Old 12-07-2012, 01:07 PM   #1
gabelikefaria
Member#: 316383
2005 impreza wrx sti
aspen white
Question 05 sti coolant on floor board driver side
hey guys i have an 05 sti and the ac compressor started going bad the clutch wouldnt turn so i got rid of it last night just took it out temporarily. i also noticed before i changed it the ac vents were smoking and i kept smelling a funny smell which seemed like free on but not sure and then when i got out i noticed a puddle of green fluid by my feet and was slowly dripping down the side and when i wiped it was green...i dont know if this is the rest of the free on from the compressor lines or what it is? evaporator? suggestions? thanks
gabelikefaria is offline   Reply With Quote
Old 12-07-2012, 01:21 PM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
It could be the refrigerant if it had die in it. It could also be coolant if your heater core is leaking.
Old 12-07-2012, 01:25 PM   #3
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
You have a cracked heater core.
I would suggest you search how to bypass it to save your head gaskets and lube your bumhole for what will be an expensive repair.
i_c_the_light is offline   Reply With Quote
Old 12-07-2012, 01:30 PM   #4
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
+1 for heater core.
Old 12-07-2012, 02:18 PM   #5
Member#: 301037
2004 Forester XT
+2 for heater core
art@grimmspeed is offline   Reply With Quote
Old 12-07-2012, 02:34 PM   #6
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
+3 for heater core.
Also, make sure you save that free on. On is not cheap, and most people have to pay for their on.
Old 12-07-2012, 02:40 PM   #7
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
take your glove box out and see what is going on there....could be as simple a loose heater hose.
AliBenn is offline   Reply With Quote
Old 12-07-2012, 02:41 PM   #8
SlowTrackImpreza
Member#: 262692
1999 GC ej217 WRB
22b widebody built fp red
if your compressor indeed went bad, its generally from the intake valve on the pump being blocked.
this causes excess pressure to build in the system and rupture the evaporator that is in the cabin. it looks ALOT like the heater core, just has a couple copper tubes with thermistors on it.
I doubt the heater core is bad, that is directly behind your radio on the firewall inside the cabin.
the evaporator can be changed by just taking out your glove box, which will reveal a black box with a kinda roundish look to it. the evaporator will be inside that box.
I would however recommend taking your dash out to make it a hell of alot easier and you will be able ot clean up the excess
SlowTrackImpreza is offline   Reply With Quote
Old 12-07-2012, 03:18 PM   #9
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Originally Posted by Loyale93 View Post
+3 for heater core.
Cars haven't used freon in nearly 20 years. And R-134A isn't that expensive.
Old 12-07-2012, 03:19 PM   #10
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
Methinks you might have missed the joke...
Old 12-07-2012, 03:53 PM   #11
gabelikefaria
Member#: 316383
aspen white
alright so the heater core is behind my radio correct? basically need to take it all out to get to it along with my glove box to see check the evaporator?
Old 12-07-2012, 06:50 PM   #12
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Anytime green **** pools in the cabin it's going to be the heater core.
Old 12-07-2012, 07:00 PM   #13
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
I can agree with this.
Old 12-07-2012, 08:50 PM   #14
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
When an ac system has a leak and we cant find it in the shop we add a die and it is green. If the ac has die in it then it would be green. So it could be ether one.
Old 12-07-2012, 08:56 PM   #15
gabelikefaria
Member#: 316383
aspen white
My heater core is busted somebody please help me with some info to get it out.... I have the whole dash out cluster and all I can't move the stupid core it doesn't want to come out
Old 12-07-2012, 10:27 PM   #16
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Holy ****. So you just pulled the dash out?
Old 12-08-2012, 12:09 AM   #17
gabelikefaria
Member#: 316383
aspen white
Yeah I took the whole thing out piece by piece only to think to just bypass the stupid thing. Is there a way to dim the cluster? Mine looks really dim
Old 12-08-2012, 02:45 AM   #18
J-hop
Member#: 318428
OP did you seriously freaking remove the A/C without having the system purged at a shop... That stuff can kill you. Why the hell do companies supply MSDS if no one bothers reading them..........
J-hop is offline   Reply With Quote
Old 12-08-2012, 06:30 AM   #19
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Umm not if you cut the lines and GTFO for 5 minutes.
Old 12-08-2012, 07:04 AM   #20
gabelikefaria
Member#: 316383
aspen white
That's what I did ^^^
Old 12-08-2012, 11:05 AM   #21
J-hop
Member#: 318428
Are you guys serious? a shop will probably charge you like $50 to evacuate the system, well worth avoiding a serious health hazard.
At the very very very least I hope you both did it outside, doing it in a garage would deserve a quadruple face palm.
Old 12-08-2012, 12:05 PM   #22
gabelikefaria
Member#: 316383
aspen white
50 bucks in my pocket. Ended up just by passing it
Old 12-09-2012, 03:57 AM   #23
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
It's actually not that bad. Just cut the lines and go make a coffee, or something.
Old 12-09-2012, 12:14 PM   #24
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Did you read the MSDS? Unless you discharge in an extremely small enclosed area with yourself inside of it, it's not going to harm you. Even in a closed garage you are probably going to be fine.
RP31 is offline   Reply With Quote
Old 12-09-2012, 12:37 PM   #25
J-hop
Member#: 318428
Yes I did, I guess with people spraying brake clean in poorly vented garage spaces without wearing respirators the effects of r134a seem pretty minimal.
I still wouldn't recommend venting the refrigerant but I guess if that's the way you do things go for it! Hell run your car in the garage for a while and get some carbon monoxide going as well. That stuff doesn't kill people either!
