Welcome to the North American Subaru Impreza Owners Club Saturday August 23, 2014
Old 08-13-2004, 04:04 PM   #101
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
I have two extra ABS sensors that fit GD's, if you want to check my FS thread...
Cronic knows the what's what with my car.
Did you check out that map, Dave?
-Sean
big_adventure is offline   Reply With Quote
Old 08-13-2004, 04:48 PM   #102
cronic
Member#: 9749
-Sean
No i was feeling generous and let my fiance' take the car to her aunts for the weekend She will be back tom sometime then i will try to load it..
Thanks man!
Dave
cronic is offline   Reply With Quote
Old 08-13-2004, 04:53 PM   #103
big_adventure
Member#: 40501
One WheelSeanPower
That WAS generous. That said, my girlfriend is about the only one I trust to drive my car without me in it to supervise, preferrably heavily armed.
-S
Old 08-13-2004, 04:55 PM   #104
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
When I swapped my rear brakes into a OBS all I did was remove my ABS sensor and plug in the ones that came on the OBS. The physical mounting is exactly the same, and works perfectly.
pegdrgr is offline   Reply With Quote
Old 08-13-2004, 05:04 PM   #105
YumGTR
Member#: 63779
1989 BNR32
what about the programming in your stock ABS computer that tells the stock ABS modulator what to do and when to do it? that code is meant for the smaller stock brakes. it doesn't whig out or throw a code? it can't be the safest thing to use brakes from another car along with ABS computer programming for stock brakes, but i guess people that upgrade their brakes using aftermarket rotors and calipers are in the same boat. just a thought...
YumGTR is offline   Reply With Quote
Old 08-13-2004, 05:09 PM   #106
cronic
Member#: 9749
-S
Yea it just sucks because i have the wastegate so tight it wont go under 19.5psi, she knows not to get on it though, and even if she did i doubt she would do long pulls, grrr now i am this has me thinking about my baby, i hope she is ok
Old 08-13-2004, 05:16 PM   #107
big_adventure
Member#: 40501
One WheelSeanPower
As long as the balance and proportioning are close, it's no big deal. You MIGHT see issues if you had 13" rotors in the back and 11" rotors in the front. Oh, wait, I actually DID have that for a while, and still didn't have any issues. I avoided emergencies.
Anyway, with the Brembos and the grippy-as-he77 pads I have, there almost isn't any need for ABS. I have an 04, though, so I have EBD anyway, making it even better.
-Sean
Old 08-13-2004, 05:17 PM   #108
big_adventure
Member#: 40501
One WheelSeanPower
Even if she does, man, your car can hold 19.5psi for like an hour before it has a problem. My turbo is blowing something like room temperature at that pressure.
-S
Old 08-13-2004, 05:24 PM   #109
cronic
Member#: 9749
-S
Sean, keep rubbing your gt30r inm and one day you will wake up and your precious wagon will be gone and this will be in its place!
Old 08-13-2004, 05:28 PM   #110
big_adventure
Member#: 40501
One WheelSeanPower
I could trade having the fastest blue wagon down here for the fastest yellow sedan! Those wheels look sweet. Everything under the hood looks pretty familiar.
But NNOOOOOOOOOO, NOT the PRECIOUSSSSSSSS! He cants HAVE the PRESCIOUSSSSS.
I gotta get outta here...
-S
Old 06-23-2012, 02:43 AM   #111
benchaloupka
Member#: 321987
Great Swap ! I'm doing a front Brembo Caliper Swap on my 2004 wrx wagon. I have 17" aftermarket rims but they don't clear the big Brembo calipers. I need to get new rims with a different offset. Do you know what the offset is on your rota rims ?
-Ben
benchaloupka is offline   Reply With Quote
Old 06-23-2012, 03:02 AM   #112
ramrod1337
Member#: 259542
2009 cobalt ss
summit white
Hopefully I will get to do this swap to my bugeye. Any estimation on price for sti drivtrain, hubs axles diffs and all?
ramrod1337 is offline   Reply With Quote
Old 06-23-2012, 03:09 AM   #113
meanjoaquin
Member#: 309723
this thread is from eight years ago
meanjoaquin is offline   Reply With Quote
Old 12-08-2012, 03:53 AM   #114
Seattle_WrxWagon
Member#: 334326
Dope wagon! i have an 04 wagon that i am swapping a vers9 jdm sti motor into and cant seem to get her to run smoothly after firing her up. I am done with the mechanical side of the swap as well as installed the avcs wiring kit but still not able to get the motor to run smooth as it should... When I fire it up it has a really hard idle and the check engine light continuously flashes off and on...any idea as to what could be causing this?
giff_piampanichwat@hotmail.com
Seattle_WrxWagon is offline   Reply With Quote
05 STI swap into 04 WRX Wagon. HELP! pismobeachrider25 Built Motor Discussion 6 04-12-2010 09:58 AM
Full USDM STi Drivetrain into MY06 2.5i Boosted WRX STi Subaru Conversions 12 05-02-2008 09:15 PM
OEM 04 STI suspension into 05 WRX wagon javi-sti Newbies & FAQs 3 11-05-2007 01:17 PM
STi drivetrain into 07 WRX St3fan Newbies & FAQs 10 02-12-2007 11:58 PM
sti tranny into 04 wrx wagon? sakebomb Subaru Conversions 1 07-08-2004 02:34 PM
