Old 12-09-2012, 10:31 AM   #1
Andrew1021
Member#: 274309
Default Looking for a Good set of Coilovers for my Son
Hey guys, it's christmas time as well all know and I'm looking to by my son a set of coilovers for christmas. However, I do not have a lot of funds left to spend on coilovers since I already purchased him a Perrin Front Mount Inter-cooler, Megan Racing Header and Uppipe, and a TurboXs downpipe. My budget for the coilovers would be around $800 MAX. What would be the best bang for my buck gentlemen?
I appreciate any and all the help.
Andrew1021 is offline   Reply With Quote
Old 12-09-2012, 10:32 AM   #2
darksc00by
Member#: 102140
Damn your son is spoiled if you are buying all of that for him for Christmas. $800 won't buy you much in coilovers anyway.
darksc00by is offline   Reply With Quote
Old 12-09-2012, 10:55 AM   #3
RoadKillDMD
Member#: 284792
2011 STI
Blurple
This ^^ For a 'decent' set of coilovers that won't fall apart in the first 5,000 miles, you don't want to spend anything less than two grand... Don't cheap out!
Old 12-09-2012, 11:04 AM   #4
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
OP, take the $800 and put it toward a pro-tune, since one will be needed.
Wait a few months, especially after winter if you happen to live in such a region (snow, salt, ice, sand, etc.), and then buy a good set of coil-overs. Good parts are not inexpensive.
Big-E is offline   Reply With Quote
Old 12-09-2012, 11:08 AM   #5
Andrew1021
Member#: 274309
Not really. I always tell him to work for what he wants. But I made a deal with him if he had over a 3.8 GPA during this semester of college I'd buy him some car parts.
He was telling me that the Cobb Accessport that he has will do just fine. Is he wrong? This is his Daily Driver so I dont want to have to listen to him complain that his car wont move because he needs a proper tune. Then he will have to take my car, and that won't happen.
Old 12-09-2012, 11:16 AM   #6
RoadKillDMD
Member#: 284792
2011 STI
Blurple
What car is this for? That shiny Perrin FMIC will require a professional custom tune in order for his car to run properly. Cobb AP doesn't have any OTS maps for front mounts.
Old 12-09-2012, 11:27 AM   #7
Andrew1021
Member#: 274309
he has a 2006 World Rally Blue Wrx wagon. Would i have been better off buying him a STi top mount? If that's the case, i'll just stick the front mount on my car and give him my top mount.
Old 12-09-2012, 11:56 AM   #8
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Unless he has plans for a large turbo upgrade later down the road, a FMIC would basically be useless on a stock turbo WRX. A larger TMIC would be more appropriate.
What type of headers did you get? Equal length? Unequal length? Regardless, because of the change in exhaust flow to the turbo, a tune would be highly recommended. You'll at least need some way to monitor boost and AFRs (gauges hint hint) to see if the engine is running safe. If your boy doesn't have at least a boost gauge and a wideband air/fuel ratio gauge, I would forget about the coilovers altogether and get those.
Old 12-09-2012, 12:37 PM   #9
13swp5dr
Member#: 335430
Cool dad...I agree with the comments ab waiting on coilovers...I want to autocross ocassionally so I will pay...I will only buy kw's bc I know they are made to handle track/dd driving...research and buy quality even if it takes longer to save
13swp5dr is offline   Reply With Quote
Old 12-09-2012, 01:22 PM   #10
Andrew1021
Member#: 274309
The headers are Megan Racing unequal length with up-pipe. So if i got him gauges what would you recommend? AEM, Autometer?
Old 12-09-2012, 01:59 PM   #11
RoadKillDMD
Member#: 284792
2011 STI
Blurple
AEM makes a great wideband UEGO gauge. However, I've heard/read a handful of negative reviews about their boost gauge. Defi is the most 'trusted' (more like popular) gauges otherwise. They are accurate, responsive, and very good looking. Unfortunately, they don't make a wideband gauge. There's honestly too many brands to compare. You just have to look around and find what would look good in the cabin, but at the same time have a reliable gauge.
Old 12-09-2012, 02:20 PM   #12
darksc00by
Member#: 102140
Get him a set of defi gauges. I like EGT, oil pressure, and boost. Then get an AEM UEGO.
Old 12-09-2012, 02:21 PM   #13
darksc00by
Member#: 102140
and for the record, I wish my parents would give me car parts for Christmas when I have a 4.0 -_-
Old 12-09-2012, 04:19 PM   #14
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
You don't have to buy coilovers to get a GOOD suspension for your son...
Dspecs or AGX and TCE springs... ~800$
Oh, and you're awesome..
Old 12-09-2012, 06:15 PM   #15
Bikelok
Member#: 254851
2002 WRX wagon 5mt
I agree with Aaron. For a bit more than $800 a set of Tokico D-specs (not the AGX, unless you stick with STI springs), STI springs or RCE springs and Whiteline Com-C front strut tops would be a killer suspension upgrade that would put most coilovers to shame.
Especially in a street driven car. Personally I don't recommend coilovers unless its a track car. If you live with salted roads even more so. Coilovers are WAY WAY WAY overrated for the street.
Edit: if you do go with struts, you will probably need 921 spacers for the rear struts to top hat connection. They are basically a special washer so you can use a D-Spec (or AGX) strut with 04-07 rear springs and top hats.
If its something you might want to do, look into it. It's not hard at all to put together.
Bikelok is offline   Reply With Quote
Old 12-09-2012, 06:23 PM   #16
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Oh, if you get used springs you can come in closer to $800 too.
Do yourself and your son a favor, don't get coilovers. If its a street car stick with springs and struts.
Coilovers require maintenance and lots of fiddling to keep working correctly. If someone tells you otherwise they are wrong.
Coilovers have their place, a daily driven street car is usually not that place.
Old 12-09-2012, 08:00 PM   #17
Andrew1021
Member#: 274309
Don't wish for your parents to give you anything, earn it yourself and you'll feel a lot better and know that you worked for what you have.
Thank you! I appreciate it.
My son was telling me that coils will get him to the ride height that he is going for. My wife "sold" him her 18x9 Rota Grids (If im correct) off of her 04 STi before she sold it.
However, i feel that i'm just going to let him do his own suspension, so he can pick out what he likes, and I will buy him gauges and a gauge pod.
Old 12-09-2012, 09:39 PM   #18
Dmochowski
Member#: 306478
2016 Focus RS
stock
OP $800 is what i spent on RCE springs (some of the best quality) and koni struts (also some of the better quality). If you want to get him some suspension get him that. so you wont have to spend more money rebuilding cheap coilovers a year later.
Dmochowski is offline   Reply With Quote
Old 12-09-2012, 09:54 PM   #19
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Not all coilovers are bad on the street, but yeah at 800 bucks they will be. Gotta spend more than that for quality.
Turn in concepts is a good place to talk to for RCE springs and some struts.
AndyRoo is online now   Reply With Quote
Old 12-09-2012, 10:05 PM   #20
rocketperson7
Member#: 283968
MBP
A wideband is a must, I prefer the AEM one since it requires no calibration and you never have to question its accuracy
I like vei systems gauges for anything else
Old 12-10-2012, 07:47 PM   #21
25rsti
Member#: 166324
Good decision on buying gauges for your son rather than coilovers. He'll be happy. Merry Xmas!
Old 12-10-2012, 08:22 PM   #22
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Can you adopt me?
Counterfit is online now   Reply With Quote
Old 12-10-2012, 08:53 PM   #23
slayer44wagon
Member#: 300834
03 wrx wagon
And me as well
slayer44wagon is offline   Reply With Quote
Old 12-10-2012, 08:59 PM   #24
jaboyd
Member#: 247304
2011 STI
WR Blue
Default xmas goodies
I agree, unless he plans on racing it later or he is very in to "tuning his suspension", coil-overs are over kill for a DD. Good springs will get him lower and improve handling as well as upgrading the struts. Make sure you get good/larger swaybars (both - $400 frt & rear) and a lower brace to tighten up the handling ($200).
If he's running a stock turbo, a stock or if you must, an upgraded TMIC would be fine. No need to spend $$$ or get complicated with FMIC.
Headers need to get a pro-tune and really don't add that much hp (10-15hp at the topend) unless you do motor or turbo changes. Stick with a good TBE exhaust system and a pro-tune will due wonders for performance without compromising daily driveability.
I prefer Defi gauges - Oil pressure, boost, and EGT. Titan is ok for wideband but several others to choose from.
jaboyd is offline   Reply With Quote
Old 12-10-2012, 11:52 PM   #25
rocketperson7
Member#: 283968
MBP
there's really no need for an EGT gauge, all you need to know is if something's about to melt, and you can do that with your O2 sensor
http://www.romraider.com/forum/viewt...hp?f=33&t=8134
