Old 10-30-2012, 07:55 PM   #401
Impressed wagon
Member#: 64413
1995 Impreza Outblak
Flat Black full WRX swap
Sent my heads off today
Impressed wagon is offline   Reply With Quote
Old 11-11-2012, 11:31 PM   #402
AK-Saabaru
Member#: 337400
2005 SAAB 9-2x
Red
Hey all, first post.
This looks like a great option for my hybrid build. I'll send a PM if I'm able.
AK-Saabaru is offline   Reply With Quote
Old 11-13-2012, 06:41 PM   #403
kornfeld
Member#: 252586
2005 Saab 9-2x Aero
V9 EJ207, Stock Int/Exh
Originally Posted by Equilibrium Tuning View Post
If we disassemble the heads. We will almost never put them back together without doing a valve job. The only exceptions to this are brand new heads or extremely low mileage heads. The CNC service is $400, our 4/5 angle valve job is $500, decking the heads is $200. If you want to be able just slap on the heads and go, I would highly recommend all of these services.
-- Ed
This is an ooooold post...but just to clarify: is the total for all three of these jobs $1100, barring any unforseen broken or unusable parts?
Another post made it sound like you either get the 4/5 angle valve job (if the heads are old), or you get the heads decked (if the heads are relatively new), but not both....but I could very easily be misinterpreting the other post.
kornfeld is offline   Reply With Quote
Old 11-14-2012, 08:25 PM   #404
Equilibrium Tuning
Member#: 26933
2006 STI
That's correct except the price of the CNC work has gone up to $450. So the total for all 3 is $1150.
-- Ed
Old 11-15-2012, 11:29 AM   #405
kornfeld
Member#: 252586
2005 Saab 9-2x Aero
So if the heads are old, do you recommend all three, or just the combustion chamber reshaping and the valve job?
(Forgive me if this is a stupid question, I know nothing about this type of work.)
Old 11-15-2012, 08:31 PM   #406
subarugod91
Member#: 334939
will it work for ej20r?
subarugod91 is offline   Reply With Quote
Old 11-16-2012, 11:09 AM   #407
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
They look great.
Old 11-19-2012, 01:54 PM   #408
Equilibrium Tuning
Member#: 26933
2006 STI
If the heads are old, I would definitely recommend all 3.
-- Ed
Old 11-19-2012, 01:54 PM   #409
Equilibrium Tuning
Member#: 26933
2006 STI
Not sure... what's the combustion chamber style on those?
-- Ed
Old 11-19-2012, 11:23 PM   #410
subarugod91
Member#: 334939
-- Ed
what to you mean by style?
Old 11-20-2012, 12:00 AM   #411
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
EJ20R has clover style like the '97-'99 EJ25D
Old 11-20-2012, 03:11 PM   #412
Equilibrium Tuning
Member#: 26933
2006 STI
Yep, we can't do the clover style.
-- Ed
Old 11-20-2012, 03:43 PM   #413
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You can always blend by hand if you're confident.
Old 11-20-2012, 06:21 PM   #414
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
Or if you don't trust your hands like me you can contact ASF machine, Joe does a combo of by hand and machine. I was curious so I talked to him about it, he said that he can get the chamber out to about 49-50cc.
spackyscooby is offline   Reply With Quote
Old 11-20-2012, 08:01 PM   #415
subarugod91
Member#: 334939
well i have a ej205 block and heads now and just bought a ej25 with ej20r heads that have low compression on cylinder #2. so i will just send my ej205s out.
Old 11-25-2012, 11:21 AM   #416
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Hey Ed,
Can you chamber match a set of ej207 heads from a version 9 STi with AVCS to match up with an ej257 block?
Soarer is offline   Reply With Quote
Old 12-02-2012, 06:52 PM   #417
Equilibrium Tuning
Member#: 26933
2006 STI
Yep. We can do 207 heads.
-- Ed
Old 12-02-2012, 06:53 PM   #418
J3SST3R
Member#: 298926
2007 USDM STI
Hey Ed,
I've got a set of EJ20X V9 dual AVCS 2.0L legacy heads sitting around here, I noticed the chamber is more square compared to the 205/207 chambers, but would you still be able to CNC these out? Or would I be limited to blending by hand? Maybe even FujiK could chime in about this.
I have photos on hand for you if you want to see.
You can shoot me a PM as well
J3SST3R is offline   Reply With Quote
Old 12-03-2012, 07:47 PM   #419
Equilibrium Tuning
Member#: 26933
2006 STI
Send me some photos and I can take a look.
-- Ed
Old 12-03-2012, 09:03 PM   #420
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
-- Ed
What is the reason you can't cut the clover style, programming or not enough material? Thought I'd asked way back about you being able to do them and can't remember if you ever replied or gave a reason.
2slofouru is offline   Reply With Quote
Old 12-07-2012, 10:11 PM   #421
Equilibrium Tuning
Member#: 26933
2006 STI
I honestly haven't tried, but I don't think the program would work properly.
-- Ed
Old 12-08-2012, 06:39 PM   #422
vf22Bugeye11
Member#: 272096
2002 6Speed swap wrx
Function Warrior!!
has your pricing changed ?
vf22Bugeye11 is offline   Reply With Quote
Old 12-09-2012, 10:58 AM   #423
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
What kind of answer is this, especially if you "honestly haven't tried"? Seems like you're slightly limiting your customer base. I actually expected a better response from a vendor, wow.
-- Ed
Old 12-09-2012, 11:40 AM   #424
J3SST3R
Member#: 298926
2007 USDM STI
^ his program is designed to reshape the chamber to mimic the EJ257, which only requires the chamber to be widened for a majority of the process.
To modify a clover style chamber to match that of a 257 would require a totally new program because more material would have to be removed to recreate the same chamber.
Ed is catering to the more recent heads using a Cnc program to keep things faster and a very close match to STi CC's.
It's not his fault he hasn't had time to do every style of head and write a few different programs.
Like posted above you can get work done to these heads from other vendors and Nasioc members.
No reason to degrade a vendor(s) on here.
Just my .02
Old 12-09-2012, 12:08 PM   #425
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
My block is ej257 which is the reason I'm trying to match the combustions chambers so... How is this saving time or "faster" for the people who would like to get it done on clover style heads? If he doesn't think the customer base exists, that would be at least something plausible but his reply simply isn't acceptable in my opinion.
This thread has been up for a few years and not once has he given an explanation or reply on queries about the clover design heads.
Its obvious other people do this, but my point was to decide on whether I would choose them for the work or someone else. Threads like this are to inform as well as advertise and there isn't much informing going on. I'm not the type of person to just send off a couple of heads to a company far away because some nasioc lackie recommends them. I prefer vendors who have a good bit of technical knowledge on the subject. Since my port and valve job will be done soon, I decided to recheck here for any updates.
Its not degrading to ask questions and expect legitimate answers from a person who represents a company that will be doing substantially technical operations to a component that will be part of your daily driver.
Just my .02
.02 doesn't get much these days
Oil Leak on Driver's Side after EJ257 Hybrid Build lancelucas Service & Maintenance 13 11-25-2014 04:42 PM
ej257 hybrid build imc343 Newbies & FAQs 3 05-06-2010 01:58 PM
FS: 2002 WRX 2.5 EJ257 Hybrid Build 02WRXmoddedrex Private Vehicle 'For Sale' Classifieds 3 04-14-2010 09:25 PM
new Sti options for the New Impreza Reiflex General Forum Archive 9 12-22-2000 12:27 AM
