#6376 |
Member#: 248747
Vehicle:04' SG XT Blk |
![]() 85' Peugeot PSN-10 60cm 980 Super Vitus Frame: Super Vitus 980 double butted tubing., chain rest, Delrin cable guide. Color: Champagne Fork: Super Vitus 980 tubing, chromed. Weight: 22.1 lbs (feels even lighter). Headset: Stronglight B10 Handlebar: Phillipe alloy Stem: ATAX alloy aero Brakes: Modolo Speedy side pull, Brake Levers: Shimano (after market), bars drilled Saddle: Vetta, black leather Seatpost: ATAX alloy 26.4 Crank: Campagnolo Triomphe 52/42 Pedals: Maillard CX 650, aero Freewheel: Helicomatic 6-speed Derailleurs: Campagnolo Triomphe Corsa Hubs: low-flange Normandy Luxe Competition hubs Rims: Mavic Module E clincher rims, 700C stainless steel spokes.
#6377 | |
Member#: 79498
SWIC
Vehicle:2013 XV Silver Slug '84 Porsche 911-sorta red |
What I'm saying is that the only thing they really do is "increase stability," which is actually just slowing the steering down. Everybody doesn't hit, or maintain high speeds on their bike. Around here, unless you're on a literal hand full of descending, gently winding, smooth trails, you're not going to exceed 20mph for more than a few seconds at a time. What you're going to do more often (around here) is lower speed work where you don't want slow steering. |
#6378 |
Member#: 453
Vehicle:2013 VT |
Bought a used Trek 3500 mountain bike
#6379 |
Member#: 73197
International
question about rear jockey wheels or "G-Pulley" from Shimano. it was my first time taking the chain off my road bike and i was going over the all the spinning parts to see if they are still good. i noticed the jockey wheels closest to the cassette in the rear derailer is pretty stiff and doesnt spin smoothly and freely as the other jockey wheel. i instantly thought it was bad and pulled it off thinking ill get a new one tomorrow.
while i had it off, i thought i might as well clean it up. so i started taking it apart noticed that there isnt really anything "bad" about it. i think by design it was suppose to be this stiff. reading more about it online and it seems like its normal. now im thinking...should i just leave it, or switch to aftermarket ones and get a ceramic ball bearing? any recommendations? |
#6380 |
Member#: 93193
South East
Vehicle:'90 Ishtbox Corolla maroon, as in, I hope not |
They should spin pretty freely, any drag in the drivetrain is going to cost horsepower to overcome, and that comes from your legs.
I'd clean the bearing out and reassemble and see what it's like then. |
#6381 |
Member#: 122171
Lots of nice bikes in OT.
Also, why do presta valves have to be so flimsy? Ugh. Was swapping out my rear tire and tube... everything going smoothly until I remove the pump from the valve and snap it in half. Awesome! My hands were cold and I was getting antsy to go for a brisk ride, but still. I ended up playing basketball at a gym. F it. |
#6382 |
Member#: 137902
Vehicle:---- Last night I dreamt of San Pedro |
^ more like, why presta, i always thought schrader was just fine...presta just annoy me.
#6383 |
Member#: 93193
South East
I have never once had a problem with presta valves, also, it'd be kind of hard to fit a schraeder valve on a skinny roadie tube.
#6384 |
Member#: 7887
I've never broken a Presta valve. I've bent several, but never broken. They still work bent.
Presta is a one way valve when you are adding air. Schraders lose air when you attach and detach the pump. Plus, Prestas can be set up for tubeless where you can remove the valve stem easily and add Stans or similar sealant when it starts to dry up. Prevents you from having to break the bead to add the sealant. |
#6385 | |
Member#: 93193
South East
#6386 | |
Member#: 7887
edit: Apparently Stans makes a combo tool that removes both cores. I guess there is enough space. |
#6387 | |
Member#: 171151
Vehicle:2008 FXT Sports Aspen White on pink sprgs |
Pics to follow when I get the bike. |
#6388 | |
Member#: 73197
International
I'll go see how much some ceramic bearings cost then decide. |
#6389 |
Member#: 242630
SCIC
Vehicle:.. Pepperoni nips and big slits... |
If anyone is in the market for a Norco downhill bike let me know. I have one for sale. Originally $6k and has A LOT done to it. Will let it go for a great price!!!
#6390 | |
Member#: 89951
#6391 |
Member#: 6511
#6392 |
Member#: 242630
SCIC
Yep, sorry typed it out wrong
#6393 |
Member#: 6511
#6394 |
Member#: 242630
SCIC
Team DH is the model
#6395 |
Member#: 242630
SCIC
Looks 99% like this. Has some better forks I put on it and some other pieces.
#6396 |
Member#: 177840
Vehicle:2000 swapped RS White 330whp |
If you guys had the choice between a 2003 Cervelo P2K or a 2009 Felt S32 both for the same price, which one would you go for??
I'm leaning more towards the Felt. |
#6397 |
Member#: 93193
South East
He uses Stan's with presta tubes with removable cores too, he thought that schraeders wouldn't have enough room. If anything, there's more room with the valve core removed with a schraeder than a presta,
#6398 |
Member#: 7887
What are these tubes you speak of? Tubeless FTW.
#6399 |
Member#: 93193
South East
#6400 |
Member#: 7887
Yup, I am. I can't fathom having to run tubes again. I got a thorn through my sidewall the other day and I just laid the bike on its side with the hole side down and pumped air in. The flat was fixed in just a few seconds.
| Thread Tools | |
| Display Modes | |
| Ride your Bicycle today! | Howl | Off-Topic | 27 | 07-26-2008 01:00 AM |
| Ever wonder who's working on your bicycle... | BlkTS02 | Off-Topic | 4 | 09-02-2005 10:29 PM |
| Carl post your pics of your dead mustang | WRXMaster | Texas Impreza Club Forum -- TXIC | 20 | 07-01-2002 01:37 PM |
| post your 'to do' lists for your car here | DoinkMobb | General Community | 46 | 03-31-2002 09:23 PM |
| Post your pics of your ROTA wheels | FatCatTurbo | Member's Car Gallery | 29 | 01-30-2002 12:40 AM |
