Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 12-08-2012, 12:26 AM   #1
legomyego
Member#: 290129
2006 STi
Default control arms
what are some decent control arms for a 2006 sti? i need some new ones.
legomyego is offline   Reply With Quote
Old 12-08-2012, 01:04 AM   #2
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Your car comes with what most people consider the best control arms. The 05-06 STI arms are it.
You are talking about control arms (front) and not lateral links (rear) right?
Bikelok is offline   Reply With Quote
Old 12-08-2012, 02:49 AM   #3
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
and why do you need new ones???
Uncle Scotty is online now   Reply With Quote
Old 12-08-2012, 09:37 AM   #4
legomyego
Member#: 290129
2006 STi
yes laterals, well I bought the car from a dealer and I took it to a mechanic(after buying) and the guy said they were so loose they stripped, he could tighten them with his fingers. the dealer said they don't see anything because they don't want to fix it I'm guessing. they said they are just bent, and they aren't the stock ones they are Perrin
Old 12-08-2012, 10:17 AM   #5
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
If your talking lateral links, unless there was a reason for the perrin ones, stock would suffice and you can get them all day in the classifieds...
Old 12-08-2012, 11:28 AM   #6
Bikelok
Member#: 254851
2002 WRX wagon 5mt
I agree with Aaron. Unless you need some adjustment in the back, you best route is to go stock (used is great and cheap) and just replace the bushings on them before installing.
Stock lateral links with some fresh bushings are hard to beat.
Old 12-08-2012, 11:34 AM   #7
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Once you replace the Perrin units and have them out of the car, you can see if they are repairable.
The dealer was probably not too keen on doing anything on aftermarket parts.
Old 12-09-2012, 07:37 AM   #8
mhoerath
Member#: 131379
2003 354 ftlb@3k rpm
justablue hatch
googled perrin lat links and they're spherical bush one end, and adjustable. nice bits. I have whiteline lat links and the nuts/threaded arms are very robust.
suggest you determine exactly what the problem is. Start by learning how the arm works.
+ ask the mechanic to explain what the problems are,
+ you might ask to see the problem
+ Or jack the car up (use jackstands) and take a look yourself.
mhoerath is offline   Reply With Quote
