Old 12-09-2012, 10:07 AM   #5076
Okita Souji
Member#: 41097
2005 WRX
Originally Posted by Vlad View Post
A US driver's side is on the left, and there are two plugs there, one brown and one black.
Is this what you're talking about?
Yes, it's the one by the battery with the brown and black plugs. Both are missing.
Okita Souji is offline   Reply With Quote
Old 12-09-2012, 10:52 AM   #5077
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
That sucks man! You can look into this harness, which promises to add the missing wires, so you can use your USDM engine harness. Supposedly it's for motors that didn't come with a complete harness...
http://www.iaperformance.com/product...oducts_id=3217
... it is different from their AVCS bulkhead wiring kit, which most people need to wire up their ECUs.
Torquey is offline   Reply With Quote
Old 12-09-2012, 12:18 PM   #5078
Okita Souji
Member#: 41097
2005 WRX
Thanks! You just saved the day!
Old 12-09-2012, 02:50 PM   #5079
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Originally Posted by johnfelstead View Post
It's 26 Euro for a lap now, which is $33, a lot more expensive than when i first started driving there. You can also do a 20 minute session on the modern GP track for 40 Euro, $51.
Where can one sign up for a lap?? You sure those rates are semi-accurate?
After a quick search I saw one lap in a Suzuki Swift Sport was 99 euro and it goes up from there.
Old 12-09-2012, 02:54 PM   #5080
johnfelstead
Member#: 856
2005 JDM STi
It's balls on accurate, certified by NASA engineers.
That's the price for using your own car.
johnfelstead is offline   Reply With Quote
Old 12-09-2012, 03:11 PM   #5081
Paul
Member#: 56203
00 RSTI Coupe
Ooo. I thought that was the price of renting/running a STI down the track...lol
That makes alot more sense and seems reasonable
Old 12-09-2012, 04:36 PM   #5082
WRX2EVOX
Member#: 203011
04 WRX
Nice "My Cousin Vinny" reference
WRX2EVOX is offline   Reply With Quote
Old 12-09-2012, 04:39 PM   #5083
johnfelstead
Member#: 856
2005 JDM STi
Old 12-09-2012, 04:57 PM   #5084
efiniluvr
Member#: 107170
2002 ver 7 EJ207 WRX
What would be my best option? Can I, 1) use the engine wire harness off my WRX engine and move wires around for the AVCS.
This is your best option, less messy. Although this would mean having to take off TWO intake manifolds to swap over the WRX harness. So while you're at it, get a new turbo inlet so you don't have to remove the IM again in te future. I wish I had done that in the first place. Right now, I have to pull the IM off to replace the fuel one due to the common leaky fuel line, so I ordered a new inlet, Grimmspeed phenolic spacers and a AFT MAF hose to do everything at once.
Jeff
efiniluvr is offline   Reply With Quote
Old 12-10-2012, 08:44 AM   #5085
Computersare8ad
Member#: 287080
2000 Fozz
Blaaaaaack
Jeff
Why do you have to take off the manifold? I pulled my cut harness off while it was in the car.
Just remove the pwr steering, alt, and ac then use wrenches.
Computersare8ad is offline   Reply With Quote
Old 12-10-2012, 09:56 PM   #5086
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
And that is supposed to be easier than the 8 bolts holding the manifold? takes like 30 minutes.
Old 12-10-2012, 10:08 PM   #5087
207STi
Member#: 197062
1998 Swapped Impreza
black
There are 3 or 4 hard to get to bolts under the manifold that connect the fuel hard lines and their plastic shielding. Having done it once I wouldn't hesitate to do it again, but its definitely not as simple as the 8 bolts you can see from the top.
Old 12-11-2012, 07:25 AM   #5088
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
Yeah there's 2 each for the harness guide and the fuel rails.
I wouldn't remove the rails without pulling the Mani unless I was wrecking them but the harness can be done
todeswalzer is offline   Reply With Quote
Old 12-11-2012, 11:34 AM   #5089
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
I am aware of those bolts, much easier to do if you pull the manifold, 30 min to get to this state.
Old 12-11-2012, 11:38 AM   #5090
207STi
Member#: 197062
black
At no point did I say that it was "difficult." I was referring to what is quoted above. I said there was more than 8 bolts holding the manifold on, which there are.
Old 12-11-2012, 12:05 PM   #5091
efiniluvr
Member#: 107170
If you've pulled the manifold off once, it gets easier everytime. Yes, there are the "easy" bolts, and then there are the bolts that hold the plastic harness rail to the manifold underneath. What I was trying to get at was that, if you need to replace the harness, why not pull the manifold off and do some things (e.g. swap turbo inlet, and the fuel rail if you're encountering the smelly raw fuel issue, which I have) while you're at it.
And to lukeskywrx, isn't that the ver. 8 manifold with the long runners? If it is, you're lucky enough to not have to remove the TGV deletes like most of us
Back to the OP regarding the cut harness, I think your best bet is to switch the WRX harness over, get a AVCS harness, and add/repin according to the DS1 instructions if you're not getting the IA Performance wiring kit.
-Jeff
Old 12-12-2012, 10:39 AM   #5092
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
So here's where I'm at with my swap.
04 wrx
V8 ej207
Jdm ecu
Currently no avcs
Engine starts but idles at ~2100
Engine won't rev past 3000
Unplugging the MAF stalls the engine. Cleaned the MAF because it was nasty, idles smoother but no change.
Could this be due to the JDM ecu and no AVCS?
If you have any ideas while I search through the thread they'd be appreciated.
Old 12-12-2012, 10:49 AM   #5093
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
No AVCS is going to trigger a bunch of trouble codes, is your CEL on? If so you are pry in safemode.
Also is your IACV OK? they tend to break in shipping so you might want to try your WRX one.
Try your WRX ECU and see if it is better once you check the IACV.
04 wrx
V8 ej207
Jdm ecu
Currently no avcs
It is the V9 spec-C manifold, same thing as the v8. I don't mind pulling the manifold, I run e85 so I get the delicious raw ethanol smell
-Jeff
Old 12-12-2012, 11:03 AM   #5094
Computersare8ad
Member#: 287080
2000 Fozz
Blaaaaaack
Never said anything about easier. It was a PITA when I removed mine and had to clean off the old gasket and then the extra $15 for new gaskets.
Old 12-12-2012, 11:08 AM   #5095
2JZ
Member#: 291949
Is the mouth of the V8/V9 DP cast iron? It looks rather beefy in the few pics I could find. Also, is the mouth of the DP split to separate exhaust gases and waste-gate flow?
Just curious as to how well subaru designed their DP to help spool
2JZ is offline   Reply With Quote
Old 12-12-2012, 11:20 AM   #5096
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
I think stainless, I have one in the garage and Ill snap a pic for ya. Just a big smooth bell mouth.
Old 12-12-2012, 11:21 AM   #5097
Psychoreo
Member#: 79643
2015 WRX STI
After some research it does sound like AVCS induced limp mode (CEL is on)
We're working on wiring up the harness now.
Old 12-12-2012, 11:49 AM   #5098
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Sounds like a bad IAC, lack of avcs won't do what you are describing, I'm able to drive my car with avcs disconnected on a v8 ecu, check engine light on from avcs sensors. Put the IAC from your wrx engine in, try it.
Old 12-12-2012, 12:49 PM   #5099
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
But would the IACV keep the motor from revving past 3k?
Old 12-12-2012, 12:51 PM   #5100
Psychoreo
Member#: 79643
2015 WRX STI
We're sorting out the AVCS right now anyway. I also swapped over the WRX IAC with a new gasket. I'll update with changes shortly
