Old 11-29-2012, 11:21 PM   #1
ejh8r
Member#: 280333
Default Ecuflash read and upload issue
- connected green test connectors under dash
- turned on ignition
- tried to read and save the stock tune and it gets stuck after only a second or two.
Interestingly enough both RomRaider and Learning View both function perfectly. I am using a MacBook Pro with parallels on Windows XP with the latest versions of RR/LV/EcuFlash available. This is my personal 2005 STi. I thought it may be an issue with the ecu being locked but I know for a fact it is not as I married a v2 accessPORT this week and unmarried it verifying that it is a stock ecu.
I am simply trying to upload a xpt stage 2 to buuild a base map off of. If you have any ideas I'd love some help. Btw I'm using a 1.3U taxtrix cable.
ejh8r is offline   Reply With Quote
Old 11-30-2012, 08:16 PM   #2
soberpoet
Member#: 264784
Subaru Blue
what year?
soberpoet is offline   Reply With Quote
Old 11-30-2012, 08:30 PM   #3
soberpoet
Member#: 264784
Subaru Blue
sorry missed the part where it says 05
you may need to jump pins on the flash block but i dont remember
Old 12-01-2012, 11:13 PM   #4
eeyuhc
Member#: 312339
'14 BRZ
CBS
You need the 03-05 reflash connector as soberpoet pointed out.
http://www.evoscan.com/evoscan-gps-o...lash-connector
eeyuhc is offline   Reply With Quote
Old 12-02-2012, 08:07 PM   #5
ejh8r
Member#: 280333
Even on STi's? I thought those were only necessary on 16bit ecu's?
Old 12-05-2012, 08:25 PM   #6
ejh8r
Member#: 280333
Anyone?
Old 12-05-2012, 08:36 PM   #7
SharpTuning
Member#: 333363
Correct, those connectors are only for WRX models. What happens when it gets stuck? Post the log from ECUFlash if you have it.
SharpTuning is offline   Reply With Quote
Old 12-07-2012, 11:11 PM   #8
ejh8r
Member#: 280333
Here's my log. Need some help.
[22:01:00.140] EcuFlash Version 1.43.3150
[22:01:00.140] OS Version Windows XP
[22:01:00.140] Qt Version 4.6.2
[22:01:00.140] 62 memory models read.
[22:01:00.140] scanning for metadata models in //psf/Home/Desktop/WRX/RomRaider/ECU Flash
[22:01:01.265] 595 ROM metadata models scanned.
[22:01:01.265] checksum module "subarudbw" loaded.
[22:01:01.265] checksum module "mitsucan" loaded.
[22:01:01.265] checksum module "mitsuh8" loaded.
[22:01:01.265] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[22:01:01.265] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[22:01:01.265] flashing tool "wrx02" loaded.
[22:01:01.265] flashing tool "wrx04" loaded.
[22:01:01.265] flashing tool "sti04" loaded.
[22:01:01.265] flashing tool "sti05" loaded.
[22:01:01.265] flashing tool "mitsukernel" loaded.
[22:01:01.265] flashing tool "mitsukernelocp" loaded.
[22:01:01.265] flashing tool "mitsubootloader" loaded.
[22:01:01.265] flashing tool "shbootmode" loaded.
[22:01:01.343] flashing tool "shaudmode" loaded.
[22:01:01.343] flashing tool "subarucan" loaded.
[22:01:01.343] flashing tool "mitsucan" loaded.
[22:01:08.281] XPT2B11J (289 tables) inheriting 32BITBASE (555 tables)
[22:01:08.328] 1048576 byte image read.
[22:01:08.328] WARNING: this ROM has all checksum features turned off! (RomRaider?)
[22:01:17.234] Using interface OpenPort 1.3 Subaru TX4590W75e87f6c9235425d57719423081d874ea179212ec
[22:01:23.390] kernel get version
[22:01:23.781] SSM2 init
[22:01:23.937] SSM2 ECU ID is 3D12594106
[22:01:24.031] Requesting Seed...
[22:01:24.093] Sending Key...
[22:01:24.140] interface close
Old 12-08-2012, 01:38 AM   #9
SharpTuning
Member#: 333363
For some reason your ECU doesn't like the handshake from ECUFlash.
Are you running ECUFlash from the parrallels XP virtual machine? This may be causing the issue. Try running ECUFlash natively on OSX http://www.tactrix.com/downloads/ecuflash_138_osx.dmg
Old 12-08-2012, 08:16 AM   #10
quazimoto
Member#: 70395
Is it an actual Tactrix cable or an Evoscan cable?Just to re-confirm, only 16bit ECU's need the reflash connectors (02-05WRX). Any USDM STI and 06+ WRX's do not require a reflash connector.
Old 12-08-2012, 04:24 PM   #11
alexmartynyuk
Member#: 191967
2002 wrx
Captain America tuned
what ecu flash are you using, I think you have to use 1.29a for a 1.3u cable, I had one and couldn't get it to work with mine so i ended up getting a 2.0
alexmartynyuk is offline   Reply With Quote
