Welcome to the North American Subaru Impreza Owners Club Tuesday May 31, 2016
Old 12-04-2012, 06:45 PM   #1
Boobaru03
Member#: 325985
2003 WRX
Midnight blue
Default 16gXT tuning question
Ok so I recently installed a blouch 16gXT turbo, DW 1,000cc injectors, walbro 255 fuel pump and a Cobb ap tuner, and a shop local to me basically f@$&ed me over,
I had had my car tuned in jersey and with stock turbo, injectors, fuel pump, and a perrin catless up-pipe and down pipe, aem short ram intake and full race 3" turbo back exhaust I put down 220awhp and after my new mods which my previous tuner said would make around 300-350awhp the ****ty tuner I went to said my car put down 250awhp @ 19psi( oh and they also told me after I made the appt to use my cobb ap as a tuner that they could only use open source)
I'm not a rocket scientist but these numbers don't really add up?!
And also on the ride home I tried playing with it and I went for full boost and it peaked then dropped to 15-16psi then shot back to 19 then back down to 15-16, I am so heated at this "conservative" tuner as he called himself that I want to flip!!! I spent $3,000+ for 30hp?!?
Any one have any insight?
Boobaru03 is offline   Reply With Quote
Old 12-04-2012, 09:26 PM   #2
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Well it sounds like they did not do a very good job, reputation is everything when selecting a shop/tuner.
lukeskywrx is offline   Reply With Quote
Old 12-04-2012, 10:10 PM   #3
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
id look into nightshift performance, junior is an amazing tuner. With that setup from what I've seen you can expect about 300whp and 300wtq. You probably could sell the AP and go opensource too but I'd see what junior says. Give them a call.
freddy121389 is offline   Reply With Quote
Old 12-05-2012, 10:36 AM   #4
Boobaru03
Member#: 325985
2003 WRX
Midnight blue
Damn that would be great if I was still living in jersey, I had to move back down to East Tennessee, and I'm trying to find a good tuner with a good rep down here
Old 12-05-2012, 12:51 PM   #5
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
Top Speed is supposedly a good place, that's where Rsutton got his car tuned its in Alpharetta, GA. I don't know who the tuner is but he made almost 400whp on the stock block before it blew up (Too much power, not because of bad tune)
Old 12-05-2012, 01:17 PM   #6
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
The tuner shouldn't be tuning it past block power levels unless it's a racecar/requested by customer.
Jubert69 is offline   Reply With Quote
Old 12-05-2012, 03:45 PM   #7
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
#'s sound fine. You're expecting much too much out of that turbo. 20G's usually see 300whp on a mustang dyno. Dyno to dyno numbers vary sooo much, dont even try and compare.
If you want to make the drive to Georgia for a retune or an e-tune, PM dux10 / Pullz-On tuning. Awesome tuner, great to work with.
Old 12-05-2012, 04:15 PM   #8
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
My 20g only puts down around 300whp with meth, cams, tvg deleats ang el headers. For a 16g that looks about right on pump. If you want 300-350 go e85.
Old 12-05-2012, 04:20 PM   #9
eg33GC
Member#: 206851
56 Belair
Pro Street
I trapped about ~320whp worth of speed with an evo3 7cm.. whoever has these 20gs on pump only at 300whp should really reconsider.
Old 12-05-2012, 08:48 PM   #10
Boobaru03
Member#: 325985
2003 WRX
Midnight blue
Yeah the tuner that I used in jersey specialized in subaru tuning, they did other vehicles but they are mainly subaru and those are the numbers that they told me, and SHOWED me on one of the workers vehicle. He had an 03 Wrx with the exact same mods on 92 octane pump gas making 348awhp on stock internals. And that was at 21psi, and they were the ones that told me exactly what to get to make those bumbers
Old 12-05-2012, 09:09 PM   #11
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
LOL don't compare dyno to dyno. Just dont.
Old 12-06-2012, 07:00 AM   #12
Boobaru03
Member#: 325985
2003 WRX
Midnight blue
I understand don't compare dyno to dyno but would the numbers be THAT far off?
Old 12-06-2012, 08:06 AM   #13
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Could be. 348whp is insane for a 16G stock motor car on any dyno.
Old 12-06-2012, 08:29 AM   #14
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
customer requested it im sure, he had money waiting for a built block
Old 12-06-2012, 09:10 AM   #15
quazimoto
Member#: 70395
What does a typical stage 2 2.0L WRX put down on thier dyno?
In what gear did this happen? I would have done a "hybrid" boost control or just a straight MBC.
Old 12-06-2012, 01:31 PM   #16
Boobaru03
Member#: 325985
2003 WRX
Midnight blue
He never told me any numbers on the other ones just that that's how he tuned the others.
And I have a grimmspeed 3 port ebcs
Old 12-07-2012, 05:45 PM   #17
SubiSam
Member#: 156401
'03 WRB WAGON
2.1 stroker GTX3071R
Need to decrease WGDC. Seems as if he forgot to do this. I wouldn't be happy either, regardless of what numbers it put down.
SubiSam is offline   Reply With Quote
Old 12-07-2012, 06:31 PM   #18
alexmartynyuk
Member#: 191967
2002 wrx
Captain America tuned
+1, Steve tuned my car a while ago and and I still have the same setup and beat the car to death daily with 120k on the clock and no issues to this day. I regularly datalog to make sure nothing is out of place and I have never seen anything out of order. Highly recommend getting tuned by him.
alexmartynyuk is offline   Reply With Quote
Old 12-07-2012, 06:58 PM   #19
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Regardless of peak numbers, this necessitates a refund or fix. Log it and RAISE ABSOLUTE HELL.
Old 12-07-2012, 07:18 PM   #20
Boobaru03
Member#: 325985
2003 WRX
Midnight blue
I am going tomorrow morning to get this issue resolved and to get my car tuned they way that I wanted it to be when I first made the appt. with this tuner (using my cobb ap tuner) I have talked to Cobb and found that the tuner lied to me in more than one way on this matter. Will let you all know what goes on after tomorrow
Old 12-07-2012, 07:20 PM   #21
Boobaru03
Member#: 325985
2003 WRX
Midnight blue
Oh and I also cannot log anything because of how the tuner screwed me over regarding his "not renewing his license to use cobb software" which I found out was a huge lie and that once you purchase the software it's yours. So I will be having my car tuned with Cobb tuning software and not crappy opensource.
Old 12-07-2012, 07:43 PM   #22
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
Noob....
nightcrawler60 is offline   Reply With Quote
Old 12-07-2012, 10:49 PM   #23
Boobaru03
Member#: 325985
2003 WRX
Midnight blue
Originally Posted by nightcrawler60 View Post
Noob....
Well since you're such an expert, what makes opensource such a great tuning software??
Old 12-07-2012, 10:54 PM   #24
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
On an '02/'03 its 99% identical to cobb. '08 + or any SD, yes I'll admit, cobb is superior.
Old 12-07-2012, 11:05 PM   #25
Boobaru03
Member#: 325985
2003 WRX
Midnight blue
Well unlike opensource, you can tune with Cobb in REAL time and them save, but with opensource you have to do a run then tune to the specs you need then run it again. So no it's not the same not even close.
