Old 12-06-2012, 10:47 AM   #1
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Default RalliTEK Sways: Worth it to upgrade from "Street" to "Track" on stock Springs&Struts?
So, I currently have RalliTEK's "Street" kit, 22mm F / 19mm R, solid sway bars, and while they did make a huge difference over stock, there's still a bit of body roll in, dare I say, 'violent' cornering, and the overall setup would not be acceptable for auto-x. Not that I auto-x, or plan to, but just to paint a picture...
I kind of want to stay on stock springs and struts, but I want a little bit more of a planted/communicative/immediate feeling. I know 18's and some PSS tires will do half of this, but I'm still curious if I should upgrade to the 25mm F / 22mm R sway bar kit?
Will it make a huge difference? I'd hate for the whole thing to be a wash...
blehhh is offline   Reply With Quote
Old 12-06-2012, 04:58 PM   #2
Maddies Daddie
Member#: 298565
2008 STi
I have the 25mm / 22mm set up on my 08 sti(stock springs). I was thinking of going to a softer front bar. I auto x and still have understeer. I have to run about 4 psi less in the front to compensate for this. I am on all season tires though and still so very well against the competition that are on performance summer tires. So I know they help. I just want to see what a smaller bar up front will do. Oh and sometimes I get the skipping on really rough turns. Hope this helps.
Maddies Daddie is offline   Reply With Quote
Old 12-06-2012, 05:09 PM   #3
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
hmmm.... would be interesting to see what would happen if I can swap out just the rear and run 22 / 22.... I doubt RalliTEK would sell me just the rear bar, straight up, but maybe I can pick up a Whiteline 22mm rear, that's assuming both companies have the same arm geometry->eccentricty->torsional stiffness.
EDIT: Okay, my plan is definitely exactly that. I'll pick up a Whiteline 22mm Adjustable Rear Sway Bar and try to sell my 19mm RalliTEK.
Old 12-07-2012, 04:45 PM   #4
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Anyone else running equal sways?
How big of a concern is something like "snap-oversteer" on the highway if I'm running equal sized sway bars, 22mm f&r?
I don't auto-x or track my car, I don't think I'd mind a little oversteer around town, but my main desire is just less body roll than what my 22/19 setup allows, and for it to not be dangerous.
Old 12-07-2012, 04:48 PM   #5
the_saintusa
Member#: 171486
2004 WRX STI
Originally Posted by blehhh View Post
Okay, serious question:
anyone else running equal sways?
If you are driving seriously, snap-oversteer should NEVER be a problem on a highway.
On a track or at an autocross event, then it may be an issue. Usually excessive driver input will be the cause.
Although errant deer or wildlife may create a similar situation.
the_saintusa is offline   Reply With Quote
