Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC
Old 12-07-2012, 06:41 PM   #1
Dillinja666
Member#: 332644
07 STI
It's white
Default Boost Control Solenoid
Anyone have a stock 07 boost control solenoid I can try on my car to see if my stock one is going out or my turbo is failing. I just need to plug it in a do a pull real fast. Im in San Diego but can travel a little ways to meet up. It would really help me out.
Dillinja666 is offline   Reply With Quote
Old 12-07-2012, 06:46 PM   #2
TheFugitiveMind
Member#: 98012
2006 Aspen White STi
2015 XV Limited - Orange!
usually you will get a code if the BCS is failing. you can pull the vacuum line off the turbo and see if it will boost to your tune. Be careful though, once you remove that line there is nothing controlling the wastegate and you will overboost like a mother...
TheFugitiveMind is offline   Reply With Quote
Old 12-07-2012, 07:26 PM   #3
Dillinja666
Member#: 332644
07 STI
It's white
Ya it hit 25lbs before I got off the throttle. I had an oil issue and got oil sucked into the into the intake system ( used too thin oil, loooooooooong story) and there is oil in the boost control valve. I wanna just try one out before I buy one. I hit 10.6 lbs of boost with it hooked up and target is 15lbs. Here is the log
https://docs.google.com/spreadsheet/...nRua0QyMlk4NHc
