Old 11-02-2009, 12:18 AM   #1
JaredG
Member#: 56093
2005 WRX
wrb
Default Any H&R OE Sport Spring users here???
Is anyone using the H&R OE Sport Springs on a WRX?. There is a "Sport" and an "OE Sport" and I'm asking about the OE versions. They are supposed to be a .75"/.50" drop F/R. I'd be interested in any observations and hub to fender measurements as well. It seems like many springs drop lower than advertised from what I've been reading.
Thanks.
Jared
JaredG is offline   Reply With Quote
Old 12-28-2009, 01:41 PM   #2
DomozitoLK
Member#: 58668
2015 WRX Limited
Lightning Red
Yes, I ran the OE Sport springs with Koni adjustable (yellows) shocks and it seemed to be a much lower drop than the 0.75" advertised. It was probably closer to 1"-1.25" drop. Which was too low with my steep driveway (at the time) and the STI corner splitters and V-limited lip.
It looked great and the ride was nice, but it was just too low for me. I was sorry to get rid of them. In the end I went with the JDM STI Spec-C spring (with blue/green painton front springs) and it was a better ride height for me.
Here is the drop with the OE Sport springs:
DomozitoLK is offline   Reply With Quote
Old 12-28-2009, 02:18 PM   #3
Badler
Member#: 133597
^^^^What sideskirts are those? Prodrive?
Old 12-28-2009, 02:21 PM   #4
DomozitoLK
Member#: 58668
2015 WRX Limited
Lightning Red
OEM skirts from SAAB 92-x. Check out my posts here (around post #18 and later) about the install:
http://forums.nasioc.com/forums/show...php?p=15376025
Old 12-28-2009, 02:28 PM   #5
Badler
Member#: 133597
Thanks!!!!!!!
Old 12-29-2009, 10:00 AM   #6
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Thanks.
Jared
Only on my 98 M3 - I had both. For that car at least, the Sport is too low for optimal handling, but looks nice. I had some paired with Bilstein Sports and hated the ride. Then I swapped that setup out for Konis with OE Sports. The ride was worlds better (partially because of the shocks and partially because of the springs, IMHO) as was the handling.
It just goes to reinforce the 2 statements at the top of the Lowering Spring FAQ:
1) Most lowering springs suck.
2) If it looks sweet, it's too low.
I have no experience with the Subaru application, but from your description of the springs it sounds similar.
john
Old 12-29-2009, 11:40 AM   #7
DomozitoLK
Member#: 58668
2015 WRX Limited
Lightning Red
I sold mine on i-Club to a guy in Sacramento. I think he is still running them on his STI. You might ask him for measurements if that's what your after. His screen ID there is "jdmdaddy"
http://www.i-club.com/forums/member.php?u=62134
Good luck!
Old 12-29-2009, 11:47 AM   #8
DomozitoLK
Member#: 58668
2015 WRX Limited
Lightning Red
Actually...I found the measurement you were looking for. I posted it on IWSTI when I was considering going to the Spec-C springs which I currently run.
http://www.iwsti.com/forums/gd-suspe...sdm-sti-5.html
Here's what I wrote:
Sorry to resurrect this old post...but I also have a set of Spec-C springs I am going to put on my WRX with Koni yellows. I currently have H&R OE sports and it was advertised as 0.75" drop (F) and 0.5" drop (R); but I'm thinking it may be closer to a 1.25"-1.5" actual drop. With my STI corner splitters and V-Limited lip that gives me about 4" clearance to get in and out of driveways at the front. I'm hoping these Spec-C springs will give me a little more clearance up front.
Anyway...I measured them and came up with similar (yet slightly different) measurements of the springs:
FRONTS
coil tip-downward: 9-1/2"
tallest part of spring-downward: 10-1/8"
REARS
coil tip-downward: 11-7/8"
tallest part of spring-downward: 12"
I wonder if my Koni's make my H&R OE Sports drop further than normal? On my WRX, from the hub to fender is:
(F) 13-5/8"; (R) 12-5/8"
Old 12-29-2009, 02:50 PM   #9
flukewrx
Member#: 75081
Wow, the SAAB 92-X Sideskirts look great on the car. I may consider getting those.
flukewrx is offline   Reply With Quote
Old 12-29-2009, 05:34 PM   #10
Butt Dyno
Member#: 17301
is the "dark side"
Any chance they accidentally gave you regular Sports?
Old 12-30-2009, 12:51 AM   #11
JaredG
Member#: 56093
2005 WRX
wrb
DomozitoLK - Thanks for the information! You were right about the drop being more than claimed. That is more like a 2"/2.17" drop.
Nice car, BTW.
Thanks again.
Jared
Old 12-30-2009, 04:08 PM   #12
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
from what I have read this is one of the few applications where HR didn't hit a home run. They are definitely a "stance" spring & not a handling spring.
I have H&R's on 2 vehicles currently & was considering them for my Wagon, but after seeing some of the specs & spring rates, they are not what I want. I want the spring to perform first & if I get a lil drop from them, great...
so, from what I have read, in the WRX application the H&R is a lowering spring, not aa handling spring.
TXwrxWagon is offline   Reply With Quote
Old 08-12-2012, 05:10 AM   #13
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Nice car, BTW.
Thanks again.
Jared
Then it has to be HR sports.. It cant be the HR OE spring because they are listed as .75 front .5 rear. The Sports are 1.4 front 1.3 rear
Dat8687 is offline   Reply With Quote
Old 08-13-2012, 07:24 PM   #14
redrexmeister
Member#: 111692
04 wrx wagon
What strut do you plan to use?
redrexmeister is offline   Reply With Quote
Old 08-14-2012, 04:19 PM   #15
IceTray
Member#: 69582
2004 VW MKIV R32
Wow, you guys have dug up a really old thread...
I'm running the H&R OE Sports right now and they are indeed much lower than a .75 inch drop. They feel, ride, and handle similarly (if not slightly softer) to the Swift Sport springs I had on my wagon previously.
IceTray is offline   Reply With Quote
Old 10-16-2012, 08:38 PM   #16
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Do you think the OE sports and STI PINK struts would be significantly stiffer than the OE wrx setup?
Old 10-17-2012, 10:36 PM   #17
Bikelok
Member#: 254851
2002 WRX wagon 5mt
No, not much. H&R fronts are approx. 200 lbs. rears are approx. 190 lbs.
Bikelok is online now   Reply With Quote
Old 12-08-2012, 11:03 AM   #18
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Well the stocks are what 165 119/132?
So to me thats a good increase.. No where near some of the others of course. But better than stock ..
Thanks for the info
Old 12-08-2012, 11:15 AM   #19
vicious_fishes
Member#: 158864
2003 SOHC destroker
brother had H&R springs. car handles better with the stock sti ones.
vicious_fishes is online now   Reply With Quote
Old 12-08-2012, 12:18 PM   #20
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Thanks for the info
Even though its an increase over stock, they are a very mild spring rate upgrade over stock. They are designed to work with the stock WRX struts, which are damped for a very mild spring. By now most 02-07 stock WRX struts are at the end of their life. So if you replace the struts with a better unit you can go with a better spring.
Unless you go with a stock type replacement strut. Then you are limited to mild springs, like the H&R, Eibach and the Mach V.
Old 12-08-2012, 01:16 PM   #21
Bikelok
Member#: 254851
2002 WRX wagon 5mt
There is no way I would choose H&R, Eibach or Mach V over STI springs.
Old 12-08-2012, 02:36 PM   #22
vicious_fishes
Member#: 158864
2003 SOHC destroker
but they look fooly sik?
H&R OE Sport Springs Daedalus Brakes, Steering & Suspension 0 08-18-2009 10:33 AM
Anyone with H&R OE Sport Spring Set? subierider Brakes, Steering & Suspension 4 09-03-2008 03:48 AM
H&R OE Sport Springs (Wagon)? tylerzero Brakes, Steering & Suspension 0 03-14-2008 06:05 PM
FS (NorCal): H&R OE Sport springs for 04+ WRX and STI DomozitoLK Suspension/Brakes/Handling 3 11-12-2007 02:34 PM
H&R OE Sport Spring Set Develitate Brakes, Steering & Suspension 2 02-19-2007 06:59 PM
