#: 210633
02 wrx
schedule 10 304?
rich045 is offline   Reply With Quote
Old 12-06-2012, 01:19 PM   #175
TyConway
Member#: 193189
2002 wrx
Originally Posted by rich045 View Post
schedule 10 304?
yes sir
