Welcome to the North American Subaru Impreza Owners Club Monday May 30, 2016
North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 12-08-2012, 10:32 PM   #26
Flynlow151
Member#: 77870
2004 Subaru STI
TheBoostCreep Stage II
Most likely the clutch was abused before you bought it but since you have only owned it for 9 months, it may have been on the way out when you bought it making it harder for you to determine the slip. I noticed slip in mine a year ago on a pull, but did not have the time to replace it until last week. To be honest, if you drive the car under regular conditions(easy 1st gear, change around 4-5k without full throttle) you may have never felt the slip. I probably had another 5-10k miles if I drove it easy, however, I missed being able to feel boost and finally had time to replace it. I only noticed it in 3-6th gear past 3k under full throttle. If you did not see this range that often, the clutch can wear out without your knowledge. Old school clutches would show with engagement points, now with hydraulic, only torque will let you know there is an issue. Hope this helps, I know this site at times encourages the d'bags to comment way too much
Flynlow151 is offline   Reply With Quote
Old 12-09-2012, 12:53 AM   #27
God
Member#: 148482
2085 CRYSMORE
LE BARON
I can personally attest to the fact that the previous owner did not ever beat on the car. He hardly even drove the thing. However, I'm not sure about the owner before Ethan.
God is offline   Reply With Quote
