Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Old 12-08-2012, 02:14 PM   #6376
njdriver04
Member#: 248747
04' SG XT
Blk
85' Peugeot PSN-10 60cm 980 Super Vitus
Frame: Super Vitus 980 double butted tubing., chain rest, Delrin cable guide.
Color: Champagne
Fork: Super Vitus 980 tubing, chromed.
Weight: 22.1 lbs (feels even lighter).
Headset: Stronglight B10
Handlebar: Phillipe alloy
Stem: ATAX alloy aero
Brakes: Modolo Speedy side pull,
Brake Levers: Shimano (after market), bars drilled
Saddle: Vetta, black leather
Seatpost: ATAX alloy 26.4
Crank: Campagnolo Triomphe 52/42
Pedals: Maillard CX 650, aero
Freewheel: Helicomatic 6-speed
Derailleurs: Campagnolo Triomphe Corsa
Hubs: low-flange Normandy Luxe Competition hubs
Rims: Mavic Module E clincher rims, 700C stainless steel spokes.
njdriver04 is offline   Reply With Quote
Old 12-08-2012, 04:35 PM   #6377
richde
Member#: 79498
2013 XV Silver Slug
'84 Porsche 911-sorta red
Originally Posted by EnterTheDragon View Post
Let's stick with Pivot bikes since that was your example. Per their website the following bikes come with the following width bars.
All these bikes are all mountain, fr, dh which is how I originally described my bikes. Different strokes for different folks but if you enjoy going downhill you should give wide bars a try...if your trails allow. I only pedal to get to the top of trails to rip down them.. no xc for me.
Speaking of MX, ex pro Aaron Gwin who won this years UCI downhill series uses handlebars 780-820 wide, this man knows how to get over and behind his bike.
I know they're available, even last year I had to look hard to find identical replacement bars after damaging mine, and I realize that's what the market is asking for, so that's what bikes are delivered with.
What I'm saying is that the only thing they really do is "increase stability," which is actually just slowing the steering down. Everybody doesn't hit, or maintain high speeds on their bike. Around here, unless you're on a literal hand full of descending, gently winding, smooth trails, you're not going to exceed 20mph for more than a few seconds at a time. What you're going to do more often (around here) is lower speed work where you don't want slow steering.
richde is offline   Reply With Quote
Old 12-08-2012, 05:40 PM   #6378
edkwon
Member#: 453
2013 VT
Bought a used Trek 3500 mountain bike
edkwon is offline   Reply With Quote
Old 12-09-2012, 07:29 AM   #6379
disaster999
Member#: 73197
question about rear jockey wheels or "G-Pulley" from Shimano. it was my first time taking the chain off my road bike and i was going over the all the spinning parts to see if they are still good. i noticed the jockey wheels closest to the cassette in the rear derailer is pretty stiff and doesnt spin smoothly and freely as the other jockey wheel. i instantly thought it was bad and pulled it off thinking ill get a new one tomorrow.
while i had it off, i thought i might as well clean it up. so i started taking it apart noticed that there isnt really anything "bad" about it. i think by design it was suppose to be this stiff. reading more about it online and it seems like its normal.
now im thinking...should i just leave it, or switch to aftermarket ones and get a ceramic ball bearing? any recommendations?
disaster999 is offline   Reply With Quote
Old 12-09-2012, 10:52 AM   #6380
VpointVick
Member#: 93193
'90 Ishtbox Corolla
maroon, as in, I hope not
They should spin pretty freely, any drag in the drivetrain is going to cost horsepower to overcome, and that comes from your legs.
I'd clean the bearing out and reassemble and see what it's like then.
VpointVick is online now   Reply With Quote
Old 12-09-2012, 12:53 PM   #6381
dbrunner
Member#: 122171
Lots of nice bikes in OT.
Also, why do presta valves have to be so flimsy? Ugh. Was swapping out my rear tire and tube... everything going smoothly until I remove the pump from the valve and snap it in half. Awesome! My hands were cold and I was getting antsy to go for a brisk ride, but still. I ended up playing basketball at a gym. F it.
dbrunner is offline   Reply With Quote
Old 12-09-2012, 01:05 PM   #6382
Meat Supply
Member#: 137902
---- Last night I
dreamt of San Pedro
^ more like, why presta, i always thought schrader was just fine...presta just annoy me.
Meat Supply is offline   Reply With Quote
Old 12-09-2012, 01:21 PM   #6383
VpointVick
Member#: 93193
'90 Ishtbox Corolla
I have never once had a problem with presta valves, also, it'd be kind of hard to fit a schraeder valve on a skinny roadie tube.
Old 12-09-2012, 01:25 PM   #6384
quentinberg007
Member#: 7887
I've never broken a Presta valve. I've bent several, but never broken. They still work bent.
Presta is a one way valve when you are adding air. Schraders lose air when you attach and detach the pump. Plus, Prestas can be set up for tubeless where you can remove the valve stem easily and add Stans or similar sealant when it starts to dry up. Prevents you from having to break the bead to add the sealant.
quentinberg007 is offline   Reply With Quote
Old 12-09-2012, 01:28 PM   #6385
VpointVick
Member#: 93193
'90 Ishtbox Corolla
You could do the same with a valve core tool on a schraeder, but i prefer prestas also.
Old 12-09-2012, 01:31 PM   #6386
quentinberg007
Member#: 7887
I know you can remove the valve core on a Schrader, but is the passage wide enough for the Stans to not gunk up in there? Every attachment I've seen to dump the Stans in the tire threads onto a Presta.
edit: Apparently Stans makes a combo tool that removes both cores. I guess there is enough space.
Old 12-09-2012, 01:39 PM   #6387
marcmtb35
Member#: 171151
2008 FXT Sports
Aspen White on pink sprgs
The wide bars were super awkward at first, but I really started liking them by the end of my first ride.
I pulled the trigger on 2013 Scalpel 3. It should be here next week. I did however, want better wheels so I ordered some hand built wheels from Dave's Wheels. Stan's Crest Rims, Stan's 3.3 rear hub, and a lefty front. Should be good stuff. About $3,700 for the bike and wheels (I got a good deal on the bike).
Pics to follow when I get the bike.
marcmtb35 is offline   Reply With Quote
Old 12-09-2012, 06:51 PM   #6388
disaster999
Member#: 73197
I cleaned them out. Relubed it and it's still running pretty stiff. I'm thinking they are like that by design Since they are bushings and not a ball bearing.
I'll go see how much some ceramic bearings cost then decide.
Old 12-09-2012, 06:53 PM   #6389
usfsfire42
Member#: 242630
.. Pepperoni nips
and big slits...
If anyone is in the market for a Norco downhill bike let me know. I have one for sale. Originally $6k and has A LOT done to it. Will let it go for a great price!!!
usfsfire42 is offline   Reply With Quote
Old 12-09-2012, 06:54 PM   #6390
TheCokeCan
Member#: 89951
There definitely is enough space. Recently put in a mixture of stans/slime in latex tubes with removable valve cores and it was fine. The main problem is most presta tubes don't have RVC's, unless they're $$$.
TheCokeCan is offline   Reply With Quote
Old 12-09-2012, 06:57 PM   #6391
EnterTheDragon
Member#: 6511
Originally Posted by usfsfire42 View Post
If anyone is in the market for a Nordic downhill bike let me know. I have one for sale. Originally $6k and has A LOT done to it. Will let it go for a great price!!!
Norco?
EnterTheDragon is online now   Reply With Quote
Old 12-09-2012, 06:59 PM   #6392
usfsfire42
Member#: 242630
.. Pepperoni nips
and big slits...
Yep, sorry typed it out wrong
Old 12-09-2012, 06:59 PM   #6393
EnterTheDragon
Member#: 6511
Aurum?
Old 12-09-2012, 07:00 PM   #6394
usfsfire42
Member#: 242630
.. Pepperoni nips
and big slits...
Team DH is the model
Old 12-09-2012, 07:04 PM   #6395
usfsfire42
Member#: 242630
.. Pepperoni nips
and big slits...
Looks 99% like this. Has some better forks I put on it and some other pieces.
Old 12-09-2012, 07:49 PM   #6396
corzy666
Member#: 177840
2000 swapped RS
White 330whp
If you guys had the choice between a 2003 Cervelo P2K or a 2009 Felt S32 both for the same price, which one would you go for??
I'm leaning more towards the Felt.
corzy666 is online now   Reply With Quote
Old 12-09-2012, 08:10 PM   #6397
VpointVick
Member#: 93193
'90 Ishtbox Corolla
He uses Stan's with presta tubes with removable cores too, he thought that schraeders wouldn't have enough room. If anything, there's more room with the valve core removed with a schraeder than a presta,
Old 12-09-2012, 08:27 PM   #6398
quentinberg007
Member#: 7887
What are these tubes you speak of? Tubeless FTW.
Old 12-09-2012, 08:33 PM   #6399
VpointVick
Member#: 93193
'90 Ishtbox Corolla
Yeah, yeah. But you're using presta stems.
Old 12-09-2012, 08:40 PM   #6400
quentinberg007
Member#: 7887
Yup, I am. I can't fathom having to run tubes again. I got a thorn through my sidewall the other day and I just laid the bike on its side with the hole side down and pumped air in. The flat was fixed in just a few seconds.
Ride your Bicycle today! Howl Off-Topic 27 07-26-2008 01:00 AM
Ever wonder who's working on your bicycle... BlkTS02 Off-Topic 4 09-02-2005 10:29 PM
Carl post your pics of your dead mustang WRXMaster Texas Impreza Club Forum -- TXIC 20 07-01-2002 01:37 PM
post your 'to do' lists for your car here DoinkMobb General Community 46 03-31-2002 09:23 PM
Post your pics of your ROTA wheels FatCatTurbo Member's Car Gallery 29 01-30-2002 12:40 AM
Message Board Statistics All times are GMT -4. The time now is 01:49 AM.
