Old 02-22-2012, 03:31 PM   #101
pretendingtowork
Member#: 202743
08 WRX Sedan
Looking forward to pics. Let me know how it handles with the sways as well.
pretendingtowork is offline   Reply With Quote
Old 02-22-2012, 06:21 PM   #102
Vaughn Performance
Member#: 170489
Just to clarify, what Thomas (pretendingtowork) is running are the Feal inserts/shock combo valved for gravel, paired with king 1.5" lift springs. They have a progressive rate about 30% higher then stock.
What I'm running on my car are revalved for gravel (by Feal) 04 STi struts and king lift springs.
Odi also has a strut insert option for us older chassis cars as well, very similar to what Thomas is running up front, but insert's all the way around rather then the shocks in the rear. A good solution for older chassis folks looking to upgrade to a good damper for RallyX but don't want to source a set of 04 STi struts. Those paired with Kings would be a good combo as well for the older chassis guys. It's all stuff based on dampers meant to withstand the punishment of rally use, so a good choice for RallyX folks!
-Anthony
Vaughn Performance is offline   Reply With Quote
Old 02-22-2012, 06:26 PM   #103
pretendingtowork
Member#: 202743
08 WRX Sedan
Yeah, Anthony is a suspension guru. The guy I go to for anything suspension related. Listen to him for the technical talk.
Old 02-22-2012, 11:19 PM   #104
gregroot198521
Member#: 280844
2006 STi
Alright, sweet, I'll be running the same setup as Thomas then, just on a little newer 3rd gen, so I should enjoy the same type of a ride then. Curious how much the sways (22mm front & 19mm rear Rallitek sways) I'm getting will mess with the ride though. Guess it'll be good in both on & off-road, but not the greatest at either.
gregroot198521 is offline   Reply With Quote
Old 02-23-2012, 03:42 PM   #105
Vaughn Performance
Member#: 170489
Ride will be fine on normal paved roads. You're not really going to loose any ride comfort at all. Offroad, you'll lose a bit of wheel independence when going over large bumps, but it will still work well. Especially if you're running a fairly grippy dirt tire. I run 22mm front/rear bars on my wagon and it still feels like it works well still in the dirt.
-Anthony
Old 02-23-2012, 09:43 PM   #106
gregroot198521
Member#: 280844
2006 STi
-Anthony
Alright, cool, that's what I thought. Thanks for confirming my thought process Anthony.
Old 02-27-2012, 02:16 AM   #107
gregroot198521
Member#: 280844
2006 STi
Well I got them put in today, wasn't too hard, mainly because Odi put the Kings on the struts for me and then shipped them out (thanks Odi!!!!). Job took a total of 4 hours, and that includes the trip to O'Reilly's to get a breaker bar for the rear strut's lower bolt. It looks pretty badass with the awesome (fistable+) wheelgap. I still need to adjust the rear struts, as they are sitting just a little higher than stock right now, but I need to find a spanner wrench that fits first. Tomorrow I'll continue the hunt. I'll post pics after completion.
Old 02-27-2012, 03:22 PM   #108
Feal Suspension
Member#: 227414
Greg,
Your spanner wrenches are on the way, no need to buy anything.
-Odi
Feal Suspension is offline   Reply With Quote
Old 02-27-2012, 08:52 PM   #109
gregroot198521
Member#: 280844
2006 STi
Originally Posted by Feal Suspension View Post
Greg,
-Odi
Sweet!! Thanks even more Odi!!!
Old 03-05-2012, 11:06 PM   #110
gregroot198521
Member#: 280844
2006 STi
Adjusted the rear struts up by an inch and a quarter. I'm sitting at ~4.5" of wheel gap in the front and ~4" in the rear, so I need to do a little more adjustment in the rear (~.5") and I'll be happy.
Old 03-06-2012, 06:31 PM   #111
Vaughn Performance
Member#: 170489
^^Looking good!
Old 04-04-2012, 01:55 PM   #112
pretendingtowork
Member#: 202743
08 WRX Sedan
My Feals and Kings helped me get another 1st at my rally x last weekend. Gave the suspension a once over and it seems to be holding up just fine.
Anthony got 3rd on his Feals and Kings also.
Old 04-04-2012, 02:52 PM   #113
gregroot198521
Member#: 280844
2006 STi
My front right one blew last week after only 600 some miles. Sent both and should be to Odi tomorrow. Hopefully he can figure out what went wrong and get them back to me quick. Guessing one of the seals or something wasn't aligned or something. Wasn't even off-roading at all last week before it happened.
Old 04-04-2012, 04:50 PM   #114
pretendingtowork
Member#: 202743
08 WRX Sedan
Yeah, you had mentioned that, which is why I wanted to do a quick once over on my suspension to see what condition it was in. Aside from being super dirty it seemed fine.
I wonder how Anthony's suspension is holding up?
Old 04-04-2012, 04:59 PM   #115
gregroot198521
Member#: 280844
2006 STi
Ah, you read it over on DI? Glad yours is good though. I'm figuring it's like I think it is, hopefully it's nothing bigger than a seal or something.
Old 04-04-2012, 06:45 PM   #116
Vaughn Performance
Member#: 170489
Mine felt great all weekend! Worked really well actually. This is the 2nd RallyX on these now as well as some in between event shenanigans and their holding up great.
Yeah they should take a pretty darn good beating. Whatever the issue was with them I'm sure Odi well get them sorted for you no prob.
-Anthony
Old 04-04-2012, 07:22 PM   #117
gregroot198521
Member#: 280844
2006 STi
-Anthony
Glad to hear yours are still good too.
Can't wait to get mine back and back in. I'm getting the feeling I will need some dirty time soon. Maybe I should get my backup stockers revolved for some backup with the proper fit, and get a set of spring compressors.
Old 04-21-2012, 12:40 AM   #118
jfarcticman98
Member#: 284675
08 wrx sedan
obp
hey I was wondering when you guys are going to release the coil overs for the 08+ chassis??
jfarcticman98 is offline   Reply With Quote
Old 12-07-2012, 08:03 PM   #119
cystem
Member#: 293753
I just wanted to post up here as im running Gregs old struts. Sent them in to Odi, seems there as a o-ring that got goofed on the last rebuild but he got them back to me real quick i was very pleased. This weekend is rally-x time so we shall see how then hold up.
cystem is offline   Reply With Quote
Old 12-07-2012, 08:09 PM   #120
gregroot198521
Member#: 280844
2006 STi
You taken her out for a run yet?
Old 08-01-2013, 02:30 PM   #121
STIdarkside
Member#: 222527
2013 Forester XT
Ice Silver Metallic
Would something like this be possible for 09-13 forester xt struts and shocks?
STIdarkside is offline   Reply With Quote
Old 08-11-2014, 04:56 PM   #122
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
reviving and old thread
pretendingtowork, the old links are broken... can you update? I'd like to see them.
Feal... are these inserts still offered?
Alternatively, if I sourced a set of GR STI struts I take it you guys could to the custom valve? Never mind I realize now the STI 5x114 knuckle has a difference cleavis mounting pattern.
chimchimm5 is offline   Reply With Quote
2008 WRX Stage 1 Datalog and map table tweaks Turbo.steve AccessPort 0 09-02-2011 08:48 AM
2008 wrx brake upgrade dwallace Brakes, Steering & Suspension 2 08-24-2011 08:00 AM
2008 WRX HID upgrade point3 Electrical & Lighting 121 04-12-2011 07:02 PM
2008 wrx turbo upgrades, and questions TMIC Sedlmeier101 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 07-28-2009 02:33 PM
Looking for 2008 WRX suspension upgrade 2008wrx Newbies & FAQs 11 06-10-2008 10:16 PM
