Old 12-07-2012, 02:02 PM   #14801
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Those of us who have replaced our head units are very familiar with this process.
Old 12-08-2012, 04:44 AM   #14802
Penguin44
Member#: 315883
2012 IMPREZA
Sorry if this is in the wrong section but didn't know where else to put it. 2012 impreza 5 door base model. Funny thing happened just now. My car is off, been off for almost seven hours. Taking a walk I hear a noise from the car. Like a small electric motor running or an electric fan coming from the left rear. I ran and grabbed my keys and when I turned the car to acc it stopped. What the heck is this? The car is off!
Edit, it was super quiet outside so I heard it. Usually I wouldn't have.
Penguin44 is offline   Reply With Quote
Old 12-08-2012, 08:15 AM   #14803
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I haven't heard it on my Impreza, but my TDI did the same thing. Cars these days have so many systems that monitor many different things all the time. I would assume it's normal.
Old 12-08-2012, 08:42 AM   #14804
Angelus911
Member#: 89967
2012 Impreza Sport
It's the emissions system
Old 12-08-2012, 02:47 PM   #14805
Penguin44
Member#: 315883
2012 IMPREZA
Emissions system? Explain how that could be.
Old 12-08-2012, 02:49 PM   #14806
Penguin44
Member#: 315883
2012 IMPREZA
I thank you for your help! Put my mind at ease
Old 12-08-2012, 03:01 PM   #14807
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
Old 12-08-2012, 04:13 PM   #14808
kinger37
Member#: 324423
2012 Impreza Sport
ISM
Anyone know how to remove the roof rails on the 2012 impreza sport? I'm in the process of installing some spot lights on my cargo basket and would prefer not to drill through the roof. My plan is to go through where the roof rails connect. Any suggestions would be much appreciated.
kinger37 is offline   Reply With Quote
Old 12-08-2012, 04:27 PM   #14809
Zeeper
Member#: 299286
2015 WRX CVT
You need to pull out the headliner and deal with all the holes left when you pull the rails. Someone here has already removed the rails, they can give you all the relevant info.
Zeeper is online now   Reply With Quote
Old 12-08-2012, 04:47 PM   #14810
kinger37
Member#: 324423
2012 Impreza Sport
ISM
^^ Thanks, do you think this is my best option for wiring? I would really prefer not to have a visible drill hole through my roof. Any suggestions?
Old 12-08-2012, 07:45 PM   #14811
danstheman7
Member#: 331089
2012 Impreza Base
DGM/Dark Grey Metallic
I've installed rails in a base impreza. The drill holes I had to drill were very tight, so I'd say it's unlikely you'll be able to fit a wire through the screw hole. Not only that, but i'd be wary of water leakage. The holes must be watertight with some type of sealant after rail removal.
Also, you need the bars for non rail impreza's.
danstheman7 is offline   Reply With Quote
Old 12-08-2012, 08:27 PM   #14812
Angelus911
Member#: 89967
2012 Impreza Sport
All I know is that there's something that sounds like a fan that runs to reduce emissions. It's in the owners manual as well
Old 12-08-2012, 09:02 PM   #14813
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Yes you are correct. I was able to catch it on video:
Old 12-08-2012, 09:19 PM   #14814
Zeeper
Member#: 299286
2015 WRX CVT
leave the rails and run the wire out next to the inside of one of the rails, then forward to the lights. You will still need to remove the headliner to run the wire (I think).
Old 12-08-2012, 09:42 PM   #14815
kinger37
Member#: 324423
2012 Impreza Sport
ISM
Sorry I'm not really understanding what you are saying.
I plan on leaving the rails on, just want to take them off to run the wires into the car under the rails and then put them back on.
Where are you suggesting I run the wires into the car?
Old 12-08-2012, 09:54 PM   #14816
Zeeper
Member#: 299286
2015 WRX CVT
Leave the rails as is, drill one hole next to the inside of a rail and run two black wires along the inside of the rail, you will need one hole, and need to run wires inside the car obviously so you will need to pull the headliner.
If you are putting on lights, you need a dedicated line to the battery so you don't fry anything (like the fuse for the dome light). But you could trace that wire down and run your wires next to it.
With the rails on you are not going to see a wire on the inside of the rail unless you are really trying...
Old 12-09-2012, 01:52 AM   #14817
Penguin44
Member#: 315883
2012 IMPREZA
Video Link: http://www.youtube.com/watch?v=-OssZCkVALQ
Yup that is the sound. Thanks for the video. Now I don't have to worry
Old 12-09-2012, 05:55 AM   #14818
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Originally Posted by subiedude676 View Post
Thanks for the replies.. That's what I thought it might be for but I'm unable to find a light online to purchase for that spot. What would it connect to as a power source if there was a light available?
Also for anyone interested in a footwell illumination kit for our 2012-2013 impreza models I've come across this:
http://techinfo.subaru.com/proxy/700...SFJ100Rev1.pdf
It's listed under the 2013 accessory installation guide, but I don't see why it wouldn't work on a 2012 model as well. It's about $120-130 online from what I have found.
That's pretty expensive for some wires and LEDs and it looks like a pain to install too.
Old 12-09-2012, 06:55 AM   #14819
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
How long does the sound last? On the TDI I had, the sound it made when the car was off only lasted 1 or 2 sec.
Old 12-09-2012, 07:10 AM   #14820
Zeeper
Member#: 299286
2015 WRX CVT
It stays on a while, long enough to hear it, and spend a little while walking around the car to try and figure out where it is originating. It may be a PZEV thing -- mine does it randomly and sometimes long after the car has been driven.
Old 12-09-2012, 08:05 AM   #14821
LGA2011
Member#: 321173
I just got my driver license. I felt like sharing my driving with my Canadian CVT Impreza.
Canadian Model with eco display(night is the cause of blurry display. I will do another drive later)
2:16 Manual mode
7:37 Automatic mode (interesting RPM needle)
LGA2011 is offline   Reply With Quote
Old 12-09-2012, 04:49 PM   #14822
Penguin44
Member#: 315883
2012 IMPREZA
Seemed to go for at least 15min and this was hours after driving. Btw I don't have a pzev
Old 12-09-2012, 05:15 PM   #14823
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Wow, 15 min?!
Old 12-09-2012, 05:23 PM   #14824
Kharn
Member#: 306129
What is the deal with the remote start for late '12s and all '13s? A little research seems to say Subaru stopped selling the remote starter that was offered for the '12s at launch, then they came out with a new one? My dealer said they could install one on a '13, but I'd end up with one remote for the doors and another for the starter?
Kharn is offline   Reply With Quote
Old 12-09-2012, 05:36 PM   #14825
sport6
Member#: 190479
2015 XV Crosstrek
2012 Impreza- Deep Cherry
Well a word or warning for those in the wooded areas.. My wife has been hearing an acorn rolling around inside of the hood. I confirmed it was actually inside the hood, little critter must have gotten in through the two 2" holes near the windshield cowl.
So I finally got around to fishing those acorns out. Took off the heat blanket on the underside of the hood.... The critter had full access to get under the blanket from within those two holes. It had chewed a big of the blanket and collected a nest at the base of the hood channel. The critter wasn't around but with the blanket off I was able to easily clean it out and get the bits of acorn out.
I have covered those two holes with some tape and hope that's enough or a deterrent to keep it away.
sport6 is offline   Reply With Quote
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
