Old 12-08-2012, 03:24 PM   #176
nels0300
Member#: 331332
2014 Camry SE V6
Originally Posted by Zeeper View Post
Meaning I didn't change the controls and slid the rear out in snow (with snow tires on) by purposely taking a turn at an "unsafe" speed, at least for traction. The car recovered nicely. If it didn't there was nothing to hit, the area was surrounded by corn fields, no curb, no guard rail, no signs or trees.
You have to work to get the rear end to break loose, but it can be done whether the stability control button is active or not.
I didn't come into the corner at an unsafe speed, I went in at a normal speed, in 2nd gear, and goosed it, and the back end came out, just like my Mustang.
It did it with the traction control on too, but the traction control kicked in right away.
With the traction control off, it still comes on, but you have to be almost sideways before it kicks in.
I don't have winter tires, so it's not hard at all to induce oversteer. I'll probably go around every corner in the snow this winter steering with the throttle.
nels0300 is offline   Reply With Quote
Old 12-09-2012, 05:08 PM   #177
nels0300
Member#: 331332
2014 Camry SE V6
Lots of snow today!
Did 360s in the cathedral of St. Paul parking lot, then smoked a couple Jeeps on the way home.
Old 12-14-2012, 12:55 PM   #178
adowdell
Member#: 108860
2012 Impreza 2.0i
Dark Grey Metallic
mine kicks in FAR before "sideways"... Maybe 12 degrees off the correct angle....
adowdell is offline   Reply With Quote
Old 12-14-2012, 09:27 PM   #179
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Is yours a manual or auto? I'm wanting to pick one of these up. Part of the reason being that the stablity control isn't as up tight as other cars on the market, at least from what I've heard...
Dirt Bringer is offline   Reply With Quote
Old 12-27-2012, 01:53 AM   #180
Dirt Bringer
Member#: 340297
Ice Silver
So today I took my manual premium out in the snow and can confirm what others have said. The stability control feature does seem to come on (I could hear something I believe was brake chatter), but it only happens when the car starts to go pretty much sideways, and it wasn't stopping me from having fun and drifting the sucker around pretty well. This was of course with the trac/stabili set to off. A salesman told me that the stability and traction control can be turned off but reengage at 25mph and above automatically. I have nowhere to go fast enough to test this...has anyone else been able to prove or disprove this claim?
Old 12-29-2012, 10:06 PM   #181
loug
Member#: 295899
Took out my 2013 base model 5sp out in about 7" of untouched powder in a large parking lot. Definitley had some fun but would love a solution to disable the tc completely. Question though.. when the tc kicks in is it detrimental to the drivetrain or car in any way? Especially when it kicks in a lot in a short period of time
loug is offline   Reply With Quote
Old 12-30-2012, 11:05 AM   #182
brapple
Member#: 327032
2012 2.0i Premium
Just had our car out and the stability control didn't interfer to much. I took some corners harder then normal in the snow and got on it alittle. The rear would start to come around and then it would straighten itself out. Car handled really well.
So I would say it kicked in when it should. However if you really want to have fun sliding the car around I could see where it would be annoying.
On a side note, I felt the stability control in my Focus worked better then the Impreza. At least on the corner I took the Impreza seemed to understeer longer before the system kicked in. However they seem to allow for about the same amount of rotation before kicking in.
brapple is offline   Reply With Quote
Old 01-16-2013, 10:38 PM   #183
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
was testing this a bit today. need more snow/icy parking lots...anyway..
it seems that if you can start to drift and then control the drift with throttle only, the car will let you. the moment you move the steering wheel, the stabilty control kicks and ruins your fun.
flyboy1100 is online now   Reply With Quote
Old 01-16-2013, 11:33 PM   #184
ans2k
Member#: 315631
2012 Impreza Sport
idk, with the limited space i had, i was on top of a parking deck after a day of freezing rain and freezing temperatures. the impreza on dws tires was easy to slide around.
Old 01-16-2013, 11:46 PM   #185
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
on ice w/o studded tires you are going to slide.
but with the stock tires i can slide very easy, but if i turn the wheel at all while sliding it seems to activate the stability control. so it seems like more practice is required so i can figure out the right amount of throttle/wheel combination to slide w/o over-doing it so i can avoid the stability control
btw we had last weekend what you guys down south got yesterday/today
Old 01-16-2013, 11:49 PM   #186
ans2k
Member#: 315631
2012 Impreza Sport
yep, i saw. first time in a while that it snowed twice in a year
Old 01-18-2013, 08:37 AM   #187
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I was testing some more this morning, if you can start the drift and then control with throttle and not turn the wheel you can have a lot of fun. I tried it with and w/o traction control on and both seem to have no affect as long as you don't turn the wheel with the gas applied. You can let off the gas, correct the wheel, then hit the gas again and continue to drift
Old 01-22-2013, 12:59 PM   #188
SubaruWRX1843
Member#: 269130
SO I bought a 11 WRX and ordered some snow tires on steel wheels at the same time. I did the Cobb stage one crap and loved the car! The best (my 1st new car besides a work van) car I’ve ever owned… But I made a mistake. I got the sedan… A year later Realizing that I was spending $1300 a month in fuel for my tiny business I got to thinking… Maybe I need a small fuel efficient car to take care of the running around and some small jobs. I needed a hatchback! I did the unthinkable and traded the WRX for a 12 Impreza CVT hatch. Now don’t get me wrong I love my Impreza! It does everything it is designed to do and more but man I miss the extra 150hp and parking lot victimization.
I’m going to call Cobb and talk to one of the engineers to see if they are going to make a AP map that will just rid the car of this crap by pushing a button… and spending $600 on there product. I think that will be our only hope.
Till then I have this…
A report will follow.
SubaruWRX1843 is offline   Reply With Quote
Old 01-22-2013, 01:11 PM   #189
SubaruWRX1843
Member#: 269130
Well that was fast… The answer is no.. They said they are focusing on turbo charged cars only. He did say that they have talked about making maps for the standard car in the past and that the issue has been brought up but not they don’t have enough market to invest the time. I say we get together and make a plea to them to DO IT!!! Cobb is a fantastic organization but until they see the prospect of making $$ they wont help us. I don’t blame them. Any ideas on how we can tell them that we will spend for a fix on our winter fun issue??
Old 01-22-2013, 01:39 PM   #190
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by SubaruWRX1843 View Post
Well that was fastÖ The answer is no.. They said they are focusing on turbo charged cars only. He did say that they have talked about making maps for the standard car in the past and that the issue has been brought up but not they donít have enough market to invest the time. I say we get together and make a plea to them to DO IT!!! Cobb is a fantastic organization but until they see the prospect of making $$ they wont help us. I donít blame them. Any ideas on how we can tell them that we will spend for a fix on our winter fun issue??
i just want to diable PZEV startup
Old 01-22-2013, 01:47 PM   #191
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
Maybe something like, we get enough of us to make a deposit on paying for the map. Once they get enough deposits, they would do it.
Xafen is offline   Reply With Quote
Old 01-22-2013, 01:55 PM   #192
SubaruWRX1843
Member#: 269130
I’m just trying to help… The fact is that Subaru made the system redundant and you are not going to be able to just pull a fuse or find a hidden button somewhere. You are going to need to remap the ECM and tell it not to give a crap when you are sliding…
Old 01-22-2013, 04:40 PM   #193
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Originally Posted by nels0300 View Post
Lots of snow today!
You bastard, why didn't you call me?
goregasm is offline   Reply With Quote
Old 01-23-2013, 07:20 AM   #194
boudy
Member#: 174665
I'd buy it for my 5 speed CrossTrek in a nanosecond but I don't think its likely to happen. The development and testing effort would probably be pretty substantial.
Enthusiasts aren't the target market for Impreza and CrossTrek. I reckon they figure we'll buy the WRX and BRZ.
This electronic interference is only going to get worse with each new generation.
boudy is offline   Reply With Quote
Old 01-23-2013, 01:07 PM   #195
SubaruWRX1843
Member#: 269130
Correct. Most enthusiasts will spend the extra few thousand and buy a WRX or BRZ. I did and told myself the entire time that the WRX was practical and fun. Wish I got the hatch!!!
I don’t think the new Impreza will ever be turned into a WRX or STI model. I think this new car is the beginning of a separation of the nasty sports car and the everyday driver.
Maybe in the future they will make a turbo 1.8L with 148hp for the standard Impreza and keep the WRX and STI the nasty 2.5L turbo. I think If they do that they can use the STI chassis and the Impreza engine to develop the next generation Subaru Rally and still be able to keep the performance/economy people respectively happy while fitting into the WRC regulations. We will see…
Old 01-23-2013, 01:34 PM   #196
Subie_Noob_Brian
Member#: 288037
2015 LightingRed WRX
11' WRX sold**14' XV sold
I have a Crosstrek CVT 60/40 split. I found the best way is to disable the VDC (only turns off the throttle limiter), use the manual mode staying in first gear (second if needed for a short period of time), and use the Ebrake. Here is what I came up with.
Subie_Noob_Brian is offline   Reply With Quote
Old 01-23-2013, 01:35 PM   #197
Subie_Noob_Brian
Member#: 288037
And if you want to see the difference in what the WRX can do check out my YouTube channel for some 2011 WRX snow drifting.
Old 01-23-2013, 02:04 PM   #198
Dirt Bringer
Member#: 340297
Ice Silver
Subaru 2013 XV Snow Drift HD - YouTube
IMG_0128.mp4 video by ArmyBoyBrian - Photobucket
Where did you get that front bash guard and lighting kit (I know its supposed to be called something else)? I wonder if it would fit an impreza...
Old 01-24-2013, 01:29 AM   #199
Subie_Noob_Brian
Member#: 288037
Primitive racing out of Oregon, WA
Old 01-24-2013, 02:04 AM   #200
ans2k
Member#: 315631
2012 Impreza Sport
light bar and auxiliary lights
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
2012 Impreza 2.0i Gas Mileage Thread Benchmark General Community 934 10-08-2013 02:49 PM
[REQUEST TO MODS] 2012 Impreza 2.0i only forum please? tornado542 General Community 10 04-26-2012 05:07 PM
2012 Subaru Impreza 2.0i Break-In Period Arseezy Newbies & FAQs 7 02-14-2012 08:28 PM
Impreza 2.0i durid Newbies & FAQs 2 02-07-2012 03:54 PM
