Old 12-08-2012, 02:13 PM   #1
shaneSC
Member#: 243074
2003 WRX
Hey guys,
I recently installed D Specs on 07 STI takeoffs for my bugeye. I'm trying to dial them in, but have a question about the adjustment if the struts.
When tightening the adjuster, how do you know when it's reached full stiff? Does it stop turning completely, or just get more firm (the knob, not the actual struts)?
I have turned it until it feels like its gotten harder to turn, but I'm afraid that might not be full stiff, and it may be throwing off my adjustment. I also don't want to just keep tightening it in fear of breaking the valving or something.
I've searched around but can't seem to find anything relating to this question. Thanks in advance.
Shane
shaneSC is offline   Reply With Quote
Old 12-08-2012, 03:04 PM   #2
f1speeder
Member#: 138854
I had these on my 06 WRX that I auto crossed. If you turn them clock wise all the way it will be at it's firmness. You don't have to make it as tight as you can just snug. For the rear extensions, once I had them where I wanted them I would put a large file clip or black elec. tape around it so they wouldn't turn with the vibration.
f1speeder is offline   Reply With Quote
Old 12-08-2012, 03:25 PM   #3
shaneSC
Member#: 243074
2003 WRX
Ok thanks. I'll have to go try gain, but when you say "all the way", does it actually reach a stopping point? I have gotten to a point where they're harder to turn, but I could continue to turn and turn through the stiffness.
Old 12-09-2012, 12:58 AM   #4
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
these are only supposed to have ~7 full turns total adjustment
if you are bein a gorilla and have over torqued them...i wonder what's broken/stripped out
Old 12-09-2012, 08:19 AM   #5
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
mine have about 10 turns soft hard, with a stop at each end. easy to turn and easy to find the ends. btw keep mine on 3 soft side for both dd and rallycross.
mhoerath is offline   Reply With Quote
Old 12-09-2012, 04:57 PM   #6
shaneSC
Member#: 243074
2003 WRX
I went out and readjusted them today. I was able to find the end at full stiff today. I must have just been scared to overtighten them before. Thanks guys!
Old 12-09-2012, 08:16 PM   #7
Uncle Scotty
OK buy Nates beans
and when you adjust them, beware that 1/4 turn will yeild noticable change and i usually use 1/8 turn incraments to fine tune
if you are trying to do even 1/2 turns, you are likely missing the sweet spot
Old 12-10-2012, 05:13 AM   #8
shaneSC
Member#: 243074
2003 WRX
Awesome, will do. Thanks for the heads up.
Old 12-10-2012, 10:31 AM   #9
f1speeder
Member#: 138854
7-10 full turns and yes small turns you will notice a difference. No, it will not stop as if you hit the max as it would if you turn it counter clockwise.. So Just as you feel it get tight that's all you need. Just turn it counter clockwise to the top and count the turns until you feel it get tight. Again, this should be 7-10 turns.
Old 12-10-2012, 05:03 PM   #10
Uncle Scotty
OK buy Nates beans
well according to tokico...they say 6.5 turns
nowhere near 10....and mine stop 'adjusting' right at 7
but anyway
