Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 12-04-2012, 03:46 PM   #1
WhatTurboLag?
Member#: 243992
2006 WRX TR
Default anyone or any shops local help with dccd controller install!
Need a hand installing my dccd controller. I suck balls at soldering and want to know It's gonna be perfect and oem looking! I have all the stuff I just need a hand Lol
Old 12-04-2012, 04:52 PM   #2
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
I'm sure thee would be someone on here willing to help you out with it, if not, then send me a jingle, I'd be willing to help you out depending on your time frames.
-Mark
APM Tuned is offline   Reply With Quote
Old 12-04-2012, 05:04 PM   #3
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
Find pigtails and solder those. Waaaayyyy easier.
Old 12-06-2012, 03:05 PM   #4
WhatTurboLag?
Member#: 243992
2006 WRX TR
I just have to solder into the ecu harness. No pigtails.
Old 12-06-2012, 03:10 PM   #5
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
pretty sure he was telling u a way to make it easier
Shortpersonbk is offline   Reply With Quote
Old 12-06-2012, 04:41 PM   #6
WhatTurboLag?
Member#: 243992
2006 WRX TR
Yes he was, but I didn't understand how or what he meant. If he was talking about vampire clips I don't want to use them
Old 12-06-2012, 06:56 PM   #7
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
okay, simply put...do you have pigtails? If not, why not source some pg tails to help the install be easier than chopping up the harness, extending some wiring and doing a "hard solder".
If you have the pig tails, and you have the wiring setup, do you require finding the pin outs or diagram and soldering into that with the new DCCD controller on the WRX?
Two different things going on there. No controller with ready wiring, no controller and wiring required.
I'm only asking as to the extent of the work is all.
-Mark
Old 12-06-2012, 08:13 PM   #8
JarHarms
Member#: 138994
06 WRX Ltd
02 Forester S
Pigtails are either OEM harness connectors (or just the OEM pin terminals with a length of wire crimped on) and are only going to simplify things if he is installing the OEM STI manual and thumb wheel switches. Even then I highly suggest installing it as-delivered since Jeff tests them before shipping. Once it is working fine then alter the switch configurations to your will.
The tap he is referring to is the TPS signal taken at the harness near the ECM connectors. 2006 WRX probably circuit B134 on pin B18 (RL colored wire), break out the DMM and check for signal change as you actuate the pedal. There are two wires with VERY similar insulation colors on that connector. If it looks good then remove some insulation, solder in, and wrap with e-tape.
Fusebox terminals might also help achieve an OEM-look for the power connection. You can use an existing and unused circuit, which will get you a factory fuse that is already there (hint fuse #18, 15amp, connector B271, pin B2) and supplied pwr at key ON and START.
v Thanks!
vv I completely understand that
JarHarms is online now   Reply With Quote
Old 12-07-2012, 11:52 AM   #9
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
^ VERY NICELY SAID!
-Mark
Old 12-07-2012, 12:11 PM   #10
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
I just wanted clarification as to which setup and how he's figuring of wiring it in.
-Mark
